We lost video through the DVD player when moving some furniture. The TV only has one cable to the cable TV box. The TV delivery guys did not have the DVD plugged into the TV, just somehow into the tuner. I tried an S cable, and still the TV (LG) will not recognize the device is there at all. What am I missing?
Ok a bit confused, Tuner ? like amplifier or Tv Tuner ? regardless seems like a easy fix .
First your cable box as 3 cables:1st . Power cable to outlet
2nd. From the wall ( usually a Coaxial cable coming from outside box ) into cable box.3rd. HDMI or Second coaxial cable ( One of these usually goes to the back or side of your Tv depending where inputs are located.)
Now Dvd has 2 cables 1st to Power2nd. To TV ( Hdmi or Coaxial )
On the back of your Tv will have 2-3 HDMI inputs . Assign 1HDMI jack to each media your trying to use.In this case TV HDMI 1, HDMI 2 DVD.
Assigning HDMI's will now reflect on your TV menu selection. Choosing HDMi 1 or HDMI2 from Tv menu will allow you use or view desired Media option in this case DVD or TV.
Now if there is Amplifier / Tuner involved like to connect surround sound to, connection may be a bit trickier however same principal.Plug all media into HDMI 1, HDMI 2, respectively,this time to the back of the tuner NOT to back of TV.Once you have done that You will need a third HDMI cable now from the back of the Tuner ( output Jack, usually has lighter color markings indicating Output HDMI) to your HDMI 1 jack in the back of your TV. Now you have bridge TV/ Cable , DVD into Receiver / Tuner and Selecting media will now be done not through TV Menu as before but through Tuner / Receiver menu or selection.
Good luck .
Good Luck
SOURCE: SETTING UP TJE PANASONIC DMR TO OTHER COMPONENTS
http://www.altex.com/product_info.php?products_id=9207 here is a link to a audio / video switch box you need one of these make sure it has several audio video in and at least one audio/video out
hook all you rca cables up to the audio/video in from the cable box, tv, and dvd/vcr combo then out to the surround sound youll also need to get some rca cable splitters for the out so you can run it back to the audio/video in to the tv as well as the surround sound here is alink to what they look like
http://www.altex.com/product_info.php?cPath=344&products_id=6201
youll need thre of these of course when hooking it up dont pay attention to the color on these just the ones from the tv and surround sound and thats it your done it will all work if you want it to were you dont have to get up and push a button everytime most of them if you push all the buttons in at one time theyll stay like that
SOURCE: Trying to Install
Do you have the red, white and yellow hookups on the back of your TV????? If you don't then you need to get an RF Modulator. You can buy one at Walmart. Older TVs don't have the red, white and yellow hookups. You hook up the RF modulator with a short cable to the cable outlet on your TV. Then you plug in your DVD player to the RF modulator. You also plug your cable for the TV into the RF modulator. It really is very simple. Directions are included with the RF modulator. You will need a short piece of cable also.
SOURCE: Cable box, digital service, channels not appearing
connect the RF lead from the wall to your cable box then out from that to your dvd then out from your dvd to your tv. now connect a scart lead from the cable box to AV 2 on the DVD then connect AV 1 on the DVD to your TV if you have a second scart on your tv connect that to the cable box. NOW on the DVD select AV2 now whatever is on the cable box will be recorded onto DVD/VCR. Put the DVD recorder into VCR mode and set it to auto tune all the Digital Video Broadcasts. You cannot physically tune the cable boxes own channels into the DVD via RF it has to be via a scart.
SOURCE: how can i connect the dmres15 to my cable box, dvd/vhs player
Yea I have the same set up and did the same thing as that your trying to do and what you have to do is run both the cable box and the VCR through your TV using the inputs. As well as a PS2 running through imput 3.
Hope I helped
SOURCE: dvd won't send picture/audio to tv
for video, 3ways and any of this should work.
Step1, video out of dvd to video in on top at video1 section on tv. or
Step2, svideo out of dvd to svideo in at video1 section on tv. or
Step3. using component video
DVD unit component video out to TV unit component video in at video2
Y to Y input of TV
Pb to Pb input of TV
Pr to Pr input of TV
for audio, connect left/right audio of dvd to left/right input of tv. Input section of TV is in the middle. on tv back panel from left to right is antenna input, IN section - this is it, use this for all your connections.
let us know if you have any issues. thanks.
The thing is, everything was working fine until we slid the stereo cabinet across the room a few feet. We did not use, or need any extra equipment. The TV delivery guys used the hdmi cable, and the TV had nothing else going in to it but we did have video from the DVD. We are not using it for recording, only movies.
We're still down to the fact that the appliance store folks hooked everything up through the stereo tuner not the TV. The LG TV never had anything going into it except the HDM cable. The LG TV says no signal, when we select the input for DVD. Don't know how to get it to recognize the DVD player. Again, it was working fine without any extra equipment.
ok , lets test HDMI Jacks and cables. Grab Dvd Player and plug it into another Tv. Keep in mind that some Tv's need to have media powered or "On" before recognizing HDMI is being used, thus sometimes giving you the " No Signal" message. Make sure all media is plugged in and powered first and then turn on TV. If you cannot view it or get "No signal" message on second TV , replace HDMI cable. If it does not work your dvd may have damage HDMI port as a result from being pulled, when furniture was moved.If it works either cable or HDMi is damaged on your TV( Hopefully the other HDMI ports on your TV should be working fine) , so , change to another HDMI on your TV or change cable or both. HDMI jack are sensitive to being pulled or stretch and usually the cable pays the price.See if this works otherwise my last suggestions "update your TV software" consult manual for this. Otherwise TV repair , may need to change your HDMI board ??? I know a really good , serves south Florida Fast Tech Repair 954 353 5855.. Good luck !
