Question about Akai LCT2701TD Television
RCA Audio Out not working?
I have hooked up stereo RCA cables to my TV's audio out ports and plugged them into my home stereo receiver. The sound continues to come out of the TV's built-in speakers for all sources (cable, DVD, composite, component). Is there a setting I need to change in my menu, or is there something wrong with my TV?
  • 3 more comments
  • Doug McGarvey Apr 22, 2007
    Update: To clarify, I'm not getting any sound of out my stereo. If I plug my devices directly into the stereo's RCA inputs, it works fine, but the TV isn't routing sound through its RCA out. I've even used the same cables to connect devices to my stereo without any problems.
    I was able to find a picture of the outputs in question in an ebay listing for this model of TV. RCA audio out is also listed in the manual and on the side of the box, so I'm surprised there's no reference to it in specs found online...
  • Doug McGarvey Apr 23, 2007
    That's what I was afraid of... not sure I want to open up the cover just to fix the audio out, since I can always go the switchbox route and use an external DVD player. It would just be more convenient to use the features the TV was supposed to have in the first place ;)
    Thanks for all your help, I really appreciate the effort you put into researching this for me. If I do decide to take a look inside the casing, I'll let you know what I find, if anything.
  • Anonymous Mar 19, 2014
    I need sound from stereo speakers
  • Anonymous Mar 28, 2014
    I just hook up a rca sound bar to my hisense tv using red and white audio cable and I don't have any sound coming out of the sound bar, what am I doing wrong.
  • 247 Answers
You don't say whether you're successfully getting sound out of your stereo or not. I'll assume for the moment you are. Still getting sound out the TV is perfectly normal - RCA plugs have no mechanism for automatically disconnecting the built in speakers (in this respect, they're different from a headphone socket). Solution should simply be to press the mute button on the TV remote - although this will silence the TV speakers, you wouldn't normally expect it to affect the RCA output (failing that, just turn the TV volume control right down). A.
Posted on Apr 22, 2007
  • Alastair Macleod
    Alastair Macleod Apr 22, 2007
    This is all looking a bit odd. Checking on the net at specs for your machine, I can't find any mention at all of an audio output to RCA sockets. All they talk about are inputs.
    It might be worth just double-checking the labelling on the sockets to make sure they genuinely are outputs.
  • Alastair Macleod
    I guess this goes to show that you can't always trust an internet retailer's spec sheet. Sorry I doubted you.
    Having another stab at the question in the light of what we've got now: I can't see any point in having a menu option to enable/disable the RCA out, so I don't think Akai (who aren't idiots) would have gone to the expense and trouble of building in such an option.
    On the whole, I think this next paragraph is a long shot - though I'll stick it in just in case. I have seen one piece of kit which had a single pair of audio RCA sockets which could be switched to act as either input or output. This wasn't a TV, and I believe they did it because they were really short of space on the back panel. I've never seen anyone else try to pull that stunt, and I can't think of any reason why Akai would want to try it on something the size of a 27" TV. If by any chance they are dual purpose sockets (and there's no hint of it in the labelling), I would expect the changeover to be done with a mechanical switch, rather than through the menus.
    In the end, this probably means that the RCA outputs on the TV aren't working like they ought to. It might be worth slipping the cover off and having a quick look - if you're lucky, it may just be that the cable loom to the RCA sockets has become unplugged from the circuit card.
    With a normal TV, a reasonable workround would be to route all your inputs through a switchbox and connect both your TV and Stereo to the output of that. Unfortunately, having the DVD integral to the TV is going to spoil that option for you.
    Conscious this isn't going awfully well.
    A.
SOURCE:
How can I make a NEC Plasma Monitor that was given to me work like a TV that has AUDIO?
If it has no internal sound, then you obviously can't make it function like a TV aside from the picture right? It does have inputs whether HDMI or standard Cable wiring to see TV from a cable box?
You'd need to have RCA cables coming from the cable box (Audio out - white wire I'd figure) going into a stereo near the monitor that has a VIDEO button on it where the white RCA cable is plugged into the Audio In jack.
A stereo receiver or even old sort of stereo with a Video or Auxillary sort of jack with button to activate that jack will allow for surround sound from the stereo coming from the cable box in sync with the video of the TV.
Feb 08, 2015 | NEC PlasmaSync PX-42VP5A 42 in. HDTV-Ready...
No right channel on AV2
First, does TV sound without external sources work on both channels?
With the one RCA connected and getting sound, unplug it and plug into other channel. Any sound? If not, remove it and plug the other RCA by itself into the left channel. Sound? If yes, plug it into the right channel. No sound? If not, bad TV input.
If you do get sound on that other channel with a single RCA, then you have either a bad cable or bad source. Reverse RCA's on source and try same test, plugging each RCA into each input on TV one at a time.
If the TV is bad, you will get sound on just the left channel regardless of which RCA you use.
Dec 16, 2013 | Blaupunkt Car Audio & Video
I can get picture with hdmi connected but no sound. Do i have to connect the optical digital audio cable from PC to TV to get sound? Actually the video and sound go to stereo receiver first, video passes...
If your video card supports audio over hdmi in that case you need to find the s/pdif port on you motherboard and the port on your video card (usually right next to and sli or xfire bridge) then you can send the sound thru the hdmi. if not you will have to connect your optical audio cable or a 3.5mm audio out to rca left and right out to your receiver for audio. what video card and mother board are you using? if you know this i can tell you exactly where the ports are for the spdif cable to video card and mobo.
Mar 15, 2011 | Computers & Internet
I wanted to know if there is a way to hook up the sound from a Panasonic DMP-BD655P-K Blu-Ray player to my existing Yamaha DVX C310SW home theater system. I know I can hook the Blu Ray directly to the TV...
Yes this can be done. You have several options for audio hookup. Stereo 2-channel (white and red) RCA cables, digital audio (optical or coaxial) or HDMI. Your home theater must have the inputs available such as optical, coaxial etc. Typically the stereo 2-channel RCA is the simple way. Just connect from the Bluray audio outputs to the Home theater inputs (white and red) for stereo sound. Select the input on the home theater. For Dolby Digital 5.1 use optical digital audio cable (black port) or coaxial (orange RCA port) from Bluray to similar home theater input.
Mar 06, 2011 | Yamaha Audio Players & Recorders
Please help. Hooked up Toshiba Satellite to l40fhd41 RCA using VGA cord and video shows up on PC channel of TV. My problem is the sound. Trying to get sound to TV using earphone port on Laptop with...
If you look real close at the VGA port on the TV, you will see a small mini phone jack 'AUDIO' that is for attaching the audio cable with mini stereo phone plug at both ends, one end is to the TV PC audio input jack, another end goes to the PC AUDIO line out or headphone out.
Dec 31, 2010 | RCA L40FHD41 40. in HDTV
I have an lg lcd mod#lc427d hdtv how do i hook up an rca rt2280 system to it. i have a dvd player hooked up to tv now using hdmi cables, rca av reciever does not have them...
You can check your dvd player for a coaxial or an optical sound output, then you can plug it directly to your receiver. Those two are the best options after HDMI. Another option is A/V RCA type cable, you´ll need 3 stereo A/V wires, in order to connect the 6 channels. Remember to uncheck the HDMI sound output option on the DVD menu.
Nov 14, 2009 | RCA RT2280 System
Hooked up to sony bravia 52" tv and can barely hear sound
You'll want to turn of the TV speakers in the Remote Menu and try turning up the volume level of the TV, which usually controls the level of the RCA outputs, as well
Feb 02, 2018 | Yamaha RX-V596 Receiver
Sound hook up
if u have a pair of rca connectors, connect audio out of your dvd dvd receiver to audio in of your tv. they are usually red and white,, for right and left speaker.
Nov 05, 2008 | Kenwood HTB-204 System
Setting up the TV with our stereo
Sure. On back of DVD player find 'audio out" left and right.
Obtain a twin RCA jack audio cable of sufficient length and put
the two plugs on one end into those audio ports, and plug
the color matching ends into any available" audio in" left/right
ports (except "phono") on your receiver. Done.
For the TV sound use the same kind of twin cable, and obtain
the sound source from audio out left/right on the back of your
cable or satellite provider box and find one additional set
of available "audio in" left/right ports on your receiver. Done.
Turn the receiver dial to correspond to the audio port that
you selected on the back and enjoy it.
If you don't have a separate cable or satellite box chances
are your TV will have audio out left/right ports in the back
or front somewhere and use those to route your TV sound,
but if you do that don't expect the sound quality to be
top notch (depending on the TV circuitry ).
If you have only one unused audio in left right pair available
on your receiver you will need to use an "A/B" audio
switch, and your local electronic store can tell you how to
use it.
You are doing the right thing. The sound should be much
improved by using your receiver. And by the way, when the
sales person in the store suggests that you need gold plated
jacks ignore him and buy the plastic ones. They will work
just fine.
Good luck.
Jan 04, 2008 | Emerson EWL20D6 Television
Audio output not working
I had what may have been a similar problem and even talked to Westinghouse to see what I was doing wrong. Woman suggested there was a problem with the audio output port and suggested I exchange tv for another one. When the new one had the same problem, I discovered that to get audio out requires the volume to be turned way up on the tv (set speaker preference to external only if you don't want sound from tv speakers as well). If you have a digital optical connection on both the tv and the home theater, the sound output is independent from the tv setting and is easier to work with.
Oct 04, 2007 | Westinghouse LTV-32w4 32.02 in. LCD HDTV
Televison & Video Logo
236 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
