Question about ASUS P5N32-SLI Deluxe Motherboard
SATA socket broken
It seems that my HDD problem was actually to do with the SATA socket. No matter which device i plug into my First SATA socket it isn't shown, recognized. This means that due to my RAID 0  array, i cannot start windows. THat explains the "Missing OS" problem from before.
What i am asking: Is it possible to replace the SATA socket or do i need to replace entire motherboard, which i really don't want to do.
    Problem Solver:
  • 15 Answers
If you also have IDE connectors, you can buy an IDE to SATA adapter and disable the SATA in your BIOS. Ron.
Posted on Sep 07, 2009
    Problem Solver:
  • 6 Answers
There is no way to replace any single component integrated on a motherboard. Sorry, but you are going to have to replace the entire motherboard.
Posted on Feb 15, 2009
What are the specification of PS4 HDD?
  1. There are some of the specifications that you can look for to get a Hard Disk Drive is as follows -
  • 2.5-inch form factor.
  • 9.5mm thick or less.
  • Interfaced with Serial ATA (SATA) only.
  • Hard drive's type doesn't matter.
  • Speed also doesn't matter.
You can also get the detailed knowledge on the specifications that you must follow and other details through one of the best site that I've been using since last year to get all the details on latest updates, and many more from PS4 hard drive.
Oct 14, 2016 | Sony PlayStation 4
MSI 760Gm-p23 version 3 Fx Desktop athlon II 640 cpu ,deskstar 500 gig 7200 3.5" sata II 16 MB cache hdd, mushkin 8 gig pc3-10600 essential ram, LG L49-8020 oem sata dvd rom post no issue but wont boo
make sure that the cables are right and are good make sure that the power cables are in the dvd and hard drive two cables to each one for board and one to power supply each
Mar 06, 2013 | MSI 760Gm-p23 Fx Desktop Motherboard Amd...
Power not up
1) Please make sure that the HDD IDE cable is plugged in properly on both ends. It is a 40 pin female cord which should be seated on IDE channel 1 on the motherboard.
2) Make sure that all the CD/DVD drives are on IDE 2 or on SATA
3) Make sure taht the Jumper setting on the back of the HDD is set to MASTER
4) Login to bios and make see if you can find the HDD from the IDE drives menu. I am sure you will. From Boot menu select the NATIVE mode that will activate both the SATA and the IDE channels. Select HDD as second boot device.
Feb 01, 2012 | Intel Gigabyte GA-8I845PE-RZ 845PE chipset...
I got a new SATA 500gb HDD but the motherboard wont detect it.
Access to your Bios Setup & configure the Bios settings.
Features Setup Page : This page sets up some parameters for peripheral devices connected to the system.
CMOS SETUP UTILITY - Copyright (C) 1985-2003, American Megatrends, Inc.
Features Setup
OnBoard Floppy Controller : Enabled
Serial Port1 Address 3F8/IRQ4 : Enabled
OnBoard IR Port : Disabled
Parallel Port Address : 378
Parrllel Port Mode : ECP
ECP Mode DMA Chnnel : DMA3
Parallel Port IRQ : IRQ7
OnBoard PCI IDE Controller : Both
OnBoard SATA-IDE
: Enabled *(Make sure This is enabled)
Audio Device : Enabled
Modem Device : Auto
Ethernet Device : Enabled
If you have got a SATA III HDD, ie if it is a Western Digital Sata III you need to configure the jumpers to work with your older Sata interface port.(Only Sata 1 & 2 ports on your Mainboard Socket 478). As for Seagate Sata III HDD, the configuration is automatic.
If your 500GD HDD is not detected, try updating the BIOS!
A word of caution "Updating the Bios is not for the Novice" Do it at your own risk. Failure in updating the Bios may render your Mainboard useless.
Hope it helps.
May 14, 2011 | PC Chips M955G Motherboard
Which hard disc drive is better for pc sata or pata.
hi SATA in my opinion is better, one for air circulation also speed, and the modern motherboards can have from 2 to 6+ SATA ports, which is better than just having 2 ports for 4 items, so i would go for a SATA any day...hope that helps
Jun 16, 2010 | Hitachi Computers & Internet
ASUS M2N68-AM SE2 GeForce 7025 Socket AM2+ MB built system. Works great with Sata hard drive. Removed my older 500GB IDE hard drive and CDROM from old PC. When i try to put both, or either 1 into to IDE...
Try to go into the bios and set the first boot device as your sata hdd. There will be a option in boot section of the cmos setup where the hdd drive order will be mentioned. If PATA is shown first press enter in the option select SATA and press enter save and exit changes things should go on fine.
Also check your pata hdd and cdrom specific jumper setting. For more help post your HDD model and make and cdrom model and the bios type
Dec 01, 2009 | Computers & Internet
Cannot detect external sata hard disk
I would start by swopping the Internal Sata Cables around and check if that solved it.
If not then there's probably a problem with either the E Sata HDD Controller board or Even the HDD or the Sata cable going from the Motherboard to your input E Sata Port.It's a matter of elimination.
So Remove the HDD from the Enclosure and plug it directly into the Motherboard and see if thats picked up.If it is then the HDD is fine.If not, get it replaced and it might still be under warranty.Check with the manufacturer.Continue reading if the HDD is fine.
Then use the Sata Cable from another HDD and connect it straight to to the E Sata Enclosure and see if the Operating System picks it up,Make sure the HDD you removed is plugged back into the enclosure.If that doesn't work then the problem lies with the Enclosure itself and you should get it replaced.
If it does the the problem lies with the cable itself and you should replce that.
Hope this helps you out.
May 08, 2009 | ASUS P5QC Motherboard - Intel P45, Socket...
How do I make my Acer E661GXM mobo read an IDE primary HDD and a SATA secondary HDD?
I didnt got exactly what ya want ...but I have some idea...
probably it says something like ( at identification on boot ) primary ide controller.....cd/dvd...... secondary ..ide ...hdd...... sata controller hdd....
this is not an issue of which one is primary ans so ....cause those are 2 completely different bus-es ...and the only way to make your ide hdd be read like primary ...its to change the plug with the one from the cd /dvd..drive ..
the rest doesnt matter cause it s a different controller...
Apr 11, 2009 | Acer Aspire SA80 (ASA80UC4603) PC Desktop
Asrock Motherboard problems with SATA HDD
It is possible that you are trying to use a SATA II HDD in a system that supports SATA. SATA II devices are not backwards compatible usually,
Dec 20, 2008 | Asrock P4V88 (P4V88 RAID) Motherboard
PC won't boot if SATA drive connected, drive works fine if plugged afterward
Try Hirens Boot CD. It has a lot of programs on it to detect format etc.
I think your hard drive has a missing or corrupt MBR and it needs to be replaced.
When I have had a hard dive not recognized I hve used Super Fdisk to format and reset hard drive.
On the boot disk
Nov 03, 2008 | ASUS K8N-E Deluxe nVidia nForce3 250...
ASUS P5N32-SLI Deluxe Motherboard Logo
113 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
