Question about Compaq Presario 5000 PC Desktop
I can not open my disk rewriter please help
Ican not open my disk rewriter on my tower presario 6000 can any one help many thanks uk
  • hairjj2000 Dec 27, 2008
    thanks very much it worked regars john uk
    Brigadier General:
  • 3,614 Answers
  • Most cd drives have a small pin hole located just below the mouth of the cd tray. If your cd rom is black this makes it much harder to notice and easy to miss. I have a picture or cd rom drive on the left. This will give you an idea of where that pin hole is located.
  • Use a small paperclip and insert it into that hole. You use the paperclip to find the lever that pushes the drive open. Usually you'll have to fiddle with finding the exact spot but it's not rocket science. Most cd drives should open if you find the right spot and push in with the paperclip.
  • If for what ever reason the drive does not open. Chances are mechanically the device has a moving part that has seized up and will no longer function normally. In this case It is better to take apart the cd rom with tools as it gives you insight on what part malfunctioned. Sometimes its as easy as a ruber band going out of place. Worse case scenario if it is completely broken cd drives are so cheap you can replace one with ease.
Posted on Dec 27, 2008
I cannot find the website for tower as my pressure cooker is an older but better version. I need valves and seals for it Thank you
Please try these web sites:
http://www.buyspares.co.uk/tower/pressure-cooker-spares/catalogue.pl?path=441256,287905
http://www.cgdomestics.co.uk/index.asp?applianceId=32&brandId=149
http://www.espares.co.uk/search/pressure-cookers/tower/p/1103/753
Jan 16, 2013 | Refrigerators
Compaq Presario 6000 desktop powers-up for 1 second
check your ramm also use s start up disk to check your drive boot sector
Jan 14, 2010 | Computers & Internet
Unable to copy dvd's
Most dell machines do no come with dvd rewriting as standard. They only come with cd rewriting capability. Unless you specifically requested it as an add on to the spec it probably just has the ability to pay dvd's.
Most internet cafe's will have a machine with a dvd rewriter if you really need to copy a dvd
Val
Dec 15, 2008 | Dell Inspiron 6000 Notebook
Tower compaq presario 6000 will not power up
after reading your query i can understand that there may be no issue with the power supply,
can u hear any kind of long beep? if yes try cleaning the ram, if this also doesnt help then try changing the ram.
if this is not helpful please check the cmos battery,
if battery is ok, then there may be a problem with your motherboard of Processor.
Dec 15, 2008 | Compaq Presario 5000 PC Desktop
Help compaq presario 6000 tower will not power upkbvs
By power up , do you mean no lights. no fans,no sounds? If correct then:
 Check 120 volts going into the power supply.  Check  that the power supply switch is on 1 and not 0 If this fails. Change power supply.
Dell 1691p http://www.cheap-laptop-battery.co.uk/dell-1691p.htm
who gave you that link? you won't get it there, try here for your model:
http://www.cheap-laptop-battery.co.uk/dell-inspiron-6000-battery.htm
regards
Nov 22, 2008 | Dell Inspiron 6000 Notebook
Rewriting on Verbatim DVD-RW
when you burn disks you have to choose the option "appendable disk"(or in simple words to create a disk where you can add information -data-later if you wish to do so)
If you just record the data on a cd without this option you will get the error -disk is full-
Oct 04, 2008 | Verbatim (95058) 25 Pack 16x DVD-R Storage...
SST FOR CANON IR 210
Not sure what you are trying to do but try
canon.com (drivers and downloads)
or
driver.com
Aug 14, 2008 | Canon Office Equipment & Supplies
COMPAQ PRESARIO V-6000 LAPTOP WILL NOT TURN ON
try to start the computer and right after that press the delete key several times as it try's see if u can get into the system bios if so change everything to a default level make sure you pres the f10 to save all info and try to reboot if this doesnot work please let me know good luck
Jul 13, 2008 | Compaq Presario 5000 PC Desktop
Front cover
Ca you please tell me what type of PC you have? Compaq, HP, Dell?
Thanks
Jack
Jun 13, 2008 | Compaq Presario 5BW284 (202493-003) PC...
Compaq Presario 5000 PC Desktop Logo
59 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
