Question about Lexmark Office Equipment & Supplies
Wireless Printer communication problem with laptop
I have a new lexmark X4530 wireless printer and have successfully connected it to my wireless router. I installed the software on my pc that the router plugs into with a ethernet cable and the printer works fine wireless. I then installed the software on my laptop and have chosen it as my default printer but the laptop cannot communicate with the printer wireless, although if I connect the usb cable it will print. How can I get my laptop to communicate with the printer wirelessly? I have tried turning off the firewall, and called myself looking at every possible setting that may be the problem. I give up. Can you help?
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 3 Answers
Please check IP, use manual IP for laptop and Printer. may AUTO IP cause this issue.
Posted on Apr 12, 2017
SOURCE: computer will not communicate with printer
Used the cd to install drivers, but am having the same problem... Selphy CP510 will not communicate with computer.
Posted on Jun 18, 2007
SOURCE: Lexmark X5470 printer
I had the same problem when I got vista. First goto lexmark's web site and try to download the vista driver. It did not work for me I had to contact lexmark and they sent me a new driver disc for vista. I have had no problem with it since.
Posted on Dec 04, 2007
SOURCE: Lexmark X 1270 Can not Print
try reinstalling the driver
Posted on Dec 20, 2007
Pterocarpous
  • 202 Answers
SOURCE: Ethernet connection
Hello Becky
There could be a security feature on the printer that requires that you enable the Ethernet port at the printer's control panel 1st. I've seen this w/ printers and All-In-Ones that have a wireless-capable.
HERE is a link to HP's info, downloads, FAQs, etc on this printer.
Depending upon your LAN configuration (on the router), you may need to at least change the subnet mask on the printer if not assign it a static IP so it doesn't conflict w/ any other devices on your LAN using DHCP. (1st, of course, you'll need to get the Ethernet port enabled on the printer)
HERE's the User Guide for your printer. Go to page 29 to find the network configuration instructions.
Please, let us know if this response was helpful for your or, of course, if you have more questions, etc on this topic.
Thank you
BJ
Posted on Apr 04, 2008
SOURCE: Lexmark x5470
I have no CD in order to reinstall the USB device. The machine copies and now prints, but not scans!!
Posted on Sep 18, 2008
I cant get my lexmark x4530 to print from the laptop. Its in the Q and says is printing but it seems like it is stuck. The printer says its ready and the green light is on for wireless!!!! Help
Check "Set as default printer" setting. Log off your user one time and restart the printer. Make sure Bluetooth of your Laptop is turned on.
Jul 28, 2011 | Lexmark X4530 InkJet Printer
My x4530 will not connect to my Airport Extreme
The problem could be caused by several reasons - firewall, signal quality, etc. Maybe this article in the Lexmark website could help: How to identify a Wireless Communication Problem and Resolution Tips.
If problem continues, please don't hesitate to contact Lexmark technical support.
Apr 09, 2011 | Lexmark X4530 InkJet Printer
I installed the Lexmark x4530 and continue to get
Usually a cable is not hooked up or the printer port is not enabled.
If it uses a USB port it should auto detect the port.
If this is the case you will need to download a new driver from the Lexmark site that matches your operating system and install it.
Mar 28, 2010 | Lexmark X1240 All-In-One InkJet Printer
Wireless printer communication unavailable via USB
Hi. Hope you got it working fine now on your Windows 7. If not, go to Start Menu > Devices and Printers > right click on the Lexmark print object > Troubleshoot. Make sure the printer is on and is still connected to the computer via the usb cable.
Mar 12, 2010 | Lexmark Wireless X4850 All-In-One Inkjet...
I just bought a Lexmark X4530 wireless printer. I
try this one. First, make sure there is no print job stuck in the queue. Then, go to start menu > run > type services.msc. make sure that lx?? device and the print spooler are enabled or you can restart both. Hope that helps.
Mar 05, 2010 | Lexmark X4530 InkJet Printer
My printers that are on my wireless network won't print
Did you define the printers and printer ports to the laptops?
On the XP laptop go to network connections in the control panel and use the network setup wizard.
Jan 01, 2010 | NetGear WGR614 Wireless Router
I don't know how to make my Lexmark 4530 print wirelessly. My internet connection is wireless, but I don't know how to get my printer to print wirelessly.
download the installation software from lexmark. You will need to connect it to the computer via a USB cable to run the setup. Just follow the prompts and it will set up the printer on your wireless network. You will run this same software on each additional computer that you want to print to this printer.
Oct 02, 2009 | Lexmark X4530 InkJet Printer
X4530 "communication not available" with laptop
I already experience it ..it becuase of the driver..I think you have 2 or more printer driver installed on your computer right??
you need to uninstall all exisiting driver and install again the printer driver...
and then..
after installing the driver
go to >programs
>printer and faxes
right click the printer icon ..
select used printer as default printer..
and right again..and select >use printer online..
Thank you for using FIXYA..
please a rate ..if it solve your problem..
good luck.
and thank you for choosing lexmark.
May 22, 2009 | Lexmark X4530 InkJet Printer
Lexmark x5490 Right /left cartridge incorrect
If you brought new cartridges and printer detecting it empty ,then you get it
replaced as the Lexmark cartridges comes with a 6 months warranty ..
Good luck....
Feb 13, 2009 | Lexmark X4530 InkJet Printer
113 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
