Question about Universal Battery Charger Charges Multiple Combination
Charger need a charger for canon 8mm video camcorder model UC-V200
  • declanhiggin Dec 27, 2008
    have film canot watch
  • 120 Answers
Next to the jack on the camcorder it should have a diagram that shows polarity (a + and - sign) for the plug, the tip should be one sign and barrel or outside of the plug should show the other polarity. you have to have your plug with the correct polarity, and you have to have the correct voltage( it should say 9v or 12v or something like that) and the supply you use should be as high or higher of a current rateing as recommended in your users manual or printed on the supple that came with it.
Posted on Jan 10, 2009
Does theCanon UC-X2 camcorder play 8mm tapes?
Hi-8 camcorders might be backward-compatible for playing tapes. I bought a model which could be switched between the two modes - Sony DCR-TRV355E.
Jan 31, 2014 | Canon ES400V Camcorder
WHERE CAN I BUY THE CASSETE
Video Only, and Best Buy will most likely have 8mm tapes. Walgreens and Radio Shack should also carry them. If the only tapes you can find are labeled Hi8 or DV8, you can still record on them with an 8mm camcorder.
May 16, 2011 | Canon ES50 8mm Camcorder
When I connect the battery charger to the camcorder it doesnt even even show that I have the battery charger hooked up nor does it charge the camera. Could that be a problem with the camera or the charger?
I got hold of Canon support. I had the same problem. Got a new battery, fully charged and would not run the unit. Canon told me to do a system reset. pull out main battery and aux battery (bottom of unit) and to power switch to aux for 90 seconds. the put batteries back and it should work. Hope this helps.
Nov 05, 2010 | Canon ES50 8mm Camcorder
Canon uc-1 video 8mm camcorder
Yes it can be fixed, but Canon is not the easiest to work on. Is the connector loose at all? The audio head may be dirty. This is not on the spinning heads. If you look inside and locate the pinch roller (rubber roller), there should be a silver head that looks like a cassette tape head. Try cleaning that using a cotton swab and alcohol. See if that resolves the problem.
Keep us posted.
Dan
Jul 23, 2008 | RCA 8MM VIDEO HEAD CLEANER (WET) 8mm Tape
Canon UC1 8mm video camcorder
No solution..... but eager to know where one can get the battery packs and charger fir this camcorder (UC1) A 8 mm videotape is stuck within the camera housing and can not be ejected...No battery and charger available..
Where are those battery packs available f.i." SUNPAK RB-E77MF 6V 1700 mA ??
I would highly appreciate your advice
Thanks in advance
J.van Bochove
e-mail: jvbochove@onenet.an
Jan 05, 2008 | RCA 8MM VIDEO HEAD CLEANER (WET) 8mm Tape
8mm/Hi8/Digital 8
As this was quite some time ago, you probably already have your solution, but I just ran across this. Just in case you can use any other 8mm camcorder or deck if you can find one. Also if you still had it I would like to buy the Instruction manual from that old Canon ES780. Please write me back at bpgray@verizon.net if you have it. Thanks.
Dec 14, 2007 | Canon ES870 8mm Analog Camcorder
Universal Battery Charger Charges Multiple Combination Logo
103 people viewed this question
Top Universal Electronics - Others Experts
Are you an Universal Electronics - Other Expert? Answer questions, earn points and help others
