Question about HP Pavillion dv9740us Notebook
Dv9500: my screen is split into 4 mini screens
My screen is split into four mini screens, making it impossible to read what is written. it reaches the hp icon then to area where can start choose your start up mode. but does not boot any further.
  • Anonymous Feb 18, 2009
    same
  • Anonymous Apr 20, 2009
    I have the same symptoms. I am considering purchasing a replacement motherboard, but i am concerned that it will be subject to the same problem. When diassembling the laptop, I noticed that the screw closest to the video adapter area had been installed crooked, I am curious if this has to do with the problem.
How to replace I pad 2 broken screen
Is the screen broken or is it just the digitiser? There are many excellent videos available which take you through the process of replacing all parts of your iPad.
However, it is not something that can be fixed easily and you need to exercise great patience in dismantling your broken iPad and replacing the damaged parts.
Make sure you have plenty of space in which to work and place all the parts of the iPad around your working area so they are easy to reach.
Good Luck.
Mar 01, 2015 | Apple iPad 2
Vizio tv to split screen for security cams
The split screen view comes from the recorder. If you have no recorder then you'll need to invest in what called a Quad to view all four cameras at once.
Jan 14, 2014 | Vizio E420VA 42 in. LCD HDTV
4 year old vizio 42 inch tv lcd. While watching tv, the screen started dimming. There is a 4 inch shadow all along left side of the screen and the 1 inch line shadow going down the middle of the screen.
Maybe a power supply or related issue but at 4 years of age the set has reached its life span----parts will be hard or impossible to find.
If you got four years I would retire it and recycle it and then replace it.
May 14, 2012 | Televison & Video
I have split screen. When I turn my laptop on, the screen is divided into four and the hp sign is very faint in all four screens.
after doing some research, this laptop has a history of this happening, the only suggestion i read that seemed applicable is to try a system restore. i know this really doesn't help the problem as it's like curing the disease by killing the patient, but i'm not sure what else to try
If you need further help, reach me via phone at https://www.6ya.com/expert/joel_63c670a84e9f6a97
Nov 27, 2011 | HP Pavilion dv9000t Notebook
My screen for the video and words is very small on the you tube page
You can make the youtube screen in full screen by clicking the 4 arrow like pointing on four directions icon. That can be found on the lower right just below the video screen. Making the screen full would definitely increase the readability of the words you want to read.
Sep 02, 2011 | YouTube Computers & Internet
Hello, My HP dv9000's screen has split into four horizontal parts. They are all slightly yellowish and it is almost impossible to read anything in them. Please can you help?
I suppose you must have a Nvidia Graphic card in your laptop....
This is a very common problem with nVidia geforce 8400 and 8600 cards.
Serach google with this "Defective Nvidia geforce card" and you will see lots of user facing same problem in HP, Dell etc..
I too have an Hp laptop with nvidia geforce 8400. I have faced similar problems(screen got divided into 8 parts) in past for 3 times. Every time I have to replace my motherboard at HP service center.... It is caused by overheating of laptop that destroys the nvidia graphic card.
Go to the service Center and ask for a motherboard replacement.
hope this will help.....
Sep 26, 2010 | HP Pavilion dv9000z Notebook
Blinking mini notebook screen
Your notebook/mini is designed to power down the screen if your battery begins to lose charge, and this may be considered normal until the battery is recharged.
Try replugging the power then press the power button to take it out of standby mode. If it still hangs on the blinking light, you may need to update the bios or change your power settings in bios to either S1 or S3 and see if that changes anything.
Mar 09, 2010 | Dell Inspiron Mini 10 Notebook
HP Pavillion DV9500 laptop with rainbow of lines on screen
Yes There are several layers that can crack and you may not feel it on the surface
Apr 29, 2009 | HP Pavilion DV9500T Notebook
HP Pavillion dv9740us Notebook Logo
642 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
