Question about Power Color RADEON HD 2600 XT, Graphic Card
New Vid Card, Comp Freezes when loading windows.
I just installed a new Radeon HD 2600 XT (AGP slot - 512mb, 128bit DDR2) into my mobo (DFI PE21-EL). Before I switched over to this card I uninstalled my drivers for my GeForce FX-5200 by way of add/remove programs. I then have tried every combination of new drivers I can get my hands on (From theDVD that came with it, to every source I can find online) and it all ends with the same result. I get the drivers installed, restart the computer like it tells me to, and I get to the windows loading screen with the tiny blue bar that shows its loading, then when it should be transitioning to the next screen, it freezes in a black screen.
My computer specs are the following:
Win XP SP3
DFI Pe21-el mobo 100mhz fsb (http://www.firingsquad.com/hw/268/DFI_PE21-EL/)
1.7 intel celeron cpu
2 gb RAM (1gb x 2 PC400) (I've also tried it with 2 x 256mb RAM, no go)
and the PowerColor Radeon HD 2600 XT
Does anyone have any ideas?
Also, I currently posess a 2.8ghz cpu that fits in the mobo, but I cannot get the computer to boot at all, I can't even get into the BIOS. The firingsquad page has specs about my mobo and it says it should handle the 2.8, but it doesn't. Could this be because I need to update my driver?
I Found the manual for my mobo online and it mentions that It can support up to DDR-333 aka PC2700 ram, but on the contrary I use PC400 aka PC3200 and it works just fine. The firingsquad page about my mobo says that I can use the PC400. So along those same lines the manual says that it supports up to a 2.53ghz cpu, but the firingsquad page says I can use up to 2.8. So going with the common trend, should and update allow me to use the 2.8 or not? Also another source for what cpu's the mobo can handle :http://www.cpu-upgrade.com/mb-DFI/PE21-EL.html and the mobo manual: http://209.85.173.132/search?q=cache:ktokqPYWVnoJ:www.dfi.com.tw/Upload/Manual/60100227.PDF+pe21-el+voltage+control&hl=en&ct=clnk&cd=4&gl=us&client=firefox-a
Thank you for your time.
  • 1 more comment
  • jchicks87 Dec 27, 2008
    I may have found the solution for my CPU problem. I had recieved a Prescott 2.8ghz cpu, and needed a Northwood cpu. So Un tilI get a northwood and prove myself wrong or right we can disreguard that bit about the CPU.
    Thanks
  • Anonymous Jan 07, 2009
    Well, in the end I decided to format my computer and start from scratch. What I learned was that prior to any of the service packs being installed, the driver for my wireless pci card was causing the computer to lock up. Once I got that out of the way, I kept installing all my drivers, updates, and programs to see which/if any were causing the problems. I now have all my drivers updated, and my windows updated to SP2. For some reason I get back to the freeze when I install SP3. Is there any logical reason for this?
  • jchicks87 Jan 07, 2009
    Scholar:
  • 40 Answers
Fisrt you must Do a search online on how to make a deep uninstall of nvidia drivers.
Then...
Do "deep uninstall" of all ati drivers and programs present in the affected computer computer, remember to remove all ati or powercolor related programs from control panel's add remove utility, including the whole multimedia center. And finally reinstalling the new drivers.
You should have downloaded the most recent catalyst drivers from the power color manufacturer that are available for your card.
Now proceed with the "deep uninstall" following this directions, taken from somewhere on the internet, thanks to the one who wrote them...
1. Go into the Control Panel and under the ADD/REMOVE SOFTWARE icon uninstall the ATI Multimedia software and/or the ATI DVD software.
2. Uninstall the ATI drivers also found in the Add/Remove section. Once removed, it will prompt you to reboot....do so.
3. When returning to windows, the NEW HARDWARE FOUND wizard will come up and will tell you that it has found a new VGA card and will prompt you for drivers. Hit CANCEL!
4. Now, go to START - SEARCH - FOR FILES OR FOLDERS and do a search for all files and folders using the filename ati*.*
This search will normally give you 3 to 4 files found in your c:/windows directory and subdirectories (including the Windows/System directory). Select these files and erase them. Now go to your Recycle Bin and Empty your bin.
5. Next...time to go to your Registry. Go to START -- RUN -- regedit
Here go to key HKEY_LOCAL_MACHINE -- SYSTEM -- ControlSet001 -- Control -- Video . Here there should be 4 entries. 3 of them are default Windows XP entries and the 4th one is put in by the ATI drivers. Expand each one by one until you see ATI entries. Once found, erase the entire key.
Now repeat the same step above for the ControlSet002 key and the CurrentControlSet Key. Normally, whenever you erase a key in the ControlSet001, XP automatically deletes it in the CurrentControlSet section too. So if the ATI key is not found in the CurrentControlSet section, don't worry about it.
Once all keys are deleted, proceed to the next step.
6. While still in the registry, go to the key HKEY_LOCAL_MACHINE -- SOFTWARE section. Here you should find an ATI Technologies key. Select it and delete it. In that same section, look for an Installed Options key. Expand it and there you should find another ATI Technologies key. Select it and erase it.
7. Still in the registry, go to HKEY_CURRENT_USER -- Software and there you should find another ATI technologies key. Select it and erase it. Once all this is done, close the registry. the registry is now clean. Though you might want to even run a registry cleaner, like the one included in the freeware program CCLEANER, it's very good, can be undone and it's safe enough to use it almost blindly.
8. Close all windows and reboot.
9. When in windows after the reboot the NEW HARDWARE FOUND WIZARD will pop up again. Cancel that. Now find the new ATI drivers that you have downloaded and extracted and run the SETUP file. Once complete, reboot and you are DONE!
Posted on Jan 04, 2009
I am a gamer and p5vdc-mx has only agp slot and i want 1gb vga card but it is harder to find in agp slot i find only pci express x16 cards can i use riser card to convert agp to pci e x16
Hello
I dont think there are any agp to pci ex riser cards.As pci e x16 is part of the motherboard circutry.
There are pci to agp riser cards.If your going to be playing some of the latest games.Most games in the past 3 yrs require a pci x16 vid card.
I suggest geting another motherboard,chipset,and memory.Along with a Pci e x 16 card min 512mb.
Sep 07, 2011 | ASUS P5VDC-MX Motherboard
Hi im from Croatia,and my english is not wery good,but im in depresion 2 week because my new video card(powercolor HD2600xt, 512mb,ddr2,agp.My problem is: when i put my card in comp and instal driver,than...
No need for depression.
Go to your Device Manager > Display adapters > double-click on your card [HD2600xt]. Go to the Resources tab and you will see one of the resources marked with red, try to manually change it's corresponding resource type setting until it is safe to use [I presume that you have a resource-conflict issue !?]. Until you do so, your gfx card will not use it's full potential ;)
Kind regards,
Mark
Dec 26, 2009 | Power Color RADEON HD 2600 XT, Graphic...
Installed a new Saphirre Radeon x1650 512mb, 128bit, AGP 8x card. But I am not seeing a significant increase over the onboard graphics. The card install sheet says to Disable the onboard video, but I don't...
In your BIOS on the main screen choose INTEGRATED PERIPHERIALS (get a copy of your manual here if you don't have one), then go to INIT DISPLAY FIRST, and choose AGP. It's not clear from the manual if AGP is an available option, choose PCI slot if it is not. ECS is notoriously sloppy with their BIOS programming.
While you are in the BIOS, under ADVANCED CHIPSET FEATURES choose AGP &P2P BRIDGE CONTROL then make sure your AGP DATA RATE is set to auto.
Apr 16, 2009 | EliteGroup 661FX-M7 (661FXM7V11)...
Screen going blank for a second or two while video freezes then jumps.
If you have on board graphics try removing video card and reboot when computer rebooted turn it of and refit card and restart when restarted computer should recognize new hard ware and should find the already installed drivers if not try installing drivers again
Sometimes windows does not recognize new hardware until its refitted
had this problem with modems alot and the above method solved it
Jul 31, 2008 | ATI RADEON X1650 Graphic Card
Graphics card support to motherboard D845GBV
AGP 2.0 and 3.0 4x and 8x feed with the 1.5v spec. AGP 1.0 1x and 2x was fed at 3.3v. In short, you should be fine.
May 15, 2008 | Intel D845GBV (BOXD845GBVL) Motherboard
Graphics Cards
The Evga 7600GT is a AGP, you can't use this.
The ATI 2600 XT is only warranted for 1yr.
The EVGA 8600GT 256Mb is a Limited Lifetime. If only these three than the 8600GT Would be best.
Suggest you look here too.
http://www.zipzoomfly.com/jsp/ProductDetail.jsp?ProductCode=10006326
Dec 25, 2007 | Computers & Internet
Sapphire HD 2600 XT Driver Problems
To get your drivers follow these simply steps below:
First go to this website "CLICK HERE" - once you've done that fill in all the details of your "Graphics Card" then download them.
After you've completed the installation restart your computer just to make everything work correctly.
Note: after you've installed the driver your resolution when you've restarted your computer will be diffrenrent and may need changing.
Good luck. Hope my solution was helpful in someway. Further problems of any kind just leave a message on here and i will get back to you a.s.a.p.
Dec 02, 2007 | XFX NVIDIA GeForce 8600 Graphics Card
Power Color RADEON HD 2600 XT, Graphic Card Logo
217 people viewed this question
Top Power Color Computers & Internet Experts
Alun Cox
David Payne
David Payne
Are you a Power Color Computer and Internet Expert? Answer questions, earn points and help others
