Question about Clarion DB425 CD Player
CDs not playing
I have a Clarion DB328R radio/CD player fitted in my car. Radio works fine and CD player will load CDs but just does not play them! Have tried resetting by removing DCP but makes no difference. Any ideas?!!
  • 41 Answers
Yellow - +12V Constant Power Red - +12V Switched (accessory) Power Blue - Power Antenna Blue/White - Amp Turn-on White - Left Front Positive Speaker Wire (LF+) White/Black - (LF-) Gray - Right Front Positive Speaker Wire (RF+) Gray/Black - (RF-) Green - Right Rear Positive Speaker Wire (RR+) Green/Black - (RR-) Purple - Left Rear Positive Speaker Wire (LR+) Purple/Black - (LR-)
Posted on Sep 21, 2007
SOURCE: connecting clarion radio cassette arb1170e
error 6
Posted on Aug 01, 2008
  • 57 Answers
SOURCE: Cannot Manually Tune The Radio CLARION DRB4475R CAR CD PLAYER
check your setting on the itrip unit to make sure it is set for frequency
Posted on Jan 10, 2009
  • 35 Answers
SOURCE: clarion DRB3675 cd and radio with clock
to set the clock just press and hold the DISP for 5 to 10 seconds, button while the clock is is displayed. When the the time starts flashing, use the DISP button to adjust the time. When you have the correct time, just hold the button until the clock stops flashing and you're done.
Posted on Jul 09, 2009
  • 4679 Answers
SOURCE: how to put in the radio code, have no manual
CLARION code entry instructions can be found here
Select your model from this long list
Posted on Sep 06, 2009
  • 54 Answers
SOURCE: standard clarion car radio in citroen c3 strugles
try cleaning it with a car of air oand the a cleaning disc
Posted on Sep 25, 2009
0 characters
1 Points
CD will not play. The CDs goes in and out fine and looks like it is playing according to the display. I can change songs, fast forward and reverse through the songs according to the display but nothing...
Do you have the radio hooked up to an amplifier? If so, it sounds like you are using the blue wire (antenna remote turn on) instead of the blue/white wire (amplifier remote turn on) to turn the amp on. The antenna remote wire turns off when leaving tuner mode.
Jun 22, 2011 | Alpine CDA-7863 CD Player
On playing a store bought cd, left front speaker doesn't play, but right front does, currently there are no rear speakers all wires are connected through the wire adapters to hook directly up to the...
if its working with the radio the fault must be the cd part of the radio hence take it back after testing different cds, home made cds may not be compitable with unit
Jan 02, 2010 | Alpine CDA-9856 CD Player
Cd's won't play
Its dirty, try a disc cleaner, (brushes not solution) and if that does not work, its time to replace, (unless the radio is all ya want).
ALSO- if you are trying to play burnt discs, (cd-r, mp3 discs etc) than that could be the issue as not all indash cd players support non store bought cds
Aug 16, 2009 | JVC KD-S640 CD Player
I having problems getting my subs to play through the cd player!!
More than likely you have hooked up the power anttena wire as your remote turn on. So hook up the OTHER blue wire to feed your amplifier, and problem solved.
Aug 07, 2009 | Clarion DXZ385USB Car CD/ MP3 Player
Jensen 2006 7" indash touch screen: CD player wont work
Try a lens cleaner . If that doesn't work then it would have to be repaired.
May 07, 2009 | Jensen MP7610 CD Player
Frmtread error
how can it solved?? My old mp3's work perfect, now i made a new mp3 cd on the 700 MB space, but it doesnt work anymore.. i get ERROR 23 on my display.. what to do??
Jul 02, 2008 | Pioneer DEH-P3500 CD Player
Doesn't Play Some CDs
hi, you have to know that a burned CD have a life limited around 10 years and after to read these CDs you have to make a new copy of them. :(
Mar 31, 2008 | Alpine CDM-7833
How to set radio to play from the last song that it plays before turn off.
all CD players should do this. Who installed the CD player? Because it sounds like the memory wire isn't hooked up right. Does the clock keep the right time? If not your memory wire isn't hooked up right.
Jan 22, 2008 | JVC KD-G310 CD Player
CD,s will not play
Read the Manual on Page 2 or get it from:
Just make a reset with a pen or something else.
This should solve the problem.
Best regards
Dec 28, 2007 | JVC KD-G421 CD Player
Clarion M235
It needs a new CD mech. Hopefully you can exchange it from the shop you got it from.
Sep 19, 2007 | Clarion M235-RET CD Player
Clarion DB425 CD Player Logo
21 people viewed this question
Top Clarion Car Audio Receivers Experts
xxxxxx xxx
Marco Avila
Marco Avila
Jaime Hernandez
Are you a Clarion Car Audio Receiver Expert? Answer questions, earn points and help others
