Question about Garmin Quest GPS Receiver
SHORTENED FIND MENU - GARMIN QUEST
Greetings from England!
Be very grateful for help with my new Garmin Quest.On the FIND NEAR ME menu I only get a list of options which is much shorter than shown in the manual. It doesn't include either ALL POINTS OF INTEREST or ADDRESSES.
I have read the manual from cover to cover and cannot see anything help there. Please tell me how can I get the full range of options for the FIND MENU?Without it the devise is not very useful!!
Thanks,Simon
  • 50 Answers
SOURCE: screen says memory full and it won't map a route! GRRRRRRR
Hi, Please do not shoot the messenger (me) but this is a known problem with Garmin GPS units. According to Garmin Tech Support, this only occurs on Garmin units with older firmware. (Personally, I am not convinced this is actually true. I no longer have my Garmin C550, which I personally liked the best out of all the GPS units I have owned or used. I will buy another Garmin, probably a Nuvi, when this silliness sorts itself out.) Anyway, you have two options, neither of them acceptable to most people, including me. 1)Perform a HARD RESET which will wipe out all data on your unit, including your favorite points, Bluetooth connections, and almanac data (satellite information). Your unit will then need at least 40 minutes, with a clear view of the sky, to update the almanac and reacquire its location. To HARD RESET, unplug your C550 from the charger and turn it off. With the C550 screen facing you, press the bottom right hand corner of your screen and hold in (relatively firmly) and then press and hold POWER. You need hold both constantly for at least 30 seconds. Follow the instructions on the screen. See if any of your personal information is still there. If there is none, then you might as well perform Step 2 below. 2)Download and Load New Firmware onto the C550. Upgrading firmware is relatively easy provided you have a computer. Visit Garmin's website (www.garmin.com). Go to "Support" .. "Updates and Downloads" and then click "Unit Software." Download the software called WebUpdater. Run that and follow its directions. The new Firmware (Software that is loaded into internal memory that does not need power to remember the information) hopefully will fix the MEMORY FULL problem. Good Luck and please post back if the fixes helped or not. I really want the new firmware to work so I can buy another Garmin.
Posted on Oct 06, 2007
  • 174 Answers
SOURCE: Garmin nuvi 250 mapsource
Verify that you have the correct basemap for the country that you are in. There are two maps inside a new Garmin. The basemap which shows all the major highways and mapsource which shows all the street. If you don't have the correct basemap try changing 'Navigation' Advoidance to avoid highways and Toll Roads.
Posted on Jan 28, 2008
SOURCE: way point memory full and will not find route
Hold your finger in one of the touch screen corners when switching the unit on. It will ask if you wish to delete all user data. Do this and your unit is hard-resetted.
This will lose all of your waypoints and favourites, but it'll restore your unit to you.
Enjoy
Posted on Aug 22, 2008
futureloginn
  • 734 Answers
SOURCE: no data available mess
Did you try to perform a map upgrade to 2008? Turn on the Garmin and from the main menu touch the wrench, then press Map, then look for Map info.
Posted on Dec 08, 2008
SOURCE: Garmin Quest: Not able to upload detail maps
hi bud, just had the same problem. hard reset i.e turn off unit, hold down ok, page and then the power button at the same time. it should then ask you if you want to delete all data. select yes and then you should be able to upload your maps again, this worked for me good luck
Posted on Feb 25, 2009
Cant get my quest to work with windows 7
your computer must have Garmin USB drivers installed. Go to Support at Garmin.com. Download and install, then connect your Quest.
Nov 09, 2012 | Garmin Quest GPS Receiver
Garmin Quest antenna broke of while quading need new antenna where to?
The best thing I can recommend is shop around on Ebay and hopefully find a basketcase Quest or Quest 2 with the antenna intact. Swapping the antennas is fairly easy. Lay the GPS display side down and remove the two endcap screws on the right side. Pull the old antenna out and to the right and replace it with the replacement antenna. Another option you may try is purchasing an external patch type antenna that can mount remotely and plugs into the back of your Quest GPS. Garmin WILL NOT sell you a replacement antenna. They want you to send it to them for repair and will charge you $100+.
Oct 05, 2010 | Garmin Quest GPS Receiver
"Detail maps Don't Support Routing" in Garmin Quest
I too have a Garmin Quest and yesterday felt like throwing it against the wall because of the above problem. I found the solution eventually. When you download the maps from the Garmin Maps page, where you select the maps download, make sure that the checkbox to "Include route calculation data" is ticked before downloading your maps. Also make sure that the total memory required for the number of maps selected does not exceed the available memory on your Quest. If you try to fit more information into your Quest than it can receive then you are bound to have some problems. The Quests seems to have different memory specifications. According to the USA spec the memory is only 128mb, the Garmin site says 115mb and the box that my Quest came in says that it has 243mb.
Jul 10, 2009 | Garmin Quest GPS Receiver
Garmin Quest 2 GPS
www.batteryship.com. Look on the screen for "GPS Devices". Click on that and it will take you to a page of pull down menus. Find the Garmin menu and just look for "Quest". Battery is about $25.
Dec 18, 2008 | Garmin Quest 2 GPS Receiver
Garmin Quest Coordinates
Menu/ Map Setup/ Layout/ Orientation,  choose 'North up'. To return to normal choose 'Auto'
Aug 19, 2008 | Garmin Quest GPS Receiver
Garmin Quest
Hello, I currently own a Garmin quest myself, and some time ago I had some strange problems myself, I am a electronics technician, and I do have a work around for you. I will explain the problems and a cure for you to try, none of the work arounds depend on any parts to be removed.
1. NO RECEIVING SATELLITE TELEMETRY. I beleieve this could be due to a number of reasons, but more so at sometime corrupted telemetry was the problem to fix this,
a turn GPS on when booted (initialised)
b. depress menu
select settings
select Time Setup
when in Time Setup depress MENU
Select SET DATE
Depress OK button
Depress OK button again on the numberic keypad that appears on the screen (DONE)
what this seems to do is resets the internal date/time clock and the unit starts to work again.
the Second workaround is this but takes hours to perform.
Simply turn the Guest on and allow the battery to fully discharge, usually this works to TOTALLY flush the Memory again, but on my unit I have to setup all the maps again, this is easy to perform, but just takes time. I hope this helps you.
phil
Mar 21, 2008 | Garmin Quest GPS Receiver
Garmin streetpilot C330
maybe you need to go to the settings click on map and click restore. If that does not work click map info and and see if it shows you two different maps. Hope that helps.
Jan 04, 2008 | Garmin StreetPilot C330 GPS Receiver
Sep 25, 2007 | Garmin nuvi 350 GPS Receiver
No Reception with Garmin Quest
You can find a discription how to reset the GPS here (http://www.elsinga.net/quest-first-aid).
I've already tried it and all the suggested solutions like discharging the battery, changing the date, ... , but it diden't help.
littletramp on worldtrip
Aug 28, 2007 | Garmin Quest GPS Receiver
Garmin Quest GPS Receiver Logo
35 people viewed this question
Top Garmin GPS Experts
Marvin
Marvin
Jean-Luc Steffann
Sheldon Dedek
Are you a Garmin GPS Expert? Answer questions, earn points and help others
