Question about York Yankees Bedding MLB Comforter
Owners Manual Where can I obtain a Owners/Parts Manual for a Stellar York Plus Gas Furnace Model# P2UDD12N07601C
  • Anonymous Mar 24, 2014
    The heater turns on and off
  • Anonymous Mar 28, 2014
    Parts diagram
    Problem Solver:
  • 17 Answers
York Corporate Headquarters
631 South Richland Ave.
York, PA 17403
Phone: (717) 771-7890
Contacting York
Mail:
York International Corp.
P.O. Box 1592
York, PA 17405-1592
USA
Phone: (877) 874-7378
York Website
York was purchased by Johnson Controls in 2005
Johnson Website.
I cannot find an actual manual online. I hope this information helps you. Good Luck.
Posted on Dec 29, 2008
I have a York Stellar Plus furnace (1994 model) on which the ventor (air induction) motor will not turn off. This problem just started. The Furnace seems to work fine, but the ventor runs continuously. I'm...
The W on the board initiates the start up sequence so I believe your problem is with the relay on the control board. probably stuck closed you need to replace the board
Apr 12, 2011 | Heating & Cooling
My York Stellar PLUS furnace (Model P2UDD12N07601C) will not stay on; The ventilator fan runs, the main blower runs, the igniter comes on for approximately ten (10) seconds and you can hear the gas valve...
Check gas pressure, inspect manifold & make sure there is not a blockage.Make sure gas is present and main gas shut off valve to furnace is on also check the knob on the 24 volt gas valve and see if it is in the on position , check the MV terminal on the gas valve to 24 volt common with a volt tester to see if you have 24 volts present, if you do have 24 volts at gas valve, replace valve. if you do not have 24 volts at gas valve check high limit control & roll out limits for a open circuit, Good luck.
Feb 20, 2010 | York Furnace Draft Inducer Blower Fasco #...
I HAVE A YORK STELLAR PLUS,MODEL PEUDD12N09501C 15 YEARS OLD. THE AIR INDUCTION MOTOR RUNS FOREVER. THE AIR INDUCTION MOTOR COMES ON , THE THE THERMOSTAT CALLS FOR GAS, THE IGNITOR LIGHTS THE GAS, FURNACE...
Check the filters first, then check for blockage in the return or supplies. An easy way to do this is by putting your hand in front of the vents to make sure accurate airflow is there. Your furnace has limit switches on it that detect heat, and if heat is getting trapped inside the unit to much, you will trip these switches and the blower will just run forever. Then you have to reset it or wait forever. But try those few things first. Hope this helps.
Nov 26, 2009 | York Yankees Bedding MLB Comforter
Condensation from small blower shorts out circuit board.
Put a plastic bag over the control board that will allow it to breath. you can add sealant to joint but you should clean the old off first. Then use some cork tape after sealant dries. You may also use pvc glue but it will never come out after that, but can be cut w/ saw if that becomes nessary.
Feb 01, 2009 | York Yankees Bedding MLB Comforter
York Yankees Bedding MLB Comforter Logo
3,038 people viewed this question
Top York Sport & Outdoor - Others Experts
Paul Carew
Shehu Pro
Shehu Pro
ray gallant
Are you a York Sport and Outdoor - Other Expert? Answer questions, earn points and help others
