Question about RCA P60921 60" Rear Projection Television
Projection tv no picture has sound - RCA P60921 60" Rear Projection Television
  • Anonymous Feb 22, 2008
    sony 61" rear projection tv has sound but no picture.notice some color bars at the top and bottom of screen
  • vjohns Aug 25, 2008
    I have a Zenith 60 in. Rear Projection Television, no picture but everything else works. The model is A56M91w9 and I was told it uses part 9-1978 to fix this. Is this right?
Hitachi rear projection tv's color is not in the lines. The yellow and the blue are floating at the top and the bottom of the screen. The problem started slowly a couple of days ago.
Posted on Jun 27, 2008
IS THE PIECE RIGHT IN THE CENTER OF THE TELEVISION. IN A LITTLE OPENING
Posted on Feb 20, 2008
  • BOOKIE69 Feb 20, 2008
    where can i get the part for the television
Thank you i will deffintely try that your explanation was great
Posted on Jan 31, 2008
  • 41 Answers
At the rear of unit remove cover and right near the center above the main chassis is a small pcb with a aluminum heat sink and an IC attached to it, usually a STK-730-150, replace it. One screw holds the board in, is easily removed for chip replacement.
Posted on Jun 29, 2007
SOURCE:
Why no sound On Samsung HLR5087 Projection TV?
Either your tuner is bad, coaxial is not plugged in all the way, or your box is bad.
Dec 29, 2012 | Samsung HLR5087W 50" Rear Projection HDTV
Hi, our toshiba rear projection tv will turn on but no picture. whats the problem? thanks
MODEL NUMBER 56H80 TOSHIBA PROJECTOIN TV,PICTURE IS NOT COMING AT ALL
WHATS THE PROBLEM
Feb 04, 2011 | Toshiba 57H81 57" Rear Projection...
Hitachi tv no picture or sound.
my hitachi projection tv 53uwx10b screen is black with no sound or picture when the power button is on
Dec 29, 2009 | Hitachi 53UWX10B 53" Rear Projection...
65" toshiba projection tv no picture but has sound..
if you could hear only sound in tv and not picture means it might be the picture tube problem just check it.
Sep 17, 2009 | Toshiba 55H70 55" Rear Projection...
Pop sound and now no picture or sound still gets power
Try disconnecting all the cables from the TV then reconnect them after a few minutes. It's suggested that you connect the power cable from the TV directly to a functional wall outlet.
If still there is no picture on the TV then it's required to replace the projection lamp.
Sep 08, 2009 | Toshiba 57H81 57" Rear Projection...
Akai 54' projection tv picture no sound
U obviously don't have all ur sund cables connected right or if ur running it through ur sound system put it on phono
Mar 05, 2009 | Akai PTH5498 54" Rear Projection...
TV won't turn on.
Samsung Projection TV Model # is PCK5315R. It displays a light on the "timer" indicator on front of the TV but the TV doesn't respond, no picture or sound.
Mar 02, 2008 | RCA HD52W56 52" Rear Projection HDTV
No picture or sound
sounds like the PTV Small Signal Board.
Jul 22, 2007 | Philips 60P8341 60" Rear Projection...
RCA P60921 60" Rear Projection Television Logo
120 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
