Question about LG TROMM WM2688H 4.0 cu.ft. Front Loading SteamWasher
Trap clear on lg tromm. still no spinning and/or draining; pse ad
Trap was clear; drained all water; started over again; still no spinning/draining on button request.
  • Jay B May 11, 2010
    Does an ie or LE error apear?
OE code should appear. I've been able to re-start after unplugging the machine for ten minutes and then re-plug and it did clear the code and spin out but I'm back to the same problem and unplugging isn't working anymore. I'm wondering now if the issue maybe the machine isn't level. Well, something I'm now going to check. Good luck.
Posted on Jan 21, 2009
Model Wm2496HSM will not spin and drain
Jodie, the OE fault is a drain problem. First thing to look at is the pump coin trap on the bottom of the washer behind the little door. If the washer has water in it, pull out the little hose, remove the stopped at the end and drain into a shallow bucket. When the water stops, removed the trap by twisting the trap handle counter clock wise. If it is full of "stuff" clean it and reinstall it. If it is clean, then you either have a bad pump or something stopping the pump.
Apr 10, 2014 | LG Washing Machines
Why will my LG TROMM not spin or drain
Hi harveybento,
Before the Spin Cycle should start, all water must be drained out of the machine. If it does not start, it could likely mean the Drain pump may be clogged. Please follow my below tip on the fix:
ACCESS, DRAIN & CLEAN THE DRAIN PUMP FILTER...
If this does not help, the drain pump may be faulty.
Kind Regards
JEDEMEYER1
* If this solution helped you, please rate it
Sep 05, 2011 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
I unscrewed the lower panel on the front and cleaned out the large black round cap on my LG Tromm Washer. I blow thru the small rubber hose and it sounds clear. I am still getting the OE when getting to...
As you know OE is drain error. you still have a drain problem and this could be because the pump impeller has a coin or similar jamming it, or it could be that the pump motor itself is failing. If the drain hose is clear and not kinked and the pump is working the machine should drain........Good luck....Nomess
May 27, 2010 | LG WM2688HWM TROMM SteamWasher
LG TROMM WM3431HW(?) soaks clothes in Dry Cycle
LG says to unplug unit. Or remove power by tripping circuit breaker. Wait a minute and plug back in. Good luck.
Mar 25, 2017 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
LG Tromm WM2075CW will not spin. I've done
Check first if repositioning the drain hose would help solve the problem. If your unit employs a drain valve, have it checked out. It has a solenoid or a small motor that opens and closes the part. Check as well the drain pump if it is running or no power is being supplied. Have the wire checked to see if there are loose connections.
Aug 27, 2009 | LG Washing Machines
LG Tromm WM2277HW during high speed spin makes noise
I had exactly the same symptom...grinding noise only during high speed spin cycle.
I took the top and back panels off to see how the drain hoses etc. connected. Not wanting to take it apart further, I eventually just took the washing machine outside (I knew I was going to be dealing with water!), pulled the debris catcher front side bottom, and let rip with a garden hose inside the drum with the catcher out (leaving an open drain that could flow unimpeded).
Water flowed quickly out of the open drain, and lo and behold, a small drill bit came out with the water flow. This bit, presumably had gotten through the drum grating, and was resting on the bottom of the housing, scraping and grinding when the drum was spinning.
Aug 16, 2009 | LG Washing Machines
MACHINE RUNNIMG STOPPED SUDDENLY WITH THE LIGHTS BLINKING AND WE TRIED TO RESTART IT AGAIN AFTER DRAINING THE WATER THROUGH THE OUTLET PIPE &OPENED THE DOOR REMOVED THE CLOTHES AND RESTARTED IT AGAIN BUT...
turn on power switch,then press the spin speed button then push start, the water should drain then spin. if the water does not drain chech the drain pump button trap, located lower left front panel.
Dec 30, 2008 | LG WM-2277HW Front Load Washer
NO SPINNING NOR DRAINING LG TROMM SER.WD-12210DB 10kg
check your pump to make sure that it is clean there is a door on the bottom of the machine open it use the little hose to drain the washer in a bucket then twist the big cap and pull it out clean that trap
Dec 26, 2008 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Tromm LG Washer
Santa says that "OF" code is really a "DF" (drain fault) which means check the filter (behind the access door at the lower left on front of the machine). There is a small drain hose next to it which should allow you to drain out the remaining water in the machine before you remove the filter. If the filter is clear, it is possible that the impeller on the pump motor is off, which requires a new pump motor. (if you push the impeller back on, it will only come off again) Santa would like a "fix ya" rating this year. thanks.
Sep 18, 2008 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Washing Machines Logo
106 people viewed this question
Top LG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
