Question about Toshiba Satellite P25-S5093 Notebook
Suddenly my toshiba p25 off
Somebody suggest to check RAM
Toshiba P25 cannot read cd
Make sure it has power (ejects). Check Device Manager in Safe Mode by pressing F8 during boot. Right click My Computer > Manage. Select Device Manager > View > Show Hidden Devices. Now delete all DVD/CD-ROMs and reboot. Windows will say "New Hardware Found" and install. Check BIOS by pressing F key (correct F key is noted during boot) and make sure BIOS see's the Optical Drive.
Nov 28, 2012 | Toshiba Satellite P25-S5093 Notebook
The monitor on my Toshiba P25-S5093 does not have any display of any kind; all black. I have display using external monitor.
Does the display show anything before you enter windows? If yes, then press the key to transfer video back to your original screen once you enter windows. It should be the function key "Fn" + F5 - F8. looks for the icon which shows a monitor or says "CRT/LCD".
If it doesn't show anything before you enter windows I'm afraid your screen needs to be replaced. Good luck.
Mar 08, 2011 | Toshiba Satellite P25-S5093 Notebook
My toshiba satellite p25 s670 suddenly stops what can I do
boot it to safe mode, then run a system restore a week before the issue occured. if there is any resource in conflict with what was installed, this will be removed and problem resolved.
if that did not help, open the laptop up and remove the memory and hard drive, then re seat them properly.
Sep 13, 2009 | Toshiba P25-S670 Notebook
My laptop tushiba satellite p25 s670 doesn"t start and beeps 3 times
you might have bad memory.if you have more than one dimm installed try using one at a time.
Good luck
Sep 05, 2009 | Toshiba P25-S670 Notebook
My toshiba P25-S676/80 will not turn on. No
May be a bad power jack or the powercord/ac adapter may not be putting out enough power.Your powerboard may need to be replaced or even the button itself may not be getting contact to the board itself.
Jul 11, 2009 | Toshiba Satellite A60 Notebook
I can't read my screen because it it too llght
You should have a Fn button on your laptop, and pressing that, combined with the button that has a sun on it should raise your screen brightness, if your screen only has one brightness setting, and it got much darker all of a sudden, your LCD lamp probably went out, in which case it is probably better to buy a new laptop, because those are expensive to replace.
Feb 26, 2009 | Toshiba Satellite P25-S507 Notebook
Nothing comes on my screen when i power on
you have to resit the ram,if the problem is not solved then dislplay adapter is gone, you have to send it for repair
May 31, 2008 | Toshiba Satellite P25-S5263 Notebook
Toshiba Satellite P25-S5093 Notebook Logo
57 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
