Question about LaCie Big Disk Extreme with Triple Interface - hard drive - 1 TB
Computer does not instal Lacie Big Disk
My computer is: Asus Striker Extreme motherboard with 6 Gb Gskill ram, 1 Tb internal HDD Pentium D 3.4 Ghz CPU, 2 x Nvidia 8800 GTX graphics cards (running in SLI) and a Sound blaster X-Fi sound card. It has recently been rebuilt professionaly and I wish to re instal my Big Disk external drive. I have mislaid (euphemism for lost) the installation instructions. I checked the computer properties which state the drivers for the other devices (Mass storage controller etc) are not installed. I have tried to install these from the Asus motherboard DVD but the computer cannot find them.
I am a Brit living in the interior of Oman (read desert) and use the computer for high end gaming as there is little else to do here but chase camels. Please help.
  • goffina Dec 30, 2008
    Thanks I shall try the solution and revert
    Genius:
  • 1,239 Answers
HI Lacie's out to lunch..you may be experiencing the old drivers are shot issues..get THem from the main site, and reinstall, ok?
Posted on Dec 28, 2008
  • ABHISHEK.C
    ABHISHEK.C Dec 28, 2008
    Did you format the drive using Disk Utility? Open "disk utility" from the dock icon or applications/utilities folder. Click the drive name on the left side of the disk utility window. click the "partition" tab in the window, next click the "options" tab and select GUID Partition scheme, or any Mac compatible scheme, read each explanation of the schemes. Name and resize your partitions, click apply. This is how it works running . I hope this helps you
    President:
  • 2,110 Answers
  • Sibananda Jena
    Sibananda Jena Dec 28, 2008
    http://www.lacie.com/download/manual/lbd...
    FOLLOW THE DOCUMENT TO INSTALL..
  • Sibananda Jena
    How do I install a drive on Windows Vista, XP or 2000?
    Some
    LaCie drives now ship with the LaCie Setup Assistant installed. The
    LaCie Setup Assistant will automatically prepare your LaCie hard drive
    for use on your system. For instructions on the LaCie Setup Assistant
    please see our FAQ here. If
    the LaCie Setup Assistant is not provided on the drive, depending on
    the model, your hard drive is formatted Mac Extended (HFS+), Windows
    FAT32 or Windows NTFS.
  • If the drive is formatted NTFS it is ready for use with Windows Vista, XP or 2000.
  • If
    the drive is formatted FAT32 it can be used with Windows Vista, XP or
    2000 but we recommend reformatting it NTFS. Keep the drive in the FAT32
    format ONLY if you are moving it between a Mac and a PC or you will be
    connecting to a computer with Windows Me or 98SE. Note: There is a maximum 4gb file size limit with Fat32. Note:
    Not all LaCie drives are compatible with Windows 98SE or Me. If you are
    unsure if your drive is supported, please check the minimum system
    requirements in the LaCie product manual.
  • If the drive is
    formatted Mac Extended, you will need to format the drive before use.
    To determine the format of the drive, open My Computer, right-click on
    the drive icon and select Properties. Select the General Tab and look
    for “File System”.
  • Microsoft Vista users: “My Computer”
    has changed to “Computer”. Access “Computer” where these instructions
    call for “My Computer”. There are only minor changes with Vista and
    they are noted in the instructions.
    To Format or Partition the Drive
    NOTE: Formatting or partitioning the drive will erase all data on the drive.
    At this point your drive should be connected, your computer booted and logged on as Administrator (if possible).
    1. Right
      click on My Computer and select Manage. If My Computer is not available
      on the desktop it will be listed under the Start Menu.
    2. Locate the Storage Folder, open it if necessary and double click on Disk Management.
    3. If
      the Initialize and Convert Disk Wizard (Write Signature Wizard in
      Windows 2000) opens, close it and use the following instructions to
      initialize.
    4. The drive should show in the lower section of the Computer Management window.
      • Note:
        If the Computer Management window does not appear as in these
        instructions, go to View and set Top to “Disk List” and Bottom to
        “Graphical View”.
    5. The Disk information in the left box should either say “Unknown” or “Online”.
      • If
        the Disk information in the left box shows as “Unknown”, right-click in
        the box and select “Initialize Disk”. The Disk should now show as
        Online,
    6. The Initialize Disk window will appear. The disk should have a check. Click OK.
      • Vista
        will give you additional choices. Leave MRB (Master Boot Record)
        selected. You only need to select GPT if you are formatting a 2TB or
        larger drive.
    7. With
      the Disk showing as Online, right-click on the unallocated space of the
      disk in the right box and select New Partition (“Create Partition” in
      Windows 2000 and “New Simple Volume” in Vista).
      • Note: If the partition has already been formatted right-click and select Format if you wish to reformat the partition.
    8. The New Partition Wizard will open. (New Simple Volume Wizard in Vista). Select Next.
    9. Select Primary partition for the partition type. Select Next.
    10. Specify the partition size. The Partition size in MB should be the same as the Maximum Disk space in MB. Select Next
    11. Assign
      a drive letter or Path. Normally you will use the default Drive letter
      the Wizard has assigned for the partition. Select Next.
    12. Format Partition-
      • File system: Choose NTFS.
      • Note: Windows Vista, XP and 2000 are not able to create FAT32
        partitions larger than 32GB. You must create multiple 32GB partitions
        if you use FAT32 format.
      • Leave allocation unit size as Default for NTFS.
      • Volume label will be the name of the partition in My Computer.
      • Select Perform a quick format. If this is not selected, the format process can take a long time.
        • Note: If quick format does not work successfully you will need to do a full format.
    13. Select Next and then Finish. The partition will show as initializing.
      (If quick format was not selected, this can take quite a while to
      complete). When completed, the partition will have a drive letter, show
      as “Healthy” and NTFS and will be listed in the top section of the
    14. The partition should now be available in My Computer and ready to use.
  • LaCie Master
  • 19,396 Answers
The external hard drive does not need any additional controller/driver on Windows, if that does not work, itis either faulty, or Windows is damaged and must be reinstalled.
  • Ginko
    Ginko Dec 28, 2008
    if the Lacie is connected throught USB , you do not need any driver to install the disk on Windows, the system is supposed to load drivers automatically.
    If the device is not detected, or not working on USB, try first unplugging computer power cable for ten minutes.
    Test also the Disk on a different connection.
    If the Lacie is connected using ethernet or wireless, then you may need to download the wireless software.
ASUS desk top wiring diagram
When it tries to start do you get any beeping, if so how many beeps?
Aug 08, 2014 | ASUS M51AC-US002S Desktop Computer - Intel...
Cant get access to d drive
go to device manager -- click on disk management and check the primary partition
Mar 08, 2014 | ASUS M11BB-US003S Desktop Computer - AMD...
Intermittent-monitor loses pic for 1 or 2 seconds
So did mine until I upgraded the Video Graphics drivers
Jul 25, 2012 | ASUS Cm1740-us-2af Desktop Computer - Amd...
We bought Sims3 for PC but now someone tell me that we must have bought the Sims and Sims2 then it can be install on the PC. Is that true and if so where can we get install disk to go on.
Hi. Welcome to Fixya!
You don't need to install Sims 1 and Sims 2 to be able to install Sims 3 to your computer. For the expansion packs and stuff packs for Sims 3 you need to install first Sims 3 base game for it to work on your computer. However your computer must have the system requirements of Sims 3 to be able to run it properly. Here is the system requirements for Sims 3 :
FOR WINDOWS XP
* Windows XP (Service Pack 2)
* 2.0 GHz P4 processor or equivalent
* 1 GB RAM
* At least 6.5 GB of hard drive space with at least 1 GB additional space for custom content
* 128 MB Video Card with support for Pixel Shader 2.0
FOR WINDOWS VISTA
* Windows Vista (Service Pack 1)
* 2.4 GHz P4 processor or equivalent
* 1.5 GB RAM
For computers using built-in graphics chipsets, the game requires at least:
* Intel Integrated Chipset, GMA X3000 or above.
* 2.6 GHz Pentium D CPU, or 1.8 GHz Core 2 Duo, or equivalent
* 0.5 GB additional RAM
SUPPORTED VIDEO CARDS
NVIDIA GeForce series
FX 5900, FX 5950
6200, 6500, 6600, 6800,
7200, 7300, 7600, 7800, 7900, 7950
8400, 8500, 8600, 8800
9600, 9800, GTX 260, GTX 280
ATI Radeon™ series
9500, 9600, 9800
X300, X600, X700, X800, X850
X1300, X1600, X1800, X1900, X1950
2400, 2600, 2900
3450, 3650, 3850, 3870,
4850, 4870
Intel® Extreme Graphics
GMA X3x00 series
Jul 18, 2011 | Sims 3 HighEnd Loft Stuff Expansion Pack...
Hi , my name is Nitin and the problem i am facing with my PC is that it gets restarted after every 10 to 15 minutes while playing games and it starts disk checking everytime it restarts. This happens even...
The following tip is not for the same model, but for the same kind of symptoms :
http://www.techsupportforum.com/hardware-support/motherboards-bios-cpu/183116-asus-p5p800-p4-3-0ghz-random-reboots.html
Dec 18, 2010 | ASUS P5QC Motherboard - Intel P45, Socket...
I have a 1TB LaCie 2Big Quadra. It has 2 500GB and runs on RAID 1. I replaced both 500 GB LaCie drives with 1.5 TB LaCie drives, but my computer only recognizes the original 500 GB. I formatted both...
I have the same problem too on my 2big form lacie . If I use 2x 1,5 tera disk in "fast mode" or in "big mode" my disk manager only shows 746 gigs available (it should be at least 2,5 terra).
If I use "safe mode" so my system can see 1,3 tera available, wich is normal for a raid mirror configuration.
I hope to find a solution quickly.
Dec 13, 2010 | LaCie Big Disk Extreme 500 GB Hard Drive
LaCie Big Disk 500GB not showing up
1. the usb connector in the PC may have a broken board contact needs soldering or replacement.
2. there may be a broken USB cord to the external usb drive
3. the electronic controller in the USB case may not be working.
4. A new case may be needed with a new controller.
Jul 08, 2010 | LaCie Big Disk Extreme 500 GB Hard Drive
Asus Striker II Formula CPU INIT
u motherboard stop of working is fault get another one from a it very professional
Sep 01, 2008 | ASUS Striker Extreme Motherboard
LaCie Big Disk Extreme with Triple Interface - hard drive - 1 TB Logo
195 people viewed this question
Top LaCie Computers & Internet Experts
Raj Patel
Tony
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
