A screw (from a pocket) got into drum, I had to remove & split drum to retrieve. Put all back together.
Machine now allows program selection, but when pressing 'start' button it does nothing. Door is locked during program selection which is not normal as it usually locks when wash program commences
I only removed wire harness to motor & heater so not much to put back(or get wrong). (all keyed)
*I've checked all wire connections across whole machine. nothing loose etc. *water level pressure switch hoses are clear of gunk. * double checked, triple checked
Any ideas please help
James
Comments:
Dec 02, 2007
- I did get the machine working in the end...
When I had it apart I jet washed the drum, to get rid of that nasty scum that always collects. I must have got the motor a little wet/damp. After pulling my hair out, it just started to work intermittently. So I worked the machine hard to warm up the motor to dry it out. After that it worked fine!
my zanussi washing machine zwf 1221s jumps out from the wall when trying to spin. pump working belt...
(More)
my zanussi washing machine zwf 1221s jumps out from the wall when trying to spin. pump working belt on. when trying to spin water some times comes out of washing powder tray machine will stop go in to reverse spin making a grinding noise the stop
after the past few washes when i have taken the load out i have noticied dirty marks on them. these...
(More)
after the past few washes when i have taken the load out i have noticied dirty marks on them. these are brown faint lines that do wash out. the washing machine doesn't sound any different help!!!
we have just changed the ecu or main printed circuit board as u may call it! board on our zannussi...
(More)
we have just changed the ecu or main printed circuit board as u may call it! board on our zannussi fle 1416w as the washer stoped working and a cliking noise came from it so we took the old one out and found that were one of the plugs went was black as if blown we have just payed £90 for a new one and put it back to the washing machine plugged all the plugs back in the right places and wen we plugged the washing machine bk in the ecu board sparked and wen switched the washing machine then on with the on/off switch nothing came on aprt from the light on the on/off switch and the door light the cycle lights dint come on and the machine made a bleeping noise please can u help me wat did i do wrong or is something else making the the ecu board blow???
My GE Front-Load Washing machine (no model name, newer one might be called Adora) is about 6 years...
(More)
My GE Front-Load Washing machine (no model name, newer one might be called Adora) is about 6 years old and recently it has started pausing itself midway through various cycles. The "pause" light is flashing, as though I pressed it, and it restarts when I press the button to unpause it. Very annoying because you expect the load is finished and discover it paused itself shortly after it started. Happens 1-3 x per wash cycle. I don't know if this is related, but I had no problems until about a month ago when I started a load and then all the lights flashed on the machine, door locked and then everything went dead. A few minutes later I was able to power on the machine and it seemed to work fine. It was not a power failure. Any advice would be much appreciated as I can't really afford a service call right now! Thank you.
