Question about Dehumidifiers
Delonghi DE220 dehumidifier stopped extracting water from the air
Basicially everything seems to work and he dehumidifier light is on but there is no water being extracted and stored in the holding tank
  • fred 95 Jan 24, 2009
    I have a dehumidifier Delonghi DE220 which doesn't work any more.
    It sets off, the fan turn but it doesn't take out a dro of water in the reservoir.
    have a resolution you ?
    my email heyo@wanadoo.fr
    best regards
  • 4 Answers
You probably have a dirty heat exchanger. Write to me at j_sjohn@hotmail.com for free maintenance instructions on a smilar unit. Cheers.
Posted on Jan 05, 2009
Runs but no longer collects water
In the price range, most of the comparable united are the same under the skin. I like whirlpool since replacement parts are widely available.
before you condemn the unit, check three airflow and the temperatures of the suction and discharge tubes a few inches from the compressor. If the discharge is hot and the suction is cold, the circuit is probably still whole.
Nov 30, 2014 | DeLonghi DE400P Dehumidifier
LD451EGL no water extraction
Apparently, the fans are running, but the compressor has shut down. It could be a failed compressor, or the charge in the system could have leaked out causing the compressor to shut down.
Aug 01, 2014 | LG Electronics Ld451egl 45-Pint...
My delonghi dehumidifier will not cool the house just keeps blowing warm air and dosnt feel to cool were thinking about giving up on it
Dehumidifiers aren't supposed to cool your house. If anything they generate heat. How it works is, it has cooling coils that it draws air across, which causes the moisture to condense, and be captured. However the heat extracted from the air has to go somewhere, so it just blows out the other side. If you want cool, buy an air conditioner.
Sep 09, 2012 | DeLonghi Dehumidifiers
My dehumidifier as stopped extracting water and has started icing up
There are 4 basic, yet solvable reasons for what you have described.
1. Air intake filter is dirty or clogged. Turn unit OFF, & Unplug the
Unit, before removing to inspect & clean it, if necessary. If washed,
allow filter to completely dry before reinstalling. DO NOT operate
the unit without the filter.
2. Obstructed air flow. Maintain a minimum of 12 to 18" of clear air
space around the entire unit.
3. Cooling coils are dirty and need to be cleaned. Use warm water & dish washing liquid to
clean the coils. Rinse and wipe dry. Apply a light coating of WD40 to the coils.
4. Ambient air temperature at floor level is between 40 - 60 degrees.
dehumidifiers do not work well between those temperatures
(Unless, you have a Low Temp Unit). This applies mainly to
where the air temperature at floor level is colder than at shoulder
level
in basement applications. Raising the unit up off the floor,
onto a sturdy table, counter top, etc, that can handle the weight
of the unit, plus a full tank of water, will usually resolve this
problem.
I hope this helps you troubleshoot & solve the problem. Thanks for choosing FixYa.
Jul 25, 2011 | DeLonghi DE500 Dehumidifier
Runs and everything seems okay but is not pulling any water out of air
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
Jun 06, 2011 | DeLonghi DE500P Dehumidifier
My DeLonghi DE500P dehumifier whch I purchased last fall is no longer collecting water. Everything seems to be functioning as outlined in the instructions. The rooms humidity is about 55%. Any ideas?
heatman101
Feb 07, 2011 | DeLonghi DH40P Dehumidifier
I have a Model 25350650000 Kenmore Dehumidifier. Everything works--motor, fan, lights, won't extract humidity from air
There are many reasons why a dehumidifier will not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier
http://www.fixya.com/support/r4662409-dehumidifier_running_but_no_water_in
heatman101
Aug 22, 2010 | Kenmore Dehumidifiers
Does not remove water I do not know if copressor is working. I would like to get an electrical schemati and parts list for my Delonghi 40 pint dehumidifier, type DH90U.
It could be a bad compressor, circuit board, or maybe even a sensor or dehumidistat...
Here is a tip about dehumidifiers2_bing.gif that run but do not extract water from the air..
Dehumidifier2_bing.gif is running but no water is in bucket
heatman101
Apr 20, 2010 | Dehumidifiers
De Longhi DE220 De-Humidifier not collecting water
Hi there - you have to vacuum the filter several times. You can pull it out of the back left hand side of the unit. Vacuum it several times, and then start the unit on the lower fan setting, at a humidity level of around 60%. It will kick in after a bit, and then you can start adjusting the humidity level to where you would normally use it.
Sometimes - after you have vacuumed the filter, it still doesn't work. I used my fingers to pick lint off the filter, and ran a BIC safety razor over it as well, to try and get more out of the filter. You can also wash the filter in warm water, and leave it to dry over night. Don't put it back in until it's completely dry.
This will work! Cheers... E
Sep 12, 2008 | DeLonghi DE500 Dehumidifier
Dehumidifiers Logo
623 people viewed this question
Top Dehumidifiers Experts
Bill Long
Gil Shultz
jasbo
jasbo
Are you a Dehumidifier Expert? Answer questions, earn points and help others
