Question about NetGear DG834G Router
Problem connecting Ipod touch to WiFi
I cannot connect my ipod touch to my netgear DG384G router.I have the IP address and Subnet Mask (?) 255,2550.0 but have no information for: Router DNS Search domains Client ID
  • purpledebz Dec 27, 2008
    I received my ipod touch for Xmas and have the same problem. It finds Netgear and IP address and subnet mask are filled in but what do I type in the fields "routner" , "DNS", "Search Domains" , "Client ID"
  • Anonymous May 15, 2009
    unable to connect
What password are you entering on to the ipod touch?
Posted on Jan 05, 2009
My LG 55LW6500 55 3D HDTVReady LCD won't connect to my NETGEAR R6200 router. The gateway does not pass!
try to manually configure the ip address on your TV settings ... ip address , subnet mask, gateway and dns. refer to the ip address used by your router. :)
Aug 10, 2013 | NA Netgear R6200 802.11ac WiFi Dual...
Hello, I've just bought an ipod touch and cannot access my internet without a password. How can I find these out without changing them ? What are IP Address, Subnet Mask, Router, DNS, Search Domains,...
I had exactly the same problem with a brand new 3rd gen iTouch. It showed it was connected to my wifi network but wouldn't access anything (invalid argument etc). I tried everything but no joy. Eventually I fixed it by changing my router's encryption from WEP to WPA2-PSK. Fixed it like magic. Where there had been no router or DNA data before, they were suddenly filled in. The key was different but was still on the bottom of the router. I had to re-enter the key on my wireless laptop2_bing.gif but that was a small price.
You can get into the router set-up page through your web browser. I found a guide on You Tube.
Feb 25, 2010 | Apple iPod Touch 8GB 32GB 64GB 3rd...
Unable to connect iPod to WiFi router
I have exact same problem and the exact same router.
Jan 27, 2010 | Belkin (F5D7230-4) Router (587009)
I cannot get internet connection, i am on wireless 1 and it is asking for a password also i don't know the ip address, subnet mask and the dns
Even if the modem/router you are trying to connect to allow 'dynamic IP' address resolution (eg. no need for coonecting device to know IP address, subnet, etc...), you will still need to know the specific 'password'/ 'Security Key'/Encryption Key for your specific modem/router Wifi coonection - I am assume that you also know the correct SSID (Broadcast system ID for Wifi) for this Wifi Connection.
Hope it clarifies a few requirements.
Dec 27, 2009 | Apple iPod touch
I have an iPod Touch and I have been trying hopelssly to connect to the wifi. I have a BT Voyager 2110 router. I have been putting in the right password and it even says I am connected as it has a tick...
Well... since you said PLEASE help!
So what is the IP Address that the iPod Touch gets? Does it match with what range the BT gives out?
Does anything else connect through that router successfully?
You might try changing the WEP, WPA, WPA2 that you are using ... see if that helps the iPod touch to connect. I've seen where certain computers, etc. do not like WPA or WPA2 or certain passwords or key codes.
Mar 01, 2009 | NetGear DG834G Router
Connecting Ipod touch 8(GB) to Wi-fi
netgear support software could be bad. The ipod might not be able to read signal. umm try restoring the ipod. then plug it to your computer let it recognize it and then before you add ANYTHING to it, go straight to the setting and put in the router number and everythign and see if it works. I know people hate it but restoring it usually works. Its just simple small virus's that hit your ipod through songs and stuff and it eventually makes everything stop working. So get back at me let me know if restoring it worked.
Jan 18, 2009 | NetGear RangeMax WPN824 Wireless Router...
I want to tell you that there might be two problems for your concern.
1. Your router is not working properly
2. Your Ipod Touch is not working properly
But it might be possible that both devices working fine just the compatibility issue.
First of all i can suggest you that you can upgrade the firmware for your router.
Then you can reconfigure your wireless setting on your router.
Then tried to put static ip on your ipod touch in the network setting option
IP address: 192.168.0.15
Subnet Mask: 255.255.255.0
Default Gateway: 192.168.0.1
Primary DNS: 192.168.0.1
Secondary DNS: 4.2.2.2
Then tried again to connect wirelessly with your ipod touch make sure you dont required to add mac address for you ipod touch and also you can click on the option called "Wireless Access Point"
Then you can see the option " Turn Access Control On" you can uncheck this option.
Try again i believe that will resolve your concern.
Thanks & Regards
Jaspreet Singh Saini
Jan 06, 2009 | NetGear RangeMax WPN824 Wireless Router...
Can't connect my router to my Ipod touch?
ok do this if it is already showing your router up on your portable device but it has that security lock and you are unable to join or need a password which u dont know lol go to that network and on the top push forget this network. than go back and click on for other location. than for the name put in your router name usually 5 characters long make sure u use capitalization cuz its case sensitive. than select what kind of key u have it should say right on the side of your wireless router. than type the key in usually a wep key and u should be set to join it if it doesnt auto matically do soo
Dec 20, 2008 | Zyxel P660HW-D1 Router
sometimes the wifi systems only work with windows, the ipod only uses safari and thats what you see on the error. Its connected but safari cannot open it since it is not windows
Dec 13, 2008 | Computers & Internet
NetGear DG834G Router Logo
947 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
