Question about HP Pavilion dv6000z 15.4" Notebook Laptop PC 64 X2 Duo Core TL-56 1.80GHz, 1GB RAM, ... PC Notebook
I have a HP laptop. When I turn on the PC the screen is just fuzzy and blurry like that fuzzy picture on a TV. I cannot log on or anthing, cannot see anything except this fuzz. Can you please help??
  • 538 Answers
Try to wiggle LCD a little. If it starts to work in certain position, - LCD needs to be replaced.
Posted on Mar 19, 2009
Iphone 4 screen has gone fuzzy and blurry
time to replace you digitizer and screen. We do it for 99.95 with return shipping.
Feb 18, 2014 | Apple iPhone Smartphone
My iphone screen is fuzzy and blurry
Your screen is demaget, change with new
I would like you to tell witch keys i should used to get hp pavilion dv9000 pc lobtop screen to display on a samsung plasma monitor
I'm assuming you are connecting the laptop to the plasma screen with an HDMI cable. If you have done so, then have both the TV and laptop turned on. Log into the laptop with an account. After you have logged in, you can press the function key (Fn) and usually its F4 (the key has a picture of a square, this represents the external display connection) at the same time. The plasma tv should display what is on the laptop.
So, Fn + F4 should work.
May 21, 2011 | HP Pavilion dv9000z Notebook
When I turn on the TV, the picture is fuzzy. After five minutes, the picture is clear but any words are out of focus even the menu for adjustments is out of focus. The convergence for red is clear but...
Below are some troubleshooting tips for a TV that has a fuzzy or blurry picture;
If your Plasma or LCD TV picture is blurry or fuzzy there are several things that may be causing the problem. It's worth running through the following list before seeking service. You may find yourself saving the full cost of a TV repair.
Make sure you are using the appropriate cable box for your TV. If you have a high-definition TV you should also be using a high-def channel box from your cable provider. Watching standard definition channels on a high-def TV can make the picture look distorted and fuzzy.
Not all cable channels are broadcast in high-definition. When you stretch a standard definition picture to fill the full frame of your wide-screen TV it may look distorted. You can try changing your TV display settings to show standard-def channels at their native resolution. This will create black or gray bands on either side of your picture.
Ideally all of your video components will be connected to your TV with HDMI cables. Your next best option will be component video cables. If your cable box does not have HDMI capabilities, contact your cable company about upgrading your box to one that does include HDMI.
Make sure there is no glare on your TV from a window or other strong light source. This can significantly degrade the quality of the image you are watching.
If your TV has digital noise reduction, try turning that feature on.
You can adjust your TV's sharpness and picture modes to see if that improves picture quality.
Try plugging the power cord into a different electrical outlet and/or surge protector. You may be receiving electrical interference through your power cord.
Trying moving any nearby electrical devices away from the TV. They may be creating interference that can degrade the picture quality.
Let me know if the above helps or not, so that I can direct you further on what do next.....
Best regards.
Apr 14, 2011 | Zenith IQB50M90W 50" Rear Projection...
I have owned an emerson tv for two years now. All of a sudden the picture has become very blurry and white. It is not the cable connection and a DVD is also white and blurry. Even the input channels are...
you must open the back cover of tv, and then things you should do is set "SCREEN" adjustment on the flyback transformer. you must turn it counterclockwise to reduce and decrease the level of screen brightness. turn screen adjustment gradually until the horizontal blanking lines disappear from the screen. and blurred images will be sharp again
Aug 11, 2010 | Emerson EWF2004 20" TV
Doubled colors, fuzzy
Dull Video...
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
* Screen Looks 3D, Warped, Distorted, etc
* Colors do not line up
* TV may shut off - and make a chirping sound.
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya
Jun 01, 2010 | Philips 60PP9202 60" Rear Projection...
Philips blurry 34pw8502/37 Blurry Screen
a part called picture tube base which connects picture tube to circuit board got some trouble,,, u can replace it with the help of a service pro..
Mar 23, 2010 | Philips 34PW8502 34" TV
Blurry picture
If you know where the fly back is, ok open the casing and see at the back of the fly back, there are two knobs, one for the focus and the other is for the brightness. Try twist both and see which one is for the focus. Ok, from the focus knob try adjusting until the fuzzy sight disappears. Try this, I usually do it to screens with blurry appearances.
Nov 10, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Fuzzy pictures
The blurry pictures are due to movement. Sometimes adjusting the flash helps.
Mar 19, 2008 | Samsung Digimax S630 Digital Camera
Blurry screen
coolant fluid on picture tube may be contaminated replace it an setbe ok (this is a technician job)
Mar 19, 2008 | Philips Magnavox 9P6034C 60" Rear...
HP Pavilion dv6000z 15.4" Notebook Laptop PC 64 X2 Duo Core TL-56 1.80GHz, 1GB RAM, ... PC Notebook Logo
520 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
