Question about Brother CS-8060 Computerized Sewing Machine
Embroidery machine janome 300. The top thread keeps bundling underneath and machine jams
  • Brother Master
  • 1,388 Answers
Please TRY the solution BEFORE giving your considered rating.
Ensure that all is clean and free of lint and jams, this is the most likely cause....now for tension troubleshooting .......
This solution is for tension problems...if you cannot form any sort of stitch, the issue is quite different, so please let me know if you need a different problem solved.....
It is quite long, but just work through each section in order.
The "knotting up" can reveal a lot. If you have loose threads on one side or the other, the tension on the opposite side will be the culprit.
QUICK SUMMARY FIRST:
Ensure sharp new needle,
Thread guides and Bobbin are Clean & Clear of lint
Set Top Tesion to 3 ....then....
Balance Bobbin to suit.
TOP THREAD TENSION:
If the looping threads are on the underside as you sew, it is the top tension. Top tension ought to be between 4 & 6 (this variation to allow for the different weights of fabric in your
projects).
IS YOUR NEEDLE SHARP ?
If you are using a needle that has seen quite a deal of work, or you suspect it may be blunt, change it for a new one !
TOP TENSION & GUIDES:
Make sure that when you thread the machine the presser foot is up so the thread goes between the discs and not to one side, top tension between 4 and 6, and that you have threaded through all the guides, including the last one, usually on the needle arm, just above the needle clamp.
It may be there is lint trapped between the discs, this will keep them slightly apart and reduce the actual tension, sometimes dramatically.
If tensions appear correct, and the thread is definitely in the channel between the discs, but still too loose and looping, try raising presser foot and remove your thread.
Now, with a 2" (50mm) wide strip piece of fabric 8 - 10" (20 - 25cm) moistened with methylated or denatured spirit, gently insert the fabric strip and clean between the discs with a see saw / to and fro action.
In the worst cases, gentle use of a needle to pick & remove the jam may be necessary, but be very gentle and make sure the tension is set at Zero and the presser foot is raised, (to disengage tension plates).... do not gouge or score the plates, they need a polished surface to work correctly.
BOBBIN TENSION:
Far less common, but if the loose threads are on the top, it is bobbin tension that is loose, it too may have lint in the spring and be giving a "false" tension.
I would not recommend fiddling with bobbin tension without good reason, it may end up with missing small screws and spring pieces, however, you can take the needle plate off to clean the hook race area (where bobbin case sits)
...this is just good housekeeping, my wife does this every time she replaces the bobbin....
just take it out and clean the bobbin case and the fixed metal hook race with a small brush to remove lint. If there is a significant amount of lint, use a vacuum and small brush to get the worst.
Then wipe all this area with a cloth or cotton bud (Q tip) moistened (not soaked) with methylated spirit, especially if there appears to be fine dirty deposits....oil and lint combine to conspire against you.
If it seems likely that you ......really ....do .....actually .....need .....to adjust the bobbin case, first check there is no lint trapped in the metal spring where the thread is tensioned.
TOP LOADER:
Drop-in Bobbin case will look similar to this image with the tension screw in the middle of the metalwork....
embroidery machine janome 300. - 4c76dc1.jpg ...the other screw at one end is holding it all together, so beware....it is not a tragedy to undo the whole lot and clean it, but very gingerly and lay the bits out in sequence and orientation, or you risk tearing your hair out !
FINISHING UP
GETTING THE BALANCE RIGHT:
When you are certain there's no trapped lint in top tension or bobbin, set the top tension to 4 and the bobbin tension to a point where you just begin to feel resistance.
Try using good quality thread of contrasting colours so you can more easily spot the changes.
Sew a sample for a few inches and check the result.... adjust the bobbin tension screw very little at
a time, perhaps 1/16 of a turn.
You may find you are playing with this balance for some little while and if you are putting the needleplate on and off each time begin to think it cannot be correct to do this.....BUT....it is,
and eventually, you do get a "feel" for the correct tension and then it happens quite quickly.....as a user you won't be doing it very often unless there is lint built up (or are there small hands at work around the house !?!?!)
OTHER ISSUES:
If you live near the ocean as we do, salt air can play havoc with metalwork inside and out, so to help minimise this, keep a few small packets of dessicant (silica gel) in your machine
case....no case ? then make some sort of cover !
Same applies in any damp or humid environment, keep your machine dry and dust free.
Budget for a proper full service every couple of years (more often if heavily used) and if you don't use your machine for a few years, be aware that old oil will dry out and combining with
dust and form a "clag" like glue (another reason for some sort of cover, even a teatowel !)
FINALLY, A WORD ON THREAD:
If it is worth spending the time, energy and money on making something that you would like to give lasting enjoyment......use quality thread, .......it may seem to cost a little more at the
time, but the results, ease of use and added longevity will be worth the extra, and as a bonus, your tension troubles may be fewer and further between, because there is a more consistent diameter with good thread, and less compensating to be done by your tension plates and less thread breaks !
Posted on Dec 28, 2008
I posted what I did to temporarily solve the problem. I put a piece of water soluble stabilizer on top of the material and it worked
Why does my Janome mb4 keeps shredding its top thread?
Change your needle and if it continues to happen, change the thread. Most likely your needle and thread are not compatible, ie the thread is too large for the needle's eye. Also, inexpensive thread will shred.
Sep 05, 2015 | Janome MB4 Four Needle Embroidery Machine
Having difficulty with free motion machine embroidery on my Janome Mystyle 16, top thread keeps breaking. What can I do to stop the thread from breaking? Plus the stitching is very erratic,any ideas?
1. Set up for regular sewing (not embroidery).
2. Adjust the tension of the bobbin and the top thread so that you have a nice straight stitch.
3. Check your thread quality. Is it fuzzy or have small trails sticking out. No Walmart thread allowed. Only top notch embroidery thread allowed.
4. When you've been successful with the thread and tension go ahead and set up for free arm.
5. Sew free arm but remember machine has to keep up with you. If you go too fast you will be pulling the thread and probably will break the thread.
6. Your erratic stitch is caused by the speed at which you are moving the hoop. Going fast; then slow is going to make a long stitch and then a short stitch, etc.
Apr 03, 2015 | Janome Sewing Machines
Janome 5900 sewing backwards!
Most likely, the bobbin thread is not in the bobbin tension. Rethread the bobbin and try again.
Loops on top of the fabric almost always mean too little tension on the bobbin thread; loops on the underside almost always mean too little tension on the top thread. Just backwards of most people's first guess. See http://www.picturetrail.com/sfx/album/view/22521551
Jan 18, 2014 | Janome Sewing Machines
Thread is knotting up on bottom of fabric causing it to stop
1.check the needle & see if it's bent--if so replace
2.lay the needle on a flat surface & roll the needle over if it doesn't roll true replace
3.check for blunt needle-if needle makes a popping sound when needle penetrates fabric
4.needle is not all way up in holder
on my mechanical sewing machine sometimes the threads come off the take up lever, that causes the thread to bunch up under something I'm working on
also check thread in bobbin
Jul 28, 2010 | Janome 4623 Mechanical Sewing Machine
I want to sell my 1991 New Home memory Craft 8000 sewing machine
A good place to see what machines are selling for is Ebay. That's where I sold a sewing machine and an embroidery machine.
It helps to know your product and machine embroidery lingo.
What are cassettes? Floppy disks? These make the machine borderline obsolete.
Memory cards are still around, but most EM now have USB connectivity or USB flash drives.
Satin thread? Embroidery machines use Rayon or Polyester embroidery thread.
Having had the machine recently serviced is also a plus.
Mar 19, 2010 | Janome Memory Craft 9000 Computerized...
Thread keeps breaking
Have you checked any edge the thread might contact for knicks which should be files or sanded down? Also, I had to replace my bobbin case after a number of years as it had kind of stretched out and allowed my bobbin to pop around and consequently broke many threads.
Feb 07, 2010 | Janome Memory Craft 9000 Computerized...
Top tread bird nesting.
When you say top thread nesting, I supose you mean that the thread is messed up at the top of the needle plate.
If so,
1st, either your bobbin thread is completely loose, or the bobbin thread is not held under the bobbin case spring,
or lint has been accumulated under the bobbin case spring.
2nd, the top thread is very tight,
or both.
Jun 10, 2008 | Janome Sewing Machines
Brother CS-8060 Computerized Sewing Machine Logo
183 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
