Question about Neff 28 in. T2764 Gas Cooktop
Constant ignition clicking
I've had a neef gas cooker hob for about two years now and the other day i noticed that the ignition was contantly clicking.....i have two RCD units in my house.one is for a spur into the garden and the other is on the main fuse box...i disconnected both of these to see if it was an earth leak but the clicking continued ...can any one suggest anything ?
  • 2 more comments
  • john holohan Apr 22, 2007
    thanks but i've actually dismantled the hob(which ment removing the knobs completely) to test the the electric circuitry and the bloody thing is still clicking !
  • Anonymous Dec 31, 2007
    Same problem. We have to randomly turn other hobs on and off until it stops clicking. Would be grateful for a solution on this one!
  • Anonymous Aug 24, 2008
    cannon, carrick gas cooker, 4 th replacement, only 1 week old all have same problem,When oven gets hot the ignition constantly clicks.
  • Anonymous Sep 30, 2008
    i have just cleaned the gas hob
     and the clicking is now constant. I have removed the rings and knobs and dried everything thouroughly what next?
Check to ensure that all the burner holddown screws are tight. I had a similar problem on a new Jenn Air after a technician changed it over to LP from natural gas.
If one is loose it will not have good continuity causing it to continually click. This happens also when the burner gets hot and expands causing the same effect.
Posted on Apr 27, 2008
  • riley_waterh
    riley_waterh Nov 04, 2012
    Great help, that fixed my stove!
Has the ignition switch got wet ?
Posted on Mar 17, 2008
    President:
  • 1,462 Answers
Try easing the knobs up slightly, they are just a push fit
Posted on Apr 22, 2007
Electric ignition to hob seems to be jammed
Here is a tip that I wrote that will help figure out why the burner spark keeps on clicking...
Gas Range Repair Burners Keep on Clicking
http://www.fixya.com/support/r4033033-gas_range_repair_burners_keep_clicking
heatman101
May 31, 2010 | Cooktops
Ignition not firing on a neff hob, gas fine
Here is a tip that I wrote to help people troubleshoot problems with their cooktops not igniting.
Cooktop Range Stove spark ignition does not work
http://www.fixya.com/support/r5649407-cooktop_range_stove_spark_ignition_not
heatman101
Feb 22, 2010 | Cooktops
Severely reduced gas supply to hobs while grill
Valve at back of cooker that isolates gas to the hobs when the lid is lowered is sticking. Move lid up and down half a dozen times or oil it to ease it.
Dec 27, 2009 | Cooktops
My indesit gas cooker's igniters keep clicking
Hi yes it could be that if it only just done this leave it off you can still use the top the heat while cooking should dry it out.
Oct 10, 2009 | Jenn-Air 36 in. CCG2523 Gas Cooktop
Gas hob is permanently igniting
hi gud day,try to clean the area of knobs by using vacium,remove all the knobs firts then clean it,unplug the unit before u clean.
tnx gerbee
May 19, 2009 | De Dietrich DTG775X Gas Hob 22 in. Cooktop
Ignitor will not stop sparking on AEG Electrolux Cooker Hob
gud day,try to clean the bottom of knob control by removing of knob then clean if by using a vacciumm,if u want to use manually ur cooktop unplug the unit to stop the cliking,then use macthes every time to on the gas cooktop.
Jan 09, 2009 | Cooktops
Stuck auto ignition
try easing each knob upwards a bit.
Jul 15, 2008 | Smeg 23 in. SE64 Gas Cooktop
Gas Hob constant ignition clicking
Had the same problem. All five burners were continuously igniting, after my wife had given the stove a clean. Turned off the power, removed the five knobs and corresponding rubber rings, and used a hair dryer on the five holes where the knobs were for about ten minutes in total. Hey presto, when I turned the power back on, the constant igniting had stopped. Thank you all. I love the internet :-)
Aug 18, 2007 | Bosch 30 in. NGP 732 / 736 Gas Cooktop
Smeg SE64 Gas cook top
problem with hob is probably water ingress in area of ignition unit - will probably cure itself oven is a completely separate unit from hob. problem with it is that you have to re-set the clock - you have it on automatic. after power outage, oven clock always has to be reset
Apr 04, 2007 | Smeg 23 in. SE64 Gas Cooktop
Neff 28 in. T2764 Gas Cooktop Logo
806 people viewed this question
Top Neff Cooktops Experts
Paul Carew
Clive
Clive
ray gallant
Are you a Neff Cooktop Expert? Answer questions, earn points and help others
