Question about Hotpoint TDC32 Electric Dryer
Spins but no heat
I have a hotpoint CTD40 condenser dryer. It spins as normal and was working OK until yesterday when it stopped. I cleaned the filter and the thermal exchange unit so it's like new, and now it will spin etc but there is no heat. Do I need to re-set anything to get it going again? Thanks.
  • kevinwhiteho Jan 03, 2009
    Barkencoa, many thanks for the help. It certainly assisted, especially testing the continuity of the heaters. Luckily, I have some electrical/electronics background, but for those who dont, this is how I finally fixed it.....
    Look on rear of machine, there is a removable panel which goes from the centre to the bottom left. Remove the screws on the outside edge of this panel and take it off. You will see two screws on their own on the panel, these keep the heaters and 3 stats in place, please dont remove these at this time. As you look at the inside of the panel you will see a number of heater filaments which look like curled up wires partially burnt. Test these for continuity and if OK, leave them alone. You will then see three small round objects the size of a 10p piece with wires coming from them. These objects are the stats. As you look at the stats from the same side as the wires going into them, you will notice ONE of them has a very small hole in the centre of it. PLEASE ENSURE THE ELECTRICITY IS SWITCHED OFF AT THE WALL.
    Now, get a pin or sewing needle and push it into the hole and you will hear a click. This has now re-set the stat. Replace all the bits and put the cover back on. Switch on at the wall and place a couple of damp pieces of clothing in the dryer and use as normal. It is now fixed saving you lots of money.
    Cheers all
    Kevin.
Update - we solved the same problem by resetting the Stat. Follow the instructions posted by kevinwhiteho, but we found that you had to push on the opposite side of the Stat with your finger whilst pushing the pin onto the trip mechanism.
Posted on Jul 27, 2009
  • Hotpoint Master
  • 3,463 Answers
There is no reset button on this m.c, most likely cause of prob, is faulty heater and or stats..Remove rear access panel, and with a meter, test for continuity on stats , and on heater. make sure the wires are removed from the stats, or you will get false readings.
Use the meter on the ohms range, you should get f,s.d (full scale deflection). if no movement on meter, then part is open cc't. Replace both stats even if one is o/k.
Plz rate my solution.
Thanks.
Posted on Dec 27, 2008
  • Godzzooks Apr 16, 2011
    Kevinwhiteo Top Man!, Non Heating problem worked for me, thanks.
    Have had this dryer now for 5 years and as long as you are prepared to De-Fluff it inside and keep pump at back free from gunge it will go on and on.
Hoptoint CDT40G condenser tumble dryer pump running no heat or movement
hi i have a ctd40 mine wouldent go a few years ago on the heater i had three stats on one of them there is a tiny hole i pushed a sewing needle in hole it reset the stat you can see if you look at bottom of stat it might be concave so pushing it out set it again dryer then worked pull plug first
Apr 29, 2013 | Hotpoint Dryers
Hi I've Got A Hotpoint Aquarius CTD40 Tumble Dryer
that isn't a model number,open the door to the dryer,look around the opening where you put the clothes in and send the full model number,
Dec 21, 2017 | Hotpoint Dryers
Hi, my hotpoint condenser dryer model ctd40 stopped getting hot, all works except no heat, any answers?
Chances are needs new thermostat cut out kit, parts cost around £16....
Nov 28, 2009 | Washing Machines
I have a hotpoint dryer ctd40, it seems to eb
either your heating element,hi-limit switch,cycling switch, thermal fuse, or missing one leg of input power i.e.120volts instead of 240 volts
Oct 29, 2009 | Dryers
Dryer spins no heat
hi..A poor connection between the wire terminals and the
heater relay causes high current draw and damages the
terminals on the heater relay on the main control board.
check it out..
thank u..
kindly rate my response..
Jul 20, 2009 | Hotpoint Dryers
Hotpoint aquarius tumble dryer, drum not going round but still
If you can hear the motor going, then the belt probably needs replacing, if no motor action, then prob is more serious.
Please rate my solution.
Thanks.
Jul 15, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Dryer not heating up
I hate to tell you but get ready for more problems with this drier, it has a bad track record. In some cases cleaning the condensor out and drying the unit well will allow the unit to function again. Once a month you need to empty the condenser unit, this is under the bottom panel at the front of the tumble dryer, you simply pull the panel down, undo the condenser and pull it out (it is normal for there to be some water in the tubes when you do this), you then have to flush the condenser by pouring water through it in either your sink or tub. Make sure that there is plenty of room around the drier and empty the water container often. This curcuitry of this unit it sensitive to high humidity and can cause the unit to not function properly. So with condensing dryers you have to work on keeping them clean. Let me know how it goes. Later DRRXR
Feb 02, 2009 | Hotpoint Dryers
Hotpoint TDC32 Electric Dryer Logo
1,259 people viewed this question
Top Hotpoint Dryers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hotpoint Dryer Expert? Answer questions, earn points and help others
