Question about Dell Dimension 4600 PC Desktop
Time and date change
Whenever we have a power outage my computer resets its date back to May 2004. I know how to reset the time and date, how can I make sure that the computer keeps the new date I set
  • 136 Answers
Replace the CMOS battery with a new one, and get yourself an un-interruptable power supply to handle the power outages.
Posted on Dec 27, 2008
  • 238 Answers
Go to your Bios Settings. Change the System Date there.
Power interruption and now my plug,n go seems to be frozen. Cannot set time or clear anything. Screen reads 9.80 or something close
I had a similar problem with my Bosch wall oven after a recent power outage-restart-outage-restart cycle that lasted only about thirty seconds altogether. The difference would be in that while I could reset all the things like day, date, time, etc., the oven would arbitrarily go off on its own and make up the day, time, date, year, etc., with no apparent correspondance to reality. Here's what I did: I completely shut down the oven at its outside breaker (you will need to do whatever it takes to remove the power from the 'plug-n-go'). I waited five or ten minutes before turning the power back on and resetting the various items. Two days have passed and there have been no more mind-of-its-own excursions into another time zone. Problem solved, unless/until another power outage cycle comes along. Hope this helps, or at least gives you an idea about where to start.
Dec 15, 2014 | Hardware & Accessories
Facebook display problem
If you haven't already set the time on your computer, you need to do so.
Depending on whether you are using Windows or Apple there are steps to take.
Try the following instructions at the link below:
http://www.dummies.com/software/for-seniors-how-to-set-the-date-and-time-on-your-computer/
For Seniors How to Set the Date and Time on Your Computer dummies
Mar 08, 2018 | Facebook Social Network
Wall scoreboard clock model #0028 not working after outlet blew
Remove several screws around perimeter of clock. Open up clock and find small (quarter -sized) battery. Remove this battery - it may be hot glued in place but you need to remove this. You don't have to replace it just remove it. Apparently this battery is used when you have a power outage to retain date / time, but when it goes dead it won't allow the clock to operate. So just remove it and put the clock back together and all should be fine except you will have to reset the date etcetera when you have a power outage.
Jun 09, 2013 | Computers & Internet
My emerson cks1850 still stuck to the old daylight savings time and I need to fix it as i rely on it for work and frequat power outages we have were i am and the auto reset is why i like it but now it...
unplug the clock radio from the power, take out the back up battery ( if it has one). let it set for 60 seconds or so, plug it back in, It should now be flashing 12:00 over and over. now reset the clock to the correct time and date.
Mar 14, 2011 | Emerson SmartSet CKS1850 Clock Radio
Does anyone know how to reset the "change Oil soon" sensor, and the "check tire pressure" sensor on a 2004 Pontiac Grand Prix GT?
Turn the key ahead to run mode, without cranking and push gas pedal to floor and back up 3 times within 5 sec, this should reset the oil change light. as for the tire pressure light there are a couple of procedures, but ensure first that the pressures are all above 28 psi, and are the same. however, without the use of a tpms tool to communicate with the tire monitor sensors it may not reset. did you have any tires changed over, or rotated? if so the use of the tpms tool is much easier to reset the light. Probably better off bringing to a tire or mechanical shop that deals with it regularly. It is actually not that difficult, but the tool will allow you to tell if a sensor is faulty, or has a weak battery, etc.. hope this helps
Jan 26, 2010 | 2004 Pontiac Grand Prix
Date resets back to 2001 after being powered off
Try changing the time and date in the BIOS and then save the changes and exit. Then turn the computer off.
Wait a few minutes then turn the computer back on and if the date resets back to 2001 then that means the battery on the motherboard is bad and would need to be replaced cause that means the BIOS isn't keeping information in memory.
The battery you would need is a cr2032 battery. Here is an enlarged image of the battery Im talking about:
http://media.digikey.com/photos/Panasonic%20Photos/CR2032.jpg
Aug 08, 2009 | HP Computers & Internet
Date & Time loss with Exilim EX-S600
Good Morning :
Hope that you are wellJ
This is the response from Casio:
"The date and time will reset and the setting will need to be readjusted. The camera does not have a separate battery for the clock. The date and time will reset whenever the camera is not supplied power by the battery and USB cradle for about 24 hours."
Sounds a bit messy to me.
If I can be of further assistance, please let me know.
And, remember; always include the type of Operating System and the type of computer you own, when you submit your questions. It simply makes for much faster solutions.
Have a wonderful morning.
Sep 30, 2008 | Casio Exilim EX-S600 Digital Camera
Wrong date on the radio.
RESETTING THE CLOCK AFTER A TOTAL MEMORY LOSS
If you do not change the built in lithium battery within a reasonable period of time after you see the ‘flashing’ LOW BATT. warning indicator, the lithium battery may become exhausted and will no longer be able to supply back up power to the SmartSet internal computer.
If the unit is disconnected from the AC outlet after the battery is exhausted, or if a power interruption occurs, the SmartSet memory will be lost and the clock will need to be reset when the power is restored. Be sure to install a fresh lithium battery before you reset the clock, otherwise the clock will need to be reset each time the power is interrupted.
If the lithium battery is exhausted and you experience an interruption in the AC power supply, the clock will reset itself to its initial default setting when the power is restored.
The initial default setting is “12:00 AM, Saturday, January 1
(1 1), 2005”.
If you notice that the time on your SmartSet clock radio is completely incorrect, and the day indicator is also wrong, press the MONTH/DATE button to see the date. If the date display is showing “1 1” (January 1 ), you probably experienced
a total memory loss. To reset the clock after a total memory loss, proceed as follows:
1.) Install a new CR2430 lithium battery in the battery compartment.
2.) Connect the radio to your AC outlet and let the clock set itself.
3.) Depress the MONTH/DATE and TIME buttons together. The display will change from ‘time’ to ‘year’. While holding the MONTH/DATE and TIME buttons, press the UP button to
set the display to the correct year, then release the buttons.
4.) Depress the MONTH/DATE button. The display will change from ‘time’ to 'month/date’ (mm/dd). While holding the MONTH/DATE button, press the UP button to set the display
to the correct month and date. The Day indicator will change automatically as you adjust the month/date settings. When the correct month and date appear on the display, release the buttons.
5.) Depress the TIME button and the UP button to set the display to the correct time. Be sure to confirm that you have set the time correctly to ‘AM’ or ‘PM’ by observing the AM indicator.
6.) After you set the time, reconfirm that the Day, and Month/Date displays are still correct. Make final adjustments if necessary.
The SmartSet clock memory is now reset and the new lithium battery will maintain it for the next 5 to 8 years, depending on the number and duration of the power outages you experience.
IMPORTANT NOTE:
After resetting the clock, don’t forget to reset your wake up times, and alarm mode settings, and sleep timer settings as well.
Oct 22, 2007 | Emerson SmartSet CKS1850 Clock Radio
Dell Dimension 4600 PC Desktop Logo
177 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
