Question about GE Refrigerators
Ice build-up around the fan making a noise.
Ice build-up around the cold air fan making a loud noise. Also noted some ice and water in the Refrigerator. Both freezer and Refrigerator cool ok. Guess it is a defrost problem??
GE profile refrigerator 4 years old.
Drain line froze.
Used hair dryer to thaw frozen line, works OK now. 01/07/09
Think the frozen drain line was caused by the light in the refrigerator not shutting off when the door closes, causing excess cooling in the freezer. Poor design on the light shutoff switch, corrected design to make permanent repair
chestnutlee.
Posted on Jan 07, 2009
Freezer fan makes noise
Noisy fan = new fan motor.
May 13, 2017 | Admiral Refrigerators
Loud "clattering" noise from freezer area when refrigerator runs
There is a fan in the back of the freezer that runs when the compressor is running. It sounds like you have ice build up around the fan.
You could have one of these problems: (Sorted by most likely to least likely)
1) Auto Defrost timer, defrost bi-metal or defrost heater is defective - the unit will go into auto defrost about twice a day, if this fails you will have lots of ice built up around the cooling fins and sometimes on the fan. Pull the back off the inside of the freezer and check for ice build up around the cooling fins, there should be none or very little if its running normal.
2) Bad door gasket - if the freezer door is leaking warm moist air inside the freezer it could be condensing around the fan causing ice (you will also see ice build up on things inside your freezer too).
3) Plugged drain - the drain leads from the freezer down to the drain pain under the fridge. If this is plugged ice will build up on the bottom of the freezer and potentially around the fan.
Apr 01, 2013 | Kenmore Refrigerators
GE Side by Side Refrig - loud noise behind the ice maker section Model PSS25SGMB BS
it sounds like the evaporator fan blade is hitting some ice that has built up around the blades i have seen this happen a lot on g.e. SxS lately,if you can remove the ice maker and dispenser you can see the fan blade,if you dont want to do this then shut down the refrigerator and leave freezer door open and heat it carefully with a hairdrier to speed the process up to melt this ice then restart it and the noise should be gone
Aug 30, 2012 | GE PSS25SGNBS Side by Side Refrigerator
There is ice building up around the fan. If I don't keep chipping it off the fan the fan hits the ice and is quite loud.
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Feb 19, 2011 | GE Refrigerators
My fridge is making a loud noise that sounds like an air compressor.
The defrost is not working and ice has built up and is hitting the fan...
heatman101
Dec 20, 2010 | GE PTC22MFM Top Freezer Refrigerator
Freezer fan is making loud noise
Fan is hitting ice build up...defrost is bad...
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
How to Defrost Refrigerator Defrost Timer Problem
heatman101
Sep 19, 2010 | Frigidaire FRS26KW3AW Side by Side...
My bottom refrigerator is not cold. The freezer is okay.
Check to make sure the fan in the freezer compartment is working and not blocked. This delivers the cold air to the refrigerator. The fan should run every time the freezer calls for cold.
Jul 22, 2009 | Refrigerators
Ice build up in bottom of refridgerator, loud fan noise
check gaskets for air leaks or blocked drain in freezer section
Jun 06, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Refrigerators Logo
369 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Brad Goodale
