Question about Sony Grand WEGA KDF-50WE655 50" Rear Projection HDTV
Ps3 sony grand wega (4 yrs old)
Hi, i am trying to hook up ps3 to my sony tv. i have an hdmi port in back of tv. i tried the hdmi cable to tv to ps3 and it is not working........i called place where i purchased tv and they said to press the input button on remote.but i dont have one.........what can i do??? thanks lori
  • 108 Answers
Press the input button on the tv itself to select the proper input you desire.
Posted on Jan 08, 2009
Ps3 turns on but no signal on tv
Hi There,
Is the TV set for the correct input?
I assume you are using HDMI?
If all settings and input selections are correct then I will have to say that either the HDMI cable is faulty, or the HDMI port on either the TV or PS3 could be faulty.
Check if PS3 can work on another TV with the HDMI cable.
Check if another Device can work on that TV with the HDMI cable.
Try another HDMI cable.
From this, you should be able to determine where the issue is sitting.
Hope this helps!
Jan 13, 2016 | Sony Playstation 3 (PS3) Console
Hdmi isnt connecting with the t.v.?
Hi.
Nativeshorta.
please double check the cable.
most common problem is cable.
try console with another hdmi cable at the same time try to connect your other device like pc...etc...with hdmi port of your tv and confirm the tv is ok and all the settings under the video menu,
regards,
nuwan
Jan 27, 2014 | Sony Playstation 3 (PS3) Console
Hi, I have a samsung LE40B750. It is connected
Ur tv some how causes HDMI 1 and 2 port hubs link together so changes back and fourth 1 or 2 HDMI hubs will not a difference.Ur tv have 4 HDMI hub ports wright?Tries not to used HDMI hub ports as like HDMI ports like 1,2,3,4 to as in sequences.Tries used like 1 and 4,2 and 4,3 and 1 as skips sequences might work for ur tv.Tries to hook up the PS3 system as the old format hook up same hook as PS2 format like used the PS station old RCA AV cable hook up.Then that should not causes conflict at all because now tv have two difference kind of format hook up.
Sep 05, 2011 | Samsung Televison & Video
Hdmi Port wont work on PS3
you need to go into your console video settings and setup for hdtv to use hdmi.
May 21, 2010 | Sony Playstation 3 (PS3) Console
I have a HDMI problem with my PS3. I have it
Try entering Recovery Mode and choose "Restore Default Settings".
If that doesn't help, you may have an HDMI port failure - which will require returning the unit to Sony or sending it to a third-party PS3 repair shop.
Mar 25, 2010 | Sony Playstation 3 (PS3) Console
My ps3 is hooked up to my tv via HDMI cord. The
1 - Turn on TV and set input to port being used.
2 - Make sure PS3 is connected via correct cable.
3 - Power on PS3 via power button and HOLD IT for 5 seconds (release after the second beep). It should automatically configure your PS3 to the TV's native resolution for all settings.
Then after that change the output setting to HDMI on your PS3 and see if it works after that, if not, try the system on another TV to make sure its not a problem with your tv.
If it still doesn't work try another cable and then after that it could be a problem with the main board inside of the ps3.
Nov 30, 2009 | Sony Playstation 3 (PS3) Console
PS3 not working on 42'' JVC via HDMI cable port
I have the PS3 and this TV and it works....Try this.
1. Turn ON TV
2. Connect HDMI from TV to PS3
3. Select the correct HDMI input on the TV for the PS3(important)
4.Turn OFF PS3 if it is ON.
5. hold [I/O] Power button on PS3
6. Wait about 5 second and you should get the "HDMI Detected" or some similar message.
7. Configure the HDMI output for the PS3
Also, If you set the PS3 to "auto" for hdmi, it may set the resolution to 1080i. You may want to deselect everthing but the 1080P.
Mar 24, 2009 | Sony Playstation 3 40GB System Console
PS 3 Hookup to Sony Grand Wega
this is a very simple fix leave cords in your sony with ps3 on standby hold the power button on ps3 itself down for 10sec your ps3 will switch back to av cables
Jan 05, 2009 | Sony Playstation 3 (PS3) Console
Ps3 static audio
I just bought my PS3 and noticed this exact problem, Go into your audiosettings click hdmi. then go to manual. Uncheck Dolby 5.1. save your settings. This fixed the static for me. Sony should fix thier 5.1 drivers
Jan 04, 2009 | Sony Playstation 3 (PS3) Console
Playstation 3
try using the composite cables as well.....with your tv set to the composite input go back into the settings and select the HDMI output switch your tv's input back to your HDMI input and remove the composite cables....it should work fine...
Jan 11, 2008 | Sony Playstation 3 (PS3) Console
Sony Grand WEGA KDF-50WE655 50" Rear Projection HDTV Logo
717 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
