Question about Hobart 24 in. LXIH-3 Built-in Dishwasher
Hobart LX 30 P2 Error and unit overflowing!
My Hobart displays a wrench and the P2 error code. Then last night it just over flowed all over my floor. I shut it down and turned it back on and it did the same thing on the first cycle.
  • Anonymous Jan 07, 2009
    p2
  • Anonymous Apr 02, 2009
    Same as above
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
Hi drogers77,
I'm not a Hobart technician, but here what I founded in my manual for the LX30 error message:
LX18 / LX30 display shows E0, E2, E3 or E4
1. Low water pressure - check for clogged hose strainer; check that site water pressure meets minimum flow pressures.
2. Make sure probes are clean
3. No water pressure - main water supply valves may not be working
4. Drain valve open - turn machine OFF to drain machine, then ON. Repeat twice (this assists in clearing any drain valve obstructions). Wait for machine to reach READY mode and press WASH. Slowly open door several seconds later and note water level. Close door; 30 seconds later, open door slowly and check that water level is the same as it was. If not, repeat the OFF-ON procedure. If problem persists, call your local Hobart Service Office.
5. Delime machine.
Hope it will help you.
pepsicrazy
Posted on Jan 13, 2009
    New Friend:
    Problem Solver:
  • 8 Answers
A P2 error code indicates Probe 2 issue. This is the Rinse Temp Probe which is located at the rear of machine near the Vac-Breaker Valve assy. Look for bad connector or wires, if nothing there then probe most likely has failed. However, Your problem with overflowing most likely comes from fouled up water-level probes. Located in bottom Rt rear of water trough, there are 2 probes, low & hi water sensing. These will get sludged up or coated with a thin, sometimes almost invisible coat of limescale. Wipe clean and scrape lightly with a jewellers screwdriver or similar to remove scale. This should solve issue. If error code continues then a faulty probe, wiring or controller issue exists and you would need to call in a professional to test circuit. Frank Commercial Equipment Repairs Nj.
Posted on Jul 28, 2017
We experienced the same problem. Eventually identified a split hose in the unit. Continuing to have the problem though.
Posted on Nov 16, 2010
Hobart Select, Model AM-15 i have a P2 error code displaying with a wrench displaying on the left top corner. i have nt been able to locate this error code in the manual?
https://www.a-wash.org/hobart_29_in_am15_1_free_standing_dishwasher/q2511110-hobart_am15t_ml_130039_p2_message_code
This is as close as I can come to finding an answer. You are correct in saying this info is hard to find. I have also found that someone changed the thermistor and it still did not repair, so, good luck on this and hope it resolves your issue.
Mar 31, 2018 | Hobart Dishwashers
Water continues coming
Hobart ' Undercounter Dishwashers, Commercial ...
www.hobartcorp.com/.../commercial.../undercounters...
Hobart CorporationGlasswasher ... The LXe undercounter is ENERGY STAR® qualified, uses only .74 gallons of water per cycle and features new Smart Display technology to eliminate error codes. Loading... Highlights: Hobart undercounter dish machines are the most popular in the industry, keeping reputations spotless all over the world.
Advansys LXe Undercounter ' Hobart
Hobart CorporationGlasswasher ... The Hobart LXe Undercounter Dishwasher is designed to pack best-in-class cleaning power into a compact space, ... The Advansys LXe low-temp model features PuriRinse, a cold-water rinse that removes chemical residue, ...
[PDF]AM15 Technical Manual - Hobart
https://my.hobartcorp.com/kroger/.../AM15%20Technical%20Manual.pd...
Steam Booster, if used based on 20 PSI steam - 20 PSI water flowing. 130°F entering.... DRAIN AND OVERFLOW: Large bell type automatic overflow and drain ...
[PDF]Glass- and dishwashers - Hobart
Dec 08, 2015 | Hobart Undercounter Glasswasher w/Chemical...
E3 Error code on hobart lx30 dishwasher.
my dishwasher Hobart LX 30 will not shut off and displays 30
Jan 21, 2011 | Hobart 24 in. LXIH-3 Built-in Dishwasher
Lx30h P2 ERROR CODE? WON'T DRAIN COMPLETELY - HELP
the p2 err. is on open or shorted rinse thermistor which is located on the back of the mach next to the vac. brkr. as for draining ck the drain valve for debris, and the end of the drain hose where it connects to the building drain
Dec 25, 2009 | Hobart 24 in. LXIH-3 Built-in Dishwasher
I am getting a wrench symbol and code P2.Can you tell me what this means
The p2 code is your rinse thermistor is bad,if you gain access in the back on the top right side you will see a probe with 2 wires going into the rinse piping.Use a 7/16 wrench and unscrew.Very easy to replace.When the machine goes into the rinse cycle the temp display goes up/down?The part is about $60.Part # 328994.I'm a hobart tech any ? let me know and please rate me.
Aug 21, 2009 | Hobart 24 in. LXIH-3 Built-in Dishwasher
Hobart lx 40 - problem D 1
Does it show a wrench icon and P1?
error codes are p 1to 3 for probe errors, or E1 to 7 for error codes.
P1 is the probe on the wash tank. It's a thermistor with two black wires to a white connector. There is another on the booster front (P2) and a 3rd on the rear airgap, (p3). You could try exchanging 1 and 3 to see if the fault changes too. You have to drain the booster to swap P2. If it can't determine the wash tank temp, it won't know to control the heat and shows the error.
Mar 20, 2009 | Hobart 25 in. LXIH-4 Built-in Dishwasher
Hobart LXIH displays P2
The rinse thermistor is bad,look on the back of the machine to the right and you will see 2 black wires with a plug that screws into the vac breaker this is the probe.I bet when the dishwasher goes into the rinse cycle the temp jumps all over,let me know.
Jul 27, 2008 | Hobart 24 in. LXIH-3 Built-in Dishwasher
Hobart 24 in. LXIH-3 Built-in Dishwasher Logo
2,637 people viewed this question
Top Hobart Dishwashers Experts
Marvin
Marvin
shaun taylor
Are you a Hobart Dishwasher Expert? Answer questions, earn points and help others
