Question about Body Glove Earglove Bluevoice Bluetooth Headset (7810001) Headset
Need a charger for Fellowes Earglove Bluevoice/Bluetooth Headset
Good Day - Might you know where I can buy or order a charger/adapter for a Fellowes Earglove Bluevoice/Bluetooth headset? Any information you could provide, including a parts number would be greatly appreciated. Thank you and Happy New Year! Regards, Nina
Blueparott B250XT Charger Specs
9vdc positive tip. Road King RPDC-812 available at most truck stops work great it's a universal dc adapter and the orange end fits the 250xt. Price $15 at Love's.
May 01, 2012 | VXI Corporation Blueparrott B250-XT...
The headset will not charge from the base unit
It maybe that you need a new charger for your base. If your base is messed up there is no replacement for that. I know you can purchase other product for the base but not the base itself.
Here is a link to the Plantronics 510S Headset.
Good luck from Headsets Direct!
Mar 14, 2011 | Plantronics Voyager 500A Deskphone Adapter...
How to us a bluetooth headset to pone
  1. Link it to your cell phone. Cell phones can be easy, but nothing is easier than keeping it in your pocket when you talk. Use a Bluetooth headset to have a hands free conversation. They are typically worn over the ear, and can be used without charging for one to four hours.
  2. Use a Bluetooth headset with your PC. You will probably need an adapter to link up your headset with your PC, and they are placed in a vacant USB port in your computer. It enables your PC to communicate with and through the headset.
  3. Pair your Bluetooth headset with your PC in order to use it for VoIP applications. You must set your headset to the discovery option and allow your computer to roam and link with the headset.
  4. Keep it charged. In order to get the most life out of your headset, keep it charged when you aren't using it. This will ensure that it is ready whenever you need it. Use the standard house charger at home, and buy a car charger for traveling.
  5. Adjust the volume. Make it easy on your ears by lowering the volume to a level that is comfortable. When you choose a setting that is too loud you can hurt the ear drum and if you set it too low you may strain to hear the other person.
jQuery('.article ol .image').each(function(i,e){ var $this = jQuery(this); $this.find('img').error(function(){ jQuery(this).remove(); $this.remove(); }); });
Feb 03, 2011 | Itech i.Tech i.Oval 303 Bluetooth Headset
Loss of charger for Jabra BT 200
hello,buy travel charger BT200/BT250/BT250V and you will have your bluetooth headset charging back.
Take care.
Apr 10, 2010 | Jabra FreeSpeak BT200 Consumer Headset
Volume trouble
The top button on the control surface, the one with the green flashing LED, is the volume control. When the unit is "ON" pushing the button up or down raises or lowers the volume, simple. When you connect it to the charger that same green light will turn red while charging. If you push the top button forward (up) at the same time you press the lower button (power) the LED will flash 1-3 times. Three flashes is fully charged and one means it's getting low.
This is a great head set. I just sat on mine and broke the ear piece. I'm looking for another as we speak! It's worth more than it's current retail price by far!!!
Jan 27, 2009 | Body Glove Earglove Bluevoice Bluetooth...
Earglove sport stereo headphones with palm centro
Ya must be a centro thing , i was reading on another fourm that www.softick.com audio gateway is the solution for bluetooth headphones butt im not sure about wired.
Jan 15, 2008 | Body Glove Earglove Sport Headset for...
Not sure if Jabra bluetooth headset or charger that not working
I had the same problem, called support, they told me battery is defective or too old and doesn't accept the charge. Battery in a headset is hardwired and can't be replaced, so the whole thing is trash :(
May 26, 2007 | Jabra BT250 Consumer Headset
Mobile phone
here is the link for the user manual for your phone if you need it; http://www.sagem-online.com/icssb2c/resetSession.do;jsessionid=ID1619250804DB0.7118802035810661End;sapj2ee_*=1619250804?Standalone=yes&uilanguage=EN&country=fr I couldn't find a solution in there but you may have more luck - it is a big document. Please post again if not :)
Apr 22, 2007 | Body Glove Fellowes Earglove Mobile Phone...
Body Glove Earglove Bluevoice Bluetooth Headset (7810001) Headset Logo
359 people viewed this question
Top Body Glove Radio Communications Experts
eradiostore
eradiostore
Marvin
Marvin
Are you a Body Glove Radio Communication Expert? Answer questions, earn points and help others
