Question about HP PSC 1315 All-In-One InkJet Printer
Plastic strip fell out
I think my cat got into my printer, as one day it was working great, and then the next time I tried to use it, it made a very loud noise, pulled a sheet of paper in and stopped. An E is now in the display on the printer. I noticed a thin plastic strip sitting next to the printer. It is long and has 2 small holes, one on each end. It is clear on the ends, but charcoal colored on the rest of it. On each end there is a small dot and a triangle that appears to be a directional type of triangle. I am unable to see where it goes in the printer, but am thinking it is the source of my problem. What do you think?
    Novelist:
    Champion:
  • 254 Answers
Perhaps this is the printhead assembly position "tape." On looking at this tape, are there tiny vetical lines on it? If so, then this is how the printer detects head position, as a sensor & associated circuitry counts how many lines the head has moved. It may attach at one end to a fixed hook, & with a spring like hook at the other end. It will have to be routed through the noted sensor also. This might be tricky if you don't possess some technical skills.
Posted on Apr 23, 2007
Will not turn on.
Maybe the cats caused the theater system to blow a fuse.
Dec 12, 2015 | Philips Televison & Video
How do I reinstall spring and clear plastic strip that fell out?
The plastic strip is supposed to be in there unless you had a mylar sheet going thru and it got jamed.
Oct 12, 2015 | Canon Pixma MG2520 Inkjet Printer
My printer is refusing to print.it makes a deceptive sound that makes one to think printing is on but to no avail.please i need urgent help.
along the top of the unit behind the cart is a plastic strip
its a vernier strip its lots of ''''''''' all the way along
the print head uses it to know where it is
i think either the sensor that reads the strip {ir TXRX led }
or the strip is dirty or worn
Jan 10, 2015 | HP Photosmart C4480 Color Printer Scanner...
My cat pulled out a clear plastic strip. How do I take apart and put it back in?
The clear plastic strip could be the encoder strip responsible for the movement of the cartridge carrier in the assembly. Please contact Lexmark Technical Support Center for assistance.
Aug 30, 2011 | Lexmark X2500 All-In-One Printer
Plastic strip above the printer head
IT IS EASY TO PUT IT BACK AGAIN. HOOKS WILL BE THERE AT TWO ENDS.
Apr 05, 2010 | HP DeskJet 932c InkJet Printer
Canon ip 2600 printer. Paper does not feed
Hey I had the same problem. Called the company; we couldn't fix it. Well I turned it upside down and a 2" flower stem fell out from when I cut some flowers next to my desk. It still didn't work. I was examining the feed area while it was running and I found another little piece of stem that was lodged way in there. I had to get it out with tweasers and it turned out to be 1" long. Couldn't really see it at all. Works fine now.
Oct 25, 2009 | Canon Pixma iP2600 Photo InkJet Printer
Error code 5100 and belt that moves ink cartridge is making noise.
hi there....
since u dint specify ur printer model.... iam giving u a generic reset procedure..... first try this
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not,
press the Power button once more.
8. Your printer should respond as normal..
5100 is a Carriage Home Position Error. if the above reset procedure dint help....
try cleaning the plastic strip that runs the length of the carriage, it may be contaminated.
Use alcohol and a swab.
check the timing strip for contamination(plastic strip about 1/4" in width)
The unit is not homing, check for obstructions.
if even after cleaning the strip ur experiencing the problem then u can be rest assured that its time to call canon...
thank you for using Fixya...
have a nice day
Please rate this solution.
iversh
Aug 01, 2009 | Canon Office Equipment & Supplies
My printer will not print, therefore I cannot receive faxes. I can however fax to others. The printer cannot pull the paper from the feeder even though it's making noises.
On mine, the big drive wheel w/ the numbered plastic disk stuck to it cracked around shaft and stripped. Fed one page, wouldn't the next but made bad sound as tried. Said gear is first one on the left on shaft. Used little gel superglue. Stuck numbered sensor wheel back on any position; seems to reset itself. Took me gutting whole thing to find it though it though,duh. Got one plastic piece, one strip of pad, and two odd shaped pads left over, though. Hadn't figured out where they go yet but it prints and copies great! No screw left either!
May 13, 2009 | HP Officejet 5510 All-In-One Thermal...
Lexmark z730
Try putting the plastic strip in. I think it should help. Anyways i had the same problem but mine didnt work even after replacing it. So Igot an HP all-in-one and I'm satisfied :).
Nov 09, 2008 | Lexmark X2350 All-In-One InkJet Printer
Small thin film fell out
Try to cut off a thin plastic strip. just try to copy that. it basically guides the cartridge on where to print. also i remember that it should have a spring connected to the holes.
Oct 04, 2007 | Dell 924 All-in-One InkJet Printer
HP PSC 1315 All-In-One InkJet Printer Logo
91 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
