Question about Acer AL1716 F Monitor
Acer monitor AL1716W 'no signal"
I have the acer AL1716W monitor. It was conected to a gateway computer. I shut it down and when I rebooted, I got the famous Acer no signal message. I tired it on a Dell Dimension 4400 with the same results. I tried it on my Systemax laptop and it works. I unplugged it over night and tried again. No luck. Any other advice?
Thanks
    President:
  • 2,976 Answers
You will need to download the drivers for this monitor. Your laptop already has them installed.
Posted on Jan 02, 2009
My monitor is an Acer 20". model # X203H I am using a MSI MEGA computer which has a VGA connection. My Acer monitor has two connections aVGA and DVI , I am using the VGA connection from the ACER Monitor...
There is both an analog and digital setting on your monitor settings. Bring up the monitor settings and toggle between the digital and analog settings until you get a signal.
Sep 13, 2010 | Acer Computers & Internet
ACER AL1716W no power
Hello Cornloh, Hi! it seems to me that the switching elements are not working, you need to check the Power transistor for shorts, and replace the IC (switching IC, usually IP3842). the easiest is to use an Oscilloscope to read/find the pulsing signal.
Apr 23, 2010 | Acer Computers & Internet
My Acer AL1716W monitor flickers, but only when I'm on the internet.
flickering monitors normally mean the lamp is on its way out but this sounds like your PC has issues either with the graphics card or memory. Run a virus check and antispyware software. If you don't have this software try microsoft security essentials its free. and people tell me its good.
Also try changing graphics card settings like resolution and refresh rate changes it might have something to do with colour schemes. Update graphics card drivers and I recently had a similar issue and had to upgrade the graphics card to handle the resolution of my monitor
Dec 30, 2009 | Acer AL1716WAB LCD Monitor
Screen comes on says Acer then No Signal, and goes out. if shut power off and then back on get same result.
This means the monitor believes it's not connected to the computer. Verify the cables first of all. Then try booting in safe mode (F8 key at PC startup) in order to verify that the PC is sending data to the proper video port (you might have a dual VGA / Digital output, for example, and the monitor might be connected to the wrong PC port). Quite often, a "bad signal" will be the same of "no signal"; and you can have a bad signal if the monitor resolution on the PC is set too high. This could happen if you installed a high-resolution capable monitor, and then replaced it with a not-completely-plug-and-play, lower resolution one. The PC would keep sending hi-res signals to a monitor which can neither interpret them, nor tell the PC "please slow down". To check this last possibility, reboot your computer while the monitor is ON. When PCs reboot, they usually drop back to standard VGA signaling, which all monitors understand. If the monitor abruptly comes to life and displays a boot screen, then goes No Signal again after several seconds, you've got a resolution issue; get in Safe Mode with F8 key at boot, and modify the screen properties (right-mouse button on the desktop, then Properties).
If everything else fails, try also connecting the monitor to another PC or laptop, to see if it works there.
Dec 04, 2009 | Acer AL2223W 22" LCD Monitor
Audio question
No this monitor have no speakers.
May 08, 2009 | Acer AL1716 F Monitor
Input Not Supported On Screen Won't Disappear.
I have a toshiba laptop and for some reason the screen has gone horizontal
Apr 26, 2009 | Acer AL1916W 19" LCD Monitor
No Signal
Not all monitors can display the same resolutions. You may have has the Dell monitor set at something the Acer can not handle. Try rebooting and if you can see the Dell startup screen press F8 as soon as it disappears. This will give you the Windows Startup Options menu, which is text and should display on any monitor. Then select VGA MODE, which is the lowest common denominator for graphics. You should be able to see the Windows display at a much lower resolution (ie, larger fonts and icons) than usual until you can reset your graphics properties to work with the new monitor.
Dec 28, 2008 | Acer AL1912 19" LCD Monitor
Black Screen on ACER LCD 1916 Monitor
see there is power in monitor and check also that your monitor is getting signal from cpu just remove the data vga data cable from cpu and see is it showing any massage on screen like check signal or any other massage. and check your keybord also by pressing num lock key see the light is on and aoff when you pressing the num lock button . if nothing is happen that mean your monitor is not getting signal from cpu and it is not monitor problem . bye
Sep 25, 2007 | Acer AL1916W 19" LCD Monitor
Acer AL1716 F Monitor Logo
358 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
