Question about Linksys -Cisco Wireless-G VPN Broadband Router [ WRV54G ] (107013)
How to reconfigure back to factory settings
I got a NEW LAPTOP. Need tp reconfigure cisco router back to factory settings
  • 585 Answers
The router should have a reset button accessible by way of a small hole and labeled "reset". Unplug power from the router for 30 seconds, and while holding the reset, plug the power back in. This should default, clearing any passwords etc. Important to Note: Lights should blink on the router, be careful not to interrupt power until the router has completed the reboot process. A power interruption may turn it into a brick.
If you find my suggestions to be helpful, please share with us some details so that others may benefit from knowing the whole story. Thank you!
Posted on Dec 27, 2008
How i reset to factory defaults without passwords?
That depends upon the brand of the router. It would be wise to google for the particular brand.
There often are software means to perform a reset but here are the hardware means.
For Netgear:
  1. Press and hold the Wireless On/Off and WPS buttons until the Power LED blinks red (about 6 seconds).
  2. Release the Wireless On/Off and WPS buttons and wait for the router to reboot.
For Linksys:
1. Press the red reset button on the back.
2. Unplug it from power for 30 seconds. Plug the power back in.
For Belkin:
1. Find the reset button (depends on the model).
2. Depress the reset button for 15 seconds.
3. Wait one minute for the router to restart.
Here is a tutorial for Cisco routers:
http://www.networkworld.com/article/2343961/cisco-subnet/how-to-reset-a-cisco-router-to-factory-default--removing-the-startup-configuration-file.html
Here is one for TP-Link:
http://www.tp-link.us/article/?faqid=496
For D-Link:
Push a paperclip into the hole marked reset on the back and keep it depressed for 10 seconds.
The default user name is usually admin and there is no password (password is blank).
May 11, 2015 | Computers & Internet
Need to retrive my password
From a web browser type LinkSys / Cisco Information on bottom of the router - Factory defaults. Information on most.
192.168.1.1
User: admin
Password: admin
once you're in, check and see if there is a check box that says: Show password. If that's not a supported option, then with the router login information above - Do a hard reset - Press and hold the button in the back of the router for about 5 seconds - This removes ALL PREVIOUS settings, you will have to reconfigure your router.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/william_02fc2766c1e13b73
Apr 15, 2014 | Computers & Internet
My cisco router is not booting properly after turned on. it rather write show some language that is not known and then stop. it would not bring any of the command line or rommon or user mode up
Straighten one end of a Norwegian-invented paper-clip, and insert it into the small hole on the back of the router, and push-and-hold it.
This will reset the router to "factory" settings.
Reconfigure it, e.g., wireless network ID, et cetera.
Mar 14, 2014 | Cisco 851W Router (851WGEK9RF)
How to connect digitech high powered wireless router YN-8330
You may have problems getting this device to register on you network due to the available subnet.
You need to check what IP address range your existing router uses first, then connect the digtech directly to a laptop via ethernet cable, go to the default address (192.1.0.1), log in using admin/admin and reconfigure the router address to one within the acceptable range of your router..
I just configured one of these on both a TP-Link router, and on a Thompson router.
For the TP-Link (Base IP 192.1.1.1) I set the digitech to 192.1.1.100 (easy for me to remember).
For the Thompson (Base IP 10.0.0.1) I set the digitech to 10.0.0.100 (same principle).
Note: you can use any IP that is within the network range of your router.
Also remember to write down the new device ID and put it in a safe place (email to yourself or stick on the back of the router)
Other than this, all config is like any other router.
Feb 04, 2014 | Music
Reinstalling cisco m20 0n vista
Is it re-installation of complete network or you are just trying to add Vista computer to the network?
Is it a complete re-installation then you can reset the router to factory default settings and then try to reconfigure it.
You can run Cisco connect software on the main computer or you can also reinstall it manually,
Read how to reconfigure router manually,
If you trying to connect Wireless Vista computer to the network then you can simply search for the WiFi and then join the wireless network on Windows Vista computer
Jun 05, 2012 | Linksys by Cisco Cisco Valet Plus Wireless...
Help!!!!!!!!!!!
Leave the user name blank and enter the password admin ( admin once only ).
Try this.
If that doesn't work then search for the Cisco connect software on your main computer. You might have installed the cisco connect software on your main computer while installing your router.
If it is windows computer then cisco connect software might be under All Programs.
If is a MAC computer then cisco connect might be under Applications.
Open cisco connect software.
Click on router settings. You will see the router name and password. If you click on Advanced settings, it will open the setup page.
If nothing is working then you will need to reset the router and reconfigure it.
Remember once you reset the router, you will need to reconfigure it from the scratch.
Click to see more information about Linksys E1000 cisco connect software
Apr 12, 2012 | Cisco Linksys E1000 WirelessN Broadband...
Forgotten password for wireless router. How do I reset? My husband needs to connect his Kindle into our secure wireless network but we cannot find our password nor remember it.
You can reset your router using a button available behind the router.
But this will reset all the settings to factory settings and your security settings will be lost, and you need to reconfigure for security settings.
Dec 27, 2010 | Linksys 10 Pack Refurbished WRT54G2RM...
SPA 9000 VOIP - Need to log into system to change configuration.
No.
Try 'admin' and "blank".
Try "blank" and 'admin'.
Failing that, do the "reset to factory settings",
and then reconfigure your VOIP settings.
Apr 02, 2010 | Linksys Cisco SPA9000 VoIP Gateway - 1 x...
I need to restore the factory settings on my router
You will find a reset button at the bottom of the router
Hold that button for 30seconds
Your router will be restored to factory settings
Ensure that you reconfigure it after you reset
Feb 10, 2010 | Linksys Wireless-G WRT54G Router
I have a toshiba laptop, already have existing computer all set up but having trouple conncted laptop to wireless. Have adsl modem and tp link router. tp link is asking or network key to be able to...
Your wireless network is secured and thats why its asking for the network key. If you dont remember the same, contact your router manufacturer or ISP and get the router reconfigured
Jul 03, 2009 | Computers & Internet
Computers & Internet Logo
74 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
