Question about Jetway 939GT4-SLI-G Motherboard
New Jetway 939GT4-SLI-G won't power up
I just upgraded my MOBO with a new Jetway 939GT4-SLI-G, CPU and 1GB of memory also a ATI Sapphire X1650PRO. The problem I'm having is after power on it appears to go thru POST FF on the De-Bug Port a short beep and then powers down. I unplugged all IDE cables and power to the disks. Same results. The PSU is a Antec 430 watt supply which should be enough. The only diff with this supply is it has a 20 pin power plug ... The manual says it should work .... Any Ideas??? Thanks in advance Dale G.
  • Dale Galekovic Apr 22, 2007
    Jetway 939GT4-SLI-G MOBO doesn't come with a onboard video. The memory is new and DDR 400. There's no old CPU it was an MOBO upgrade from an Intel based MOBO. Debug Port Post Code FF means Boot. But after FF is displayed and the short beep code the MOBO powers down. I suspect power is an issue but not sure ...
  • Dale Galekovic Apr 26, 2007
    This problem was fixed ... Because of the fact that this processor was used in a water cooled environment the Thermaltake fan/heatsink assy. wasn't making good contact with the CUP die. I had to cut off the small plastic nubs on the yellow plastic retainer that is around the CPU. This allowed the heatsink to sit lower ... approx. 1/23" lower and was enough to allow the CPU to run.
    Anyways thanks for the help ... now I have another issue ... Blue Screen upon boot up....
Thank you for the 4 pin connector your a life saver i was about to get pissed but now i am in bussiness
Posted on Aug 08, 2007
    President:
  • 2,961 Answers
Some processors require the extra 4 pin plug to be connected to the cpu power terminal, to power it up and not from the zif socket. Apologies if i'm wrong but it's suprising how many people forget to connect it when they're used to the board supplying the psu power.
Posted on Apr 24, 2007
  • 385 Answers
Try using the onboard video first, remove the video card and any other card from the motherboard. If it still does this, then check the memory, maybe the speed is not compatible. If it's not that then try booting up with the old cpu.
Posted on Apr 22, 2007
  • Rona  Heredia
    Rona Heredia Apr 26, 2007
    Blue screen normally has to do with a driver that is not correct for a hardware. Try booting up in safe mode. Press f8 when computer starts up. if you manage to boot up, try removing drivers, maybe video, audio, network card. then try rebooting normally.
    If not then you might need to do a repair of the operating system. you will need an xp cd.
Bios will not load keyboard
you may have a bad keyboard try new one
Jan 27, 2014 | Jetway 939GT4-SLI-G Motherboard
I was wondering if my 939GT4SLI-G can run PCI Express 2.1 x16. Example of a video card would be, MSI R6950 Twin Frozr II OC Radeon HD. Thanks, Rob
This is your board:
http://www.dealtime.com/Jetway-JetWay-939GT4-SLI-G-Socket-939-NVIDIA-nForce4-SLI-ATX-AMD-Motherboard-Retail-939GT4-SLI-G-BRAND-NE/info?sb=1&tab=specs
This is the card you want:
http://www.newegg.com/Product/Product.aspx?Item=N82E16814127575&nm_mc=OTC-RSS&cm_mmc=OTC-RSS-_-Desktop%20Graphics%20%2f%20Video%20Cards-_-MSI-_-N82E16814127575
Some say that the card will work but with limited capacity. I don't see the power requirements for the card but, I would guess a minimum of 350w or greater. Your board definatley was not designed for this card. It's alot of money for a card that may not work at all with your system.
This is MSI's link:
http://us.msi.com/index.php?func=prodvgaspec&maincat_no=130&cat2_no=&cat3_no=&prod_no=2093#menu
There is a "contact us" link at the bottom of the page where you can try to ask them but, in my opinion, for the money, I don't recommend the card without upgrading your system.
Dave
Jul 01, 2011 | Jetway 939GT4-SLI-G Motherboard
Adding 2 gigs memory
try to install windows xP!! when the screen turns blue!! just press f7 until the setup is finnish!!
Jul 12, 2009 | Jetway 939GT4-SLI-G Motherboard
No beep,No Display on my monitor,only CPU heatsink fan is moving
You motherboard has onboard video. It's possible it needs to be disabled and the option changed to use the pci or pci-express slot for the Ati card you installed. Since you have no post error beeps this is the best place to start. Also I had built a system not to long ago and had a similar problem. Resetting the cmos on the motherboard (usually a pin combo) solved the issue.
Start by hooking up your vga cable to the onboard video.
Hope this helps.
Apr 07, 2009 | MSI P7N Diamond Core 2 Quad/ Nforce 780i...
Graphic card heating problem
Cards can over heat but usually not only purchase 2 cards if $ & mobo allow while xfire / sli Graph are great most games are fine on a 512 to 1 gb card anyway and also bdepends on the cpu mobo combo that goes with it
Oct 22, 2008 | Computers & Internet
Help
It will be ok if you are going to be sure that the ordering part# correspond to this table: http://products.amd.com/en-us/downloads/AMD_Opteron_First_Generation_Reference_100707.pdf
Your motherboard maximum Front System Bus is 1000MHz.
Aug 17, 2008 | Jetway 939GT4-SLI-G Motherboard
7F debug code with no video output
do you see a bios screen at all or you just dont receive a signal at all?
Feb 13, 2008 | Jetway 939GT4-SLI-G Motherboard
DRAM Beep
Try to clean the bronze circuit of your VGA card and insert it again, if its the same Your video card is broken, you need to replace..
1 Long beeps means theres an error on your vcard / or theres a problem on it..
3 short beep means thats your RAM have an error or a problem on it..
Once the if the mbord doesnt gives any sign or a beep and seems to be blackout there could be a short circuit on your mbord to the parts with a connection to it...
Feb 02, 2008 | Jetway 939GT4-SLI-G Motherboard
Driver
Welcome To Jetway Home Page.. this company use nForece520LE(MCP65V)chipset motherboard and can not stall RAID disk driver in CD,for ... Example to JETWAY 939GT4- SLI-G mainboard.
You will find the driver on this link, Read follow instructions.
Good Luck, Please dont for get to Vote/Thank You.
Dec 26, 2007 | Jetway 939GT4-SLI-G Motherboard
Problem with mobo upgrade ... From Intel CPU to AMD CPU
hi dale, itsnot a good thing when you see the blue screen of death, cause recent changes hardware normaly maybeif you have changed from intel to amd using mobo and all parts are amd now , maybe if you reinstalled your operating system the new hardware that is installed will accept you software cheers steve good luck
Apr 26, 2007 | Jetway 939GT4-SLI-G Motherboard
Jetway 939GT4-SLI-G Motherboard Logo
338 people viewed this question
Top Jetway Computers & Internet Experts
john smith
Steve Berry
Level 1 Expert
Computer Links
Are you a Jetway Computer and Internet Expert? Answer questions, earn points and help others
