Water does not spray or drain properly
If the water in your dishwasher does not spray or drain properly, there are a number of things you can do. Start by giving your dishwasher a thorough cleaning and see if that helps. See How to clean a dishwasher for step-by-step instructions.
Next, consult the owner's manual for simple instructions on how to access and clean your dishwasher's filter.
Look where the dishwasher drain hose snakes through from one cabinet to the other. Does the hose look flattened or kinked? Do you see any sharp bends? If so, straighten out the hose with your hands and manipulate it so that it regains its rounded shape.
If your dishwasher drains through the garbage disposal, try running the garbage disposal for a bit to process and clear any food.
Does your dishwasher spray your dishes, but it does not advance to the next stage and drain the dirty water? The timer controls the start of the draining process. You may need an entirely new timer or a new motor for the timer. Repair service is recommended.
If you hear a humming or grinding noise, that's an indication that bits of glass, broken dish pieces, beans or seeds may be caught in the pump impeller.
For more troubleshooting steps and solutions, see Dishwasher not draining. I hope this helps!
Hi
If you
are noticing that the dishes are not clean, then there are a few things to
check for. Check the soap powder if it's kept in a dry environment. Also try
replacing the powder with something like a gel or liquid. Next thing to check
for is the water pressure and fill valve. Check if the water is filling in and
the spray arms are throwing the water with enough pressure. Try and listen to
the sound if you hear a proper spraying action sound.
If it
seems as a low water pressure then check the fill valve. Now, check if
dishwasher is draining the water or not. While the dishwasher is working check
whether the dishwasher is draining and there is not much left out water after
the cycle is complete. Try cleaning the spray arm with a soft brush. The water
temperature plays a major role in cleaning of dishes. The temp should be
between 125 and 150 F for dishwasher to clean the dishes.
Hope
this helps... Please post back if you need more information.
Daniel
