Question about Sony Uncharted: Drake's Fortune
The sanctuary wen getting to the four statue, iv turned them around facing eachother away from eachother tried everything, but nothing happens im so stuck
  • 903 Answers
Hit "Select" to check the journal entry, then use that to line the statues up. Each statue corresponds to a a Gospel - Matthew, Mark, Luke, and John. Figure out which statue is which, then use the compass painted on the floor to point them in the right direction. Each statue has to face a certain direction (north, south, east or west), and when they're all properly aligned a door will open.
got this from gamefaq
hope it helps
Posted on Dec 30, 2008
Cannot pick up the statue in the rotating room for Mystery of the Mummy..level 3. I can get into the next room and solve the water puzzle and get the chess board but I can't solve that puzzle because I...
I found this walkthrough for the DS version By: perseaphone@yahoo.comHopefully it will work for pc as wellTo help keep yourself oriented in here: there are a total of 4 statues. Two on eachside that face each other. On one side you will see that the statue closest to the door has a crooked staff in hand and the other statue has a spear. The opposite wall has the statue with the spear closest to the door and the other statue holding the crooked staff in the back. Click on the center of the room until you are facing two of the statues and can reach them. Click on each statue once. Turn and click on the center of the room until you are facing the other two statues and can reach them. Click on each of these statues once. A panel in the floor next to the door you came in should pop open if you did it right and you need to work your way back there and pick up the STATUE. Click on the center of the room until you are in the center again. Your objective is to now reach the door opposite the one you came in. *NOTE: I found that once I got to the center of the room and then clicking towards the statues OPPOSITE the door I really wanted to go to, I was able to get to the door I needed.
Mar 21, 2011 | DreamCatcher Interactive Sherlock Holmes...
Wen i installed my new logitech webcam 300. everything installed properly. but wen i use the camera a whole bunch of white lines run up and down the screen. verticle lines. ive tried changing settings, but...
Try to rotate the web camera lens adjustment knob. It controls the images quality of the camera. It is located in the front face of the cam. But if nothing happens right then take your camera back from the store you bought it.
Dec 23, 2009 | Logitech Webcam
I dont understand the 4 statues they're facing the right way when i come to that part am i doing something wrong ? an when i do get statues in the right place where do i go then? i have been stuck on this...
If you look on the floor you will see where north, east, south and west is facing. If you check your journal, each statue will need to face the correct direction. Just match what the journal says to the compass on the floor.
Jul 12, 2009 | Sony Uncharted: Drake's Fortune
Which way do the statues face inward or outward
There is a compass on the floor. Match the direction of the statue to what the journal says. The direction of each statue is written in the journal.
Jun 27, 2009 | Sony Uncharted: Drake's Fortune
Honda x8rx will not pull away
your cars needs cleaning and you need a new spark plug.
Mar 26, 2009 | 2003 Honda XR 400R
Yomb raider underworld
SHIVA/KALI STATUE COURTYARD – MOVABLE STATUES WITH FANS: Approach the 2 small statues of Thai dancers holding fans. You'll notice these are set on tracks in the floor, enabling them to move. Face the big Shiva/Kali statue to get oriented and then go to the dancer statue on the right. Press Interact to grab it. Slide it along the straight track to the left. Then push it clockwise along the circular track, almost all the way back to the straight track. When it reaches the correct spot, the beam of light shining from the gem in Shiva's hand reflects off the fan the small statue is holding.
Now go to the statue on the left. Take hold of it and push it counterclockwise along the circular track all the way around to the straight track. Then slide it to the left all the way across the straight track. Finally push it forward (clockwise) just a little bit along the circular track until the sunbeam from the gem above reflects off the fan. (The diagram at right shows the sequence.)
When the statues are positioned correctly, the two beams of light strike the Kali statue and the floor opens up, revealing a doorway.moz-screenshot.jpgmoz-screenshot-1.jpg
Mar 12, 2009 | Eidos Interactive Tomb Raider Underworld
Turning the 4 statues, which way do each face?
Hit "Select" to check the journal entry, then use that to line the statues up. Each statue corresponds to a Gospel - Matthew, Mark, Luke, and John. Figure out which statue is which, then use the compass painted on the floor to point them in the right direction. Each statue has to face a certain direction (north, south, east or west), and when they're all properly aligned a door will open.
I got this from gamefaq
I hope it helps
Dec 30, 2008 | Sony Uncharted: Drake's Fortune
Start up trouble
when you press ON button try to press the eject button of the cd-rom drive. last night we have the same problem.
Apr 09, 2008 | HP Compaq nx5000 Notebook
Red Lights, Sounds and scratching discs
Allright the four red lights is an over heating error that MS could have taken care of. When you moved the system from being layed down to standing up if the CD was still moving you probably scratched and or broke your game inside the system. This is not covered under there warranty you will probably be stuck with a bill from MS for around 140$. sorry I hope this helps.
Jan 04, 2008 | Microsoft Xbox 360 Console
Sony Uncharted: Drake's Fortune Logo
207 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
