Question about Canon imageRUNNER 5020 Copier
Message error E901:press the power switchto off then back to on
I have canon np6030 machine when turn on that message is diapla
thank u
    New Friend:
  • 34 Answers
Cassette feed unit motor or control board are faulty. or something is interfering with it.
Posted on Jan 08, 2009
Ihave canon 400 problems. e051, e901, e805 problems frequently please suggest me
by the look at your problems:
E051 - Horizontal registration sensor problems
E001 - Fixing temperature faulty
E805 - The Fan rotation problems
It can be that You have problems with DC contoller ( main pcb ) or the copier is in worst condition and there are faults on every segment.
For E001, you can try to reset error:
1. The following error codes cannot be reset by merely turning off and then on the main power.
They require resetting in service mode:
E000, E001, E002, E003, E004, E032, E717
1) Start service mode, and select COPIER>FUNCTION>CLEAR>ERR.
2) Press the OK key.
3) Turn off and then on the main power.
2. Error codes other than the above may be reset by turning off and then on the main power.
n Detail Code
Some error codes offer detail codes, which may be checked in service mode:
COPIER>DISPLAY>ERR (3rd block from the right)
BUT I THINK THAT THE BEST SOLUTION IS TO CALL SERVICE TO RECTIFY THE PROBLEM OR YOU BUY NEW MACHINE:..
Hope that helps!
Jul 22, 2011 | Canon imageRUNNER 400S Copier
Error code E000013-0001
getfile.asp?rid=1258 February 2, 2005 getfile.asp?rid=3215 Product : imageRUNNER C5800 / C6800 Title : E013 code and Waste Toner Full message Question :
The copier shows an E013-0001 and "Waste Toner Full" message. The Waste Toner Bottle has been emptied and SW1 is operating properly but the code and the message are still appearing on the display.
Answer :
The counter for the Waste Toner Bottle needs to be reset back to zero in Service Mode.
Enter Service Mode level 1 by pressing * 2 8 *, select Copier > Counters > MISC, then highlight WST-TNR, press Clear - the counter will zero out.
Power off the copier, turn the copier back on, the Waste Toner Full message on the display should clear out.
Canon USA, Inc. Systems & Technical Support Division 1-800-528-2830
Dec 22, 2010 | Canon imageRUNNER C6800 Copier
Code error E002 for Canon NP6030
hi 1. cheq the fuser heater lamp & thermal fuse,
2. enter in the sim mod by pressing service swich located in side the front cove you can see the $ sing at the screen left upper corner then press *4* then scroll to find the error then ok macine will re start and hope your error will go
thanks
May 13, 2010 | Office Equipment & Supplies
Canon PIXMA iP1000 - Service Error 5100
It means that the waste ink absorbers are filled and you will need to replace them and take the machine to a service center.. Well thats what Canon says,, then when you get there they say buy a new one..
Any way forget them try this..
1.) unplug machine (power cable from back of printer.
2.) hold the power button down and plug cable back in.the printer light will stay on ,,
3.) still holding power,, press the paper feed button.. light will change to orange
4.) press paper feed button again.. It will turn to green
5.) release power button and enjoy..
Depend on the the firmware skip step 4...
That will bypass canons firmware and reset the counters.. Print as you will now..
Mar 23, 2010 | Office Equipment & Supplies
Receiving E,2,7 Error messages. Can't clear. help please!
Canon support says reset machine by holding power button for one second until the display shuts off. Wait ten seconds, press power button - allow machine to completely turn back on. Otherwise, they say your printer may need repair.
(If holding the power button will not turn device off, you may unplug the power cord as an option).
Nov 28, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Error 805 and 803
Hello sir; The error code you display 803 & 805 could be come from same problem, both all are composite board 24 volt supply problem, replace composite board will take care this problem. good luck.
Jul 24, 2009 | Canon imageRUNNER 400S Copier
Canon np6030
Most likely, you have a problem with the scanning lamp.... When you turn the copier on, will it turn right off? If so, try to hold the power switch "ON". The Display pannel will flash a Error Code... It may be a E0200 or E0220 or E000. Get the Error Code and get back to us... I think you have a heat or scanning lamp is shorting out... Good Luck
Mar 28, 2009 | Canon NP 6035 Copier
Canon NP6030
go to service mode then press *4* and clear ram and enter same values displayed in *3* (please note old values of your machine in *3*before clearing ram)
Jan 14, 2008 | Canon imageCLASS D761 Copier
Canon imagerunner 210s
EOOO is a thermistor-fuser error. Your machine will need a fuser, but on occasion a power surge can trip the error, E000 needs a code to reset it, I dont know if same but this is the code on a IR 330s
Press the userbutton then press "2" & "8" at the same time and then press userbutton again.
You will now enter servicemode
press " Copier "
press "function"
press "Clear"
press "Error"
leave servicemode by pressing resetbutton twice.
restart machine.
Mind you it is only a reset, if fault still exist it will go eooo again confirming that it needs a new fuser unit.
Dec 30, 2007 | Canon imageRUNNER 210S Copier
Canon np6030 copier
Does the machine start and switch itself off? Some errors cause this to occur to prevent further damage. Try switching it on with the front door open, this will prevent the fixing heater circuitry from initialising. You will then need to find the error code. The ones that cause it to switch off never appear on screen, only viewable thru service mode. Push a straightened paper-clip into the hole below the right hand meter inside the front of the machine, press << and >> to get to *1* DISPLAY, find ERROR and let me know. Hope this helps...
Aug 29, 2007 | Canon imageCLASS D761 Copier
Canon imageRUNNER 5020 Copier Logo
382 people viewed this question
old marine
old marine
