Question about Nakamichi AV-2 Receiver
Nakamichi receiver av-2
L have a reciever that no l cannot figure out how to get the sound to come out.you have to turn up the volume to hear the littlest sound.when you turn it on there is a click to let you know it's ready.it also has dubbing control on.not sure if this is the problem or not,as cannot get it to turn off.lt probably is something minor.any help would be great.l've tried different a/v cables and no difference
  • 1 more comment
  • jmrc Dec 30, 2007
    System worked fine for years. Suddenly I only can get a very low volume when volume knob is turned all the way up.  I was using TV remote and pressed a number above four when it happened. Played around with the receiver buttons and suddenly the volume came back to normal. Not sure how I fixed it.
  • ngennaro Nov 25, 2008
    Have the same issue. In normal tuner mode can only hear sound if I turn it all the way up. If I put it in Stadium mode I can hear it fine albeit with a stadium echo. Any ideas?
  • lucky2262 Apr 02, 2009
    It turn's on ,on sound at all. my dubbing light on also. I checked all speaker outs, no go-go . Can you help
Jumpers must be in main in pre out
Posted on Aug 19, 2007
The receiver is muted when playing in tuner or cd the volume is not coming through the speakers. We can hear it muted when turning up to max its very low. Lost instruction manual can you help. I think my...
I can't find a manual either. Can I assume you really mean the sound is muted for EVERY source, not just tuner and CD?
I'd guess it's either MUTED or a Tape Monitor is active. Turn the volume down, select FM as the source, tune a station and use it as your test source. Look around for indicators that give a clue.
NEVER troubleshoot anything with the volume control turned way up. You'll blow up or damage the speakers and your hearing right after you discover and correct the misplaced control.
Aug 15, 2010 | Nakamichi AV-2 Receiver
Got a Nakamichi AV-2 receiver at a garage sale, no manual however. Can I use it to power a 5.1 surround system for home theatre?
I could find only little information about this receiver, but it seems that is supports only 4.0 Dolby Pro Logic.
May 12, 2010 | Nakamichi AV-2 Receiver
Nakamichi AV10. Re: left channel softer than the right one.
Hi,\
Its an issue with the tone switch activate and reactivate it to get back to normal volume on both speakers, and would suggest you to clean the switch with WD40 and it should resolve the issue
Jul 16, 2009 | Nakamichi AV-10 Receiver
AV-2 surround receiver. No sound
This may sound silly, but make sure that the tape monitor switch is not turned on. If it is not, let me know and we'll look elsewhere.
Dan
Sep 12, 2008 | Nakamichi AV-7 Receiver
Nakamichi AV-7 (issue with surround mode - prologic)
Nice Receiver!
>In your surround sound settings make sure the levels are set correctly and the distance from your listing point to the furtherest
speakers are set to accommodate the levels etc.
>How many speakers 5.1, 6.1, or 7.1 (1meaning subwoofer)
>Pro-Logic supports 5.1 but not sure about 6 or 7
>Pro-Logic II does support all
>Make sure you are hear the sound from all sometimes the sound is really faint if you are in surround mode
Thank You and good luck
Aug 28, 2008 | Nakamichi AV-7 Receiver
Nakamichi TA-4A receiver no sound
HAI,AMP WORKS FINE , CONNACT ANY OTHER TO AMP(CD,DVD,COMPUTER,MOBILE,TV) IN BACKSIDE INAUDIO OR PRE_AMP .THEN SELECT  PLAYER TO IN MODE YOU HAVE INSAERTED.THE SOUND IS OK
Jun 26, 2008 | Nakamichi AV-10 Receiver
Reciever get louder in one channel then static then goes back to normal
HAI,IT'S A SMALL PROBLEM ANY DRY SOLD INLEFT AUDIO SECTION
Apr 30, 2008 | Nakamichi AV-10 Receiver
Nakamichi AV-10 loud thud from subwoofer
I don't know the design of this reciever, and do not have any schematics or engineering information to know the design.
This is a general comment:
In many of these recievers at this level they don't have very good muting designed in to their system. When switching sources, the audio is not being muted.
This is a theory of why the noise is not on the main speakers, but present on the sub woofer. Because the switching noise is of very low frequency, this is why the sub woofer is making noise. The main speakers lack the low frequency sensitivity that the sub woofer has. This is one way of looking at it. It is also possible that there is muting for the main speakers, and none for the sub woofer.
If the reciever does have muting in to its design that is supposed to mute when switching modes, then there is an obvious defect. When a source is switched, or a mode is changed, the output would mute for the duration of the switching interval. This is usually for a period of about 100 ms.
Your best bet is to contact the service rep for nakamichi and ask the question there.
I have serviced many recievers made by other manufactures. The higher end models all had muting in their design. This way, the output was muted when the source was changed, and when the reciever was turned off or on.
Jerry G.
Apr 23, 2008 | Nakamichi AV-10 Receiver
Nakamichi AV-10 very little sound on the center speaker
could be the speaker, try connecting another speaker and cable and see if it improves. If the problem is still there and you've checked all the settings insuring that its not turned down, then could be an internal problem with the receiver.
Hope this helps a little at least.
Mar 30, 2008 | Nakamichi AV-10 Receiver
493 people viewed this question
Top Nakamichi Audio Players & Recorders Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Damen Wong
Damen Wong
Are you a Nakamichi Audio Player and Recorder Expert? Answer questions, earn points and help others
