Question about Epson Stylus Photo RX500 Printer
Printer errors Every time I try to print I get this Communicaton error, asking if all my devices are connected and they are. How do I get rid of this error so I can print?
    Sergeant:
    Champion:
  • 248 Answers
Go to control panel and delete the printer icon from there. Unplug the printer, restart the computer, when the computer is back on, reconnect the printer... This should automatically create another printer icon in "printers and faxes" ... try printing the windows test page.
Posted on Jun 30, 2008
Error 49.23F9
. Press CANCEL JOB to clear the print job from the printer memory. 2. Turn the printer off, and then turn the printer on. You can try reprinting the job to see if it was a temporary error. 3. If error persists, try printing a job from a different software application. If the alternate job prints, go back to the first application and try printing a different file. (If the message only appears with a certain software application or certainprint job, try upgrading the printer driver and / or firmware.) 4. If the message persists with different software applications and print jobs, disconnect all cables to the printer that connect it to the network or printer. Turn the printer off and delete the print queue. Then reboot printer AND computer, reconnect cables, and try printing again. 6. Remove all EIO devices from the printer (JetDirect cards, hard drives, etc.). If 49 error goes away, turn printer off, re-install EIO devices one at a time, and reboot printer each time to determine which EIO device is failing. 7. If printing still fails with all EIO devices removed, remove all memory DIMMs or third-party DIMMs from the printer. (Do not remove the firmware DIMM-- printer won't function without this installed.) Turn the printer on with DIMMS missing. If the error no longer exists, install each DIMM one at a time, turn printer on, test printer. Replace a DIMM if you determine that it causes the error. 8. Remember to reconnect all cables that connect the printer to the network or computer. 9. If the error persists, replace the firmware DIMM. 10. If error persists, replace the formatter.
Mar 19, 2014 | HP CP3525N Color LaserJet Printer
Laserjet 2605 49 error
Error 49 is a firmware error. Try following these steps:
1. Press CANCEL JOB to clear the print job from the printer memory. 2. Turn the printer off, and then turn the printer on. You can try reprinting the job to see if it was a temporary error. 3. If error persists, try printing a job from a different software application. If the alternate job prints, go back to the first application and try printing a different file. (If the message only appears with a certain software application or certainprint job, try upgrading the printer driver and / or firmware.) 4. If the message persists with different software applications and print jobs, disconnect all cables to the printer that connect it to the network or printer. Turn the printer off and delete the print queue. Then reboot printer AND computer, reconnect cables, and try printing again. 6. Remove all EIO devices from the printer (JetDirect cards, hard drives, etc.). If 49 error goes away, turn printer off, re-install EIO devices one at a time, and reboot printer each time to determine which EIO device is failing. 7. If printing still fails with all EIO devices removed, remove all memory DIMMs or third-party DIMMs from the printer. (Do not remove the firmware DIMM-- printer won't function without this installed.) Turn the printer on with DIMMS missing. If the error no longer exists, install each DIMM one at a time, turn printer on, test printer. Replace a DIMM if you determine that it causes the error. 8. Remember to reconnect all cables that connect the printer to the network or computer. 9. If the error persists, replace the firmware DIMM. 10. If error persists, replace the formatter.
Mar 10, 2014 | HP LaserJet 2605dn Printer
Product assistant
remove printer from the com and then give add device. If still problem exists, connect using USB
Nov 13, 2013 | HP Photosmart C5280 Printer
How solve error 49 on 4730mfp
it's a long one !
Dec 18, 2012 | HP LaserJet 4730mfp All-In-One Printer
4730mfp error 49. turn of and on, but not resolved
Dec 18, 2012 | HP LaserJet 4730x MFP All-In-One Printer
49 error
49 error means firmware error..
solution:
3. If error persists, try printing a job from a different software application. If the alternate job prints, go back to the first application and try printing a different file. (If the message only appears with a certain software application or certain print job, try upgrading the printer driver and / or firmware.)
5. Remove all EIO devices from the printer (Jet Direct cards, hard drives, etc.). If 49 errors goes away, turn printer off, re-install EIO devices one at a time, and reboot printer each time to determine which EIO device is failing.
6. If printing still fails with all EIO devices removed, remove all memory DIMMs or third-party DIMMs from the printer. (Do not remove the firmware DIMM-- printer won't function without this installed.) Turn the printer on with DIMMS missing. If the error no longer exists, install each DIMM one at a time, turn printer on, test printer. Replace a DIMM if you determine that it causes the error.
7. Remember to reconnect all cables that connect the printer to the network or computer.
8. If the error persists, replace the firmware DIMM.
9. If error persists, replace the formatter.
If you need any kind of technical assistance you can contact support cell at http://www.vtechsquad.com/
Dec 11, 2012 | HP LaserJet 3055 All-In-One Printer
Error message 49 on my HP CP 2025 (printer shuts itself off and truns itself back on to see error message 49)
Firmware error:
Nov 22, 2010 | HP Hewlett Packard LaserJet 3000dn Printer
A problem with HP Laserjet 2420
X PRINTER ERROR A firmware error occurred 1. Press CANCEL JOB to clear the print job from the printer memory. 2. Turn the printer off, and then turn the printer on. 3. Try printing a job from a different software application. If the job prints, go back to the first application and try printing a different file. (If the message only appears with a certain software application or print job, contact the software vendor for assistance.) 4. If the message persists with different software applications and print jobs, disconnect all cables to the printer that connect it to the network or printer. 5. Turn the printer off. 6. Remove all memory DIMMs or third-party DIMMs from the printer. (Do not remove the firmware DIMM in the lowest DIMM slot.) 7. Remove all EIO devices from the printer. 8. Turn the printer on. 9. If the error no longer exists, install each DIMM and EIO device one at a time, making sure to turn the printer off and back on as you install each device. 10. Replace a DIMM or EIO device if you determine that it causes the error. 11. Remember to reconnect all cables that connect the printer to the network or computer. 12. If the error persists, replace the firmware DIMM. 13. Replace the formatter. This error is usually caused by a bad formatter board.
Apr 07, 2010 | HP LaserJet 2420dn Printer
Printer has ''internal error''
  • Unplug the printer cable from the computer.
  • Unistall the printer drivers from Device manager and also unistall the all the printer appications
  • restart the computer
  • try to download drivers from the website
  • after installing drivers and software it will ask you to connect the printer.
  • then you can connect the printer and and try to Print the test page.
Hope this help. Please Rate My Response! Thanks!
PREM
Mar 12, 2009 | Samsung ML 2151N Laser Printer
ERROR MESSAGE
But try the following:
Dec 13, 2008 | HP Hewlett Packard LaserJet P3005n Printer
Epson Stylus Photo RX500 Printer Logo
54 people viewed this question
Top Epson Office Equipment & Supplies Experts
Inky Fingers
Inky Fingers
Clive
Clive
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
