Question about AOC 19LVWK LCD Monitor
Blue contrast/brightness box keeps popping up on the screen
My blue contrast/brightness box keeps popping up in the middle of the screen and will stay up there for approximately 3 or 4 minutes, and then disappear. I try to push the circled 1 button to exit it, but it doesn't seem to work, this is very distracting to me, and I can't seem to figure out how to make it stop...it does it continuously and I am at my wits ends...please help..! This happens every few minutes for the entire time I am trying to use my computer..is there any way to go in and disable the option boxes so it wont continue to do this?
  • ldmcarthu Feb 10, 2009
    contrast brightness screen keeps ppping up
Benimur
  • 6966 Answers
SOURCE: Contrast window keeps on popping in the monitor
Hi, it might be that a sensor in the monitor is sensing change in ambient light and therefore reacts by auto adjusting the contrast. when you push auto, it will do just that and auto react. Why not try manual and set it to your desired setting and let it run that way. But then again, of course it is possible that something is really wrong with the monitor and you would need a qualified service personnel to diagnose/repair it. Hope this be of some help and pls post again how things turn up. Kind regards.
Posted on May 18, 2007
  • 165 Answers
SOURCE: Monitor issue
Open Control-Panel-Display, click on "Settings tab".
Use the slidet to change resolution.
Your monitor should be 1440 X 900.
Click "Apply"
If screen is OK, click "OK" on popup prompt.
if display goes dark, wait 15-20 seconds and it will return to where it was before.
Also: you can click the "Advanced" button
Click on "Monitor" tab.
Adjust "Screen refresh rate to 60 hz or 75 hz.
Posted on Jul 10, 2008
SOURCE: Dell Ultrasharp 21' monitor
I had the same issue. I pressed and hold the + button and the monitor did an auto adjust and the pop up stopped.
Posted on Jan 16, 2009
SOURCE: Dell 15 inch monitor, brightness/contrast window
Press and hold the + button, You will get a message that the monitor is going into auto adjust. After that problem solved.
Posted on Jan 19, 2009
SOURCE: how do you unlock the power button?
press the down and the power botton both at the same time end hold it for 20 second then release that´s all
Posted on Feb 23, 2009
A blue box keeps popping up on my screen that shows brightness & contrast %. How can I remove this?
You may have problem in the logic board (the right board in the first picture), bad firmware in the ROM chip, which there is not much you can do to reload the firmware. You can open it up and inspect the inside.
http://s807.photobucket.com/albums/yy352/budm/HP%20F1703/
Apr 18, 2010 | HP Pavilion F1703 17" LCD Monitor
View sonic monitor gets contrast/brightness blue box in middle of screen
Its an issue with the OSD menu button or the circuit, tap the button a couple of times, it may resolve the issue as it may free up the jammed button. Else its a circuit issue, also check any loose connections. It may need a repair.
Regards,
Shrey
Oct 09, 2009 | Computers & Internet
Brightness/contrast window pops up and scrolls through fast
The up/down button on your flat panel is stuck. Please contact Dell Technical Support to have the monitor replaced if its still within warranty.
May 28, 2009 | Dell E172FP 17" LCD Flat Panel Monitor
Contrast pop up
Is the OSD button stuck on the front of the monitor? Can you control the OSD menu with software or firmware? It may be the button interface/hardware.
Jan 03, 2009 | Computers & Internet
Display problem
the adjustment box for colour, brightness and contrast stays fixed on the screen. i tried pressing the exit button.... after a few times it disappears only to reappear within a few minutes. also the auto adjustment option, for which we are supposed to manually press the i button, keeps auto adjusting the screen whenever it feels like it. the box appears right in middle of the screen and is a real nuisance as it blocks out the main portion.
Jun 28, 2008 | BenQ FP547 - 15" LCD Monitor
Dell E173FP 17-inch Flat Panel Color LCD Monitor
The dell monitors are bad with capacitors going out, check caps in power supply and video board. You can use a can of freeze, it would be easier that way. Just be careful not to touch anything, because these monitors can shock easy.
Sep 06, 2006 | Dell E173FP 17" Flat Panel LCD Monitor
Getting More Brightness/Contrast ?
problem with my monitor Viewsonic E70....Memory recall keep flashing......any help out there.....
Mar 15, 2006 | HP 90 19 in.CRT Conventional Monitor
AOC 19LVWK LCD Monitor Logo
516 people viewed this question
Top AOC Computers & Internet Experts
Jerry Umali
Raj Patel
Are you an AOC Computer and Internet Expert? Answer questions, earn points and help others
