Question about Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System
Ice maker not making ice
I changed my filter and now the ice maker is not making ice. It was making ice before I changed the filter. Water is coming from the water level when pressed but not running into the ice maker to make ice. What could be the problem. The water valve is on.
  • 37 Answers
Make sure that the filter is the right one and that it is pushed in all the way. The most likely cause is the water solenoid behind the fridge. Take an ohm meter and test across the two terminals and it should NOT ohm out (beep). If it does not ohm out I would replace the P.C. Board kit, emitter & receiver icemaker control.
Posted on Jan 03, 2009
Why is ice maker making small cubes?
Low water pressure can make small cubes.
Feb 14, 2016 | Refrigerators
Whirlpool refrigerator icemaker is not making ice
When the ice tray is full it pushes 'UP' a lever, which stops the water flow. It may be stuck in that up-position.
Jul 01, 2015 | Whirlpool Refrigerators
My kenmore side by side is not making ice
when was the last time u change your water filter, if water is coming into the ice maker and it don,t make ice that means u have a defective ice maker, if no water comes into the ice maker check the water valve at the back of the refrigerator with an ohm meter for resistance if no resistance is present replace water valve,u should unplug water valve when checking
Jan 16, 2013 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Ice maker stopped making ice
Here is a check list to use to verify ice maker is good or bad or if something else is causing the problem.
1) Has the water filter been changed recently, or does it need to be changed? The filter being old can cause a reduction on water and lower performance of anything else that requires water.
2) Check the temperature in the freezer. Even though things are frozen in there, the ice maker requires that the temperature be at least 10 degrees F to even cycle. Ideal would be around the 0 degree mark.
3) Check the fill tube where water comes into the ice maker. From time to time this will get blocked due to water freezing in the tube itself.
********* If the first three checks all pass, either the water valve is bad and not allowing water to come to the ice maker, or the ice maker itself is not calling for water **********
Depending on the age of the machine it might not be a bad idea to change the water valve and the ice maker together.
May 30, 2012 | Frigidaire Refrigerators
Do i need to change the filter in order to get the ice maker to work? the water still come out but not into the ice maker. please help!
no you donot need to change the filter first. all of the water goes through the filter first. you either have a bad water valve for the ice maker. a bad ice maker. or bad optics that sense the ice bin on the door is full. can you move the ejector blades on the ice maker? that will tell you if the ice maker gear is broken.
Apr 25, 2010 | Whirlpool GS6NBEXR Side by Side...
Ice maker is not making ice
Even though the water dispenser is OK you need to make sure the tray(s) in the ice maker are filling. The filter valve, located to the rear of the ice maker can freeze over and stop water flow. Check the supply line for the ice maker, it may be separate from the water dispenser.
Mar 24, 2010 | KitchenAid Superba Architect KSCS25INSS...
Icemaker not making ice
If water is also not com out of dispenser then filter should be changed. If water dispenses but ice ice is not being made, the sensor arm or infrared sensor may be stuck or blocked. If sensor is OK then ice maker needs service.
Aug 25, 2009 | Kenmore 57029 Side by Side Refrigerator
Water will not come into the ice maker and the filter needs changing. Even though the filter needed changing before, water has never stopped coming into the ice maker. The line seems to be clear. Any...
Replace the water inlet valve after making sure the tube which fills the icemaker is not frozen . If it is , replace the valve anyway . The valve is the piece which connects to the line to the wall on fridge .
Jul 29, 2009 | Whirlpool GS6NBEXR Side by Side...
Not making ice
Hi: Change or just remove the water filter first. As your water dispensing slowed that is a clue. If the water filter is that clogged it will cause a problem with the ice maker. Plus the water you drink is not filtered anymore. City water is being run through 2 years of crud. If you don't replace it just remove it. I hope this helps, Jeff
Jun 03, 2009 | Frigidaire FRS3R5EMB Side by Side...
GE GSH22SGRE - water dispenser not working but ice cube maker working fine
check the water valve on the back of the ref. it sends water to the ice maker and water in the door one can work and the other one not
Apr 30, 2008 | Whirlpool ED2FHEXN Side by Side...
Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System Logo
162 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
