I have a winfast 761GXK8MC motherboard. I am using a athlon 2800 CPU, and a SATA hard drive. when I install windows 98 it keeps locking up. then it says "child devices are keeping it from fully starting up" I shut it down and restart in safe mode. if I go to file system properties in the system (Control Panel) and (disable all 32 bit protected mode disk drivers) this is the only way it will boot correctly. but I lose my cd drives it does not even recognize them and I cannot install anything else is there an update for this and how can i install them if i cannot use the cd drives.
    Genius:
  • 1,066 Answers
I doubt sata technology is supported by windows 98, you need to use windows 2000 at least. microsoft, unfortunately, does not support windows 98 anymore. the only other option is for you to check on your motherboard's manufacturer's website for windows 98 drivers. you could also try ide cd drives.
Posted on Dec 29, 2008
MSI 760Gm-p23 version 3 Fx Desktop athlon II 640 cpu ,deskstar 500 gig 7200 3.5" sata II 16 MB cache hdd, mushkin 8 gig pc3-10600 essential ram, LG L49-8020 oem sata dvd rom post no issue but wont boo
make sure that the cables are right and are good make sure that the power cables are in the dvd and hard drive two cables to each one for board and one to power supply each
Mar 06, 2013 | MSI 760Gm-p23 Fx Desktop Motherboard Amd...
My desktop computer keeps freezing about 3-5 mins into start up with windows 7 ultimate 32 bit. I attempted to install windows 7 pro 64 bit, formatted the hard drive, then started to install and my...
a custom built computer check every connection a computer needs current and data to travel up to and through every device for a computer to work properly
check the cmos battery make sure the seat is cleam this will apply to the ram as well make sure the sockets are clean and they are seated securely
what sort of ide connections are they do you mean molex power connections?
make sure the leads from motherboard to hard drive sata and electrical are securely seated also check all of the connections to drives cd/dvd floppy and usb
hope this helps
Jun 29, 2011 | HP Computers & Internet
Motherboard and cpu upgrade
Your hard drives are not setup for that mobo run the windows cd again/safe boot if you can (via f8) but do not format just install
Jan 03, 2009 | Computers & Internet
Motherboard
Windows 98 does not support SATA very well, the technology did not exist when the OS was created. Change to Windows XP and you will find it works well.
Dec 27, 2008 | Foxconn Computers & Internet
Compatible CPU
check the winfast website for a cpu support list for your model of motherboard, that will tell you if it supports it and ALSO if you need to update the bios to support later cpu's, i'd imagine your using the old socket A standard, see if your motherboard is listed here> http://www.leadtek.com/eng/mainboard/default.asp?lineid=3&seriesid=23&chipseriesid=15 (this is what is now listed in google as winfast and does show winfast boards), please advise if you get stuck anymore.
Sep 22, 2008 | Foxconn WinFast K7S741MG Motherboard for...
Reboots every 30 seconds or so
Check all your fans and heat sinks including power supply one
Also check CPU heat sink for fluff and dirt
Sep 09, 2008 | Foxconn WinFast K7S741MG Motherboard for...
Disk boot failure when I installed a new SATA DVD writer
Start the system & enter you're bios & use you're manual to help guide you on this. Go to the Boot section of the bios. You can set the boot order. Normal boot order is like this:
1st boot device, floppy disk (if one is connected).
2nd boot device, cdrom drive
3rd boot device, hard drive
(Drive the has windows installed on it).
Save & exit the bios. The system will restart & windows should load. If it does not, than you picked the wrong hard drive.
Mike
Jun 17, 2008 | Foxconn (755A01-6ELRS) (K8S755A6ELRS)...
Bios reads wrong speed
you have to find in yor bios the section where to change the fsb and multiplicator factor of the cpu.I had same problem with an athlon 2400++...you have to upgrade it from 100 to 133 or 166 depending the case.
its   a simple routine work..just find the section in bios...explore it look for this cpu options..I cant tell you exactly where in bios because the bios version is differen from board to board..
and for the second problem
you have to make the hard with windows a bootable option
you may do this from bios too oor from the cable coneting the hdd with the mainboard...options slave/master.cable select..
however you have to set it like:"boot from...." from the bios
good luck .tell me how it worked
bye
Feb 06, 2008 | EliteGroup 741GX-M Motherboard
Upgraded system keeps rebooting before going into windows
Did you upgrade to a new motherboard? If so you need to completely reinstall windows.
Aug 11, 2007 | AMD Motherboard, nForce4 SLI, S939, Athlon...
SATA problem during windows install
try other memory or if you have 2 dimms take one out and try same to both dimms
Jun 30, 2007 | Biostar M7NCD ULTRA Motherboard
Computers & Internet Logo
932 people viewed this question
David Payne
David Payne
