Question about Samsung ML 1710 Laser Printer
Paper scrolling i have a ml 1710 laser printer. it seems as if the printer all of a sudden is having trouble getting the paper from the drawer into the printer. it goes round and round...sounds like it's trying to turn and pick up the paper, but some how can't feed it through the printer. there are even marks on the end of the paper where the 'turning device' has tried to grab on. i tried putting more paper in, then taking some out to see if the level of paper made a difference. nothing has helped. any ideas? thanks.
  • Anonymous Mar 18, 2014
    MY PRINTER TURNS ON AND YOUR CAN HEAR THE PAPER FEED SET BUT THERE IS NO DISPLAY NO MATTER WHAT BOTTON I PUSH. HOW DO I SOLVE THIS PROBLEM. I EVEN TRIED PLUGGING INTO MY COMPUTER NOTHING.
  • Anonymous Mar 23, 2014
    Paper won't feed jus grabs and goes in a little bit then says error again out of paper
    New Friend:
  • 12 Answers
Sometimes there is a spring in the paper tray which pushes the paper upwards so it presses against the rubber roller in the body which pulls the paper into the printer. If this spring has become dislodged or similar, it won't push the paper up with enough force for it to work. Also, somethimes in an older printer or one which has seen much use, the rubber roller can become deformed, causing a similar problem. This one is much harder to fix because spare parts are usually either not available or extortionately priced!
Posted on May 31, 2007
Samsung 1710 stops before printing
to fix the problem you have to press the plate that the paper sits on down until it clicks into place once you do that it should work fine.
Oct 29, 2007 | Samsung ML 1710 Laser Printer
Samsung ml 1710 printer pickup more then two or three paper at one time
plz make it sure that the paper are not damp. if the paper is ok then your printer needs servcing
Aug 02, 2010 | Samsung ML 1710 Laser Printer
Online error light nothing prints
I have a ML 1710 .Not my area of expertise but I took out the paper and could not see a jam. Took toner out , a little cleaning, plugged and unplugged from computer several times. I found paper jammed in the very back ,folded so tight nothing was showing. Mine has a back door and the paper is having trouble rounding the last bend and coming out. So I leave the back door open to get my copies. Green light on.
Feb 26, 2010 | Samsung ML 2010 Laser Printer
My samsung 1710 laser printer is not printing every page. It sometimes doesn't feed the paper through or misfeeds
you need to clean the feed rollers with rubbing alcohol or have them replaced...
I’m happy to assist further over the phone at https://www.6ya.com/expert/norman_d2fa496dce30c65d
Dec 22, 2009 | Samsung ML 1710 Laser Printer
ML-1710 Printer won't print
Our printer at work does this and I found that a piece of paper was stuck under the rollers. As soon as I removed it the paper went through. Another problem could be that you may need to FAN the paper and make sure the other side is feeding in first. Hope this help
Mar 20, 2009 | Samsung ML 1710 Laser Printer
Paper jam
You could try cleaning the tires if you can get to them and check to see if there isn't any paper stuck in the paper path.
Jun 11, 2008 | Samsung ML 1710 Laser Printer
Samsung ML 1710 Laser Printer, over active feeding
sounds like there's something in the print queue..disconnect it from the computer, and try it again.
Feb 19, 2008 | Samsung ML 1710 Laser Printer
Samsung ML 1710 Laser Printer Logo
145 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
