Question about Ovens
Hotpoint BS 21 fan oven Broken door hinge
How do I remove the old door hinge from the oven I can see how to remove it from the door but can't see how to remove it from the oven
  • barry_dav55 Dec 28, 2008
    Thanks for the advise, nice clear instructions, it took just 10 mins to replace the hinges.Many Thanks barkencoa.
    Cheers Barry
  • Anonymous Feb 02, 2009
    I also have the same fan oven by Hotpoint. It is still under guarantee and one side has broken off even thought it is only 10 months old. I did not expect that to happen as the oven has not been given any bad treatment in my kitchen.
  • Ovens Master
  • 3,463 Answers
Pull the door down as far as it will go, and at the lower end of the hinges, there you should see what looks like 2 round discs, with a step cut out, rotate the discs with a scewdriver as far as they will go,then close the door and pull it towards you, the door should then pull off.
Replace both hinges, not just the one ,or it will close unevenly.
Slot the hinges back into the hinge slots, pull the door down, rotate the disc back to their original setting, and that should be it.
Plz rate this solution. Thanks.
Posted on Dec 27, 2008
Removing oven doors
  • Trying to clean a late 1970s Hotpoint GE Wall Oven Model "R K746 013AD" and
  • I do not know how or if the oven door is removable.
  • See photos.
  • I am able to remove the side of the door hinge attached to the oven but am not sure about the hinge attached to the door.
  • I do not have the owners manual.
Jan 01, 2014 | Ovens
I have an Indesit oven FI 31 KB. It is 3 years old but never used as it is in a house I have just renovated. I turned the oven on, but the fan did not come on as it is expected to do. Oven and light seem...
sometimes there is a switch that operates when the door is opened or closed causes the fan to stop when the door opens. The switch is normally mounted at a door hinge, or hinge bracket.might have to remove a panal to get to it
Oct 19, 2013 | Belling XOU492 Electric Double Oven
Reinstalling oven door which was removed by overseas movers
Have a look on You Tube, there are a number of videos that demonstrate how oven doors can be removed, it normally revolves around latching the hinge. Refitting is a reversal of the process.
The following video shows a number of different methods to remove and refit the oven door
Hopefully, one of the methods shown in the video will help you.
Jun 15, 2012 | Hotpoint Ovens
We have a Hotpoint double oven spec# BD52K and after having the element refitted have notice that the bottom oven door no longer fits flush causing the oven not to seal correctly. is there any way that...
Assuming that the door was not removed for the new element to be fitted, then it sounds to ne as thiugh the oven door hinges are weak.
The only solution is to replace both door hinges,
If the door was removed, then it could possibly be not fitted back correctly.
Jan 28, 2011 | Hotpoint Ovens
How do you fit an oven door to a Hotpoint BD81P oven? My hinges need replacing ?
Go to
WWW.YOUTUBE.CO.UK
In the search box enter---FITTING OVEN DOOR HINGES
You will find some very informative videos on how to fit the hinges.
Dec 04, 2010 | Hotpoint Ovens
How to put oven door back on after removing!
Although very tight (because the oven is only 1 yr old) i managed to get the hinges into the open position, then slide the door into position on the oven and close the door. The hinges did go back and lock as they should but I struggled for almost 30 mins before success.
Jan 08, 2010 | Whirlpool GMC275PD Electric Double Oven
I have a wall oven, a St George single oven. The
Depending on model-
Put the door at an opening of about 100mm. You should feel an indent for thecorect position.
You will probably need 2 people, 1 each side,
Slide the door upward at an angle same as hinge, It will slide off the hinge.
If the hinge is broken, and they usually break inside the wall of the oven, it will be very difficult to slide it off the broken hinge.
Hinges are available from EDIS SPARES 1800 125 039
Sep 12, 2009 | Ovens
Broken inner glass on Model # NGSG3PZAQA
To replace the door glass do the following:
0 Check if there is a hinge stop bracket located at the hinge point of entry on the oven, in that case remove it.
1 remove the oven door by pulling it up and removing from the the hinges. If glass is broken , then secure glass with tape. Have a table with a cloth on top ready to lay the door.
2 Remove the outer screws , starting from lower side of the panel.
3Removethe inner screws. Keep all set of screws ordered, and take note of theorder you remove them. You will follow reverse order in reassembly.
4 the frame will be free now,
5 Remove the external glass panel and leave it in a safe place.
6 Replace the inner glass.
7 Clean outer glass and metal door, re-assemble it and mount it back
I also report testimonials for your model:
removed the door from the oven by releasing clips attached to the door hinge -- very nicely engineered. Removed about 6 philips head screws to allow the door assembly to be taken apart for access to the glass. Lifted out the broken glass, cleaned the inside of the door, installed the new glass, reassembled the door (a two minute project), and reattached the door to the oven. Cleaning the inside of the door"
I removed the oven door by lifting it off with the hinges. Disassembled the door parts one at time making sure I remember where I removed the screws until I am able to get to the broken glass. The most difficult part is making sure that the insulation strip & the gasket stayed in place after I replaced the broken glass & doing the reverse process of installing the parts together. Relatively easy process as long as you remember where the parts go. When in doubt, I had to refer to the pictorial of the disassembled door shown on your website. "
See diagram below , click on picture to enlarge:
Part here: Inner Door Glass
Mar 17, 2009 | Frigidaire FGB24S5A Gas Single Oven
Manual
You can download the instructions you require by going to the Hotpoint web site.
In your browser bar type in --hotpoint user manuals
In the list click on---manuals-user guides-handbooks
In the search box enter the oven model number and download as req'd
Plz rate my solution.
Thanks.
Jan 26, 2009 | Hotpoint Ovens
Ovens Logo
257 people viewed this question
Top Ovens Experts
Marvin
Marvin
Sal De
Craig Butler
Craig Butler
Are you an Oven Expert? Answer questions, earn points and help others
