Question about Zoom H4 Handy Recorder
Corrupt wav recording on an H4
I ve had my H4 for few months now and recently, when i record on wav format, each track, about one minute through sounds corrupt.as if fragments from random bits of the track appear the real track.that happends every about 1 min of music.I think when i record on MP3 this doesn't happen.I have now updated to 2.20 version but the problem is still there.please help.thanks
SOURCE: transfering music from the H4 handy recorder to the pc.
Make the instalation of cubase LE that come when you buying the Zoom H4.When you instaled this,the driver H4 must appear in the sound/device properties.I hope you can solve
FF
Posted on May 08, 2008
SOURCE: h4 randomly stops recording on cubase le
I may possibly have solved this. I didn't realise that when I log off from Cubase, the ASIO driver returns to the Multimedia ASIO driver, which seems to be the default setting.
Every time I want to record with the Zoom H4 in future I'll need to reconfigure the ASIO driver to the H4 one.
I thought once I'd set the driver, it would remain there every time Cubase booted up. Apparently not.
Posted on Aug 31, 2008
SOURCE: Corrupted WAV file will not play or transfer to computer
yes!...
after try, try and try again... i have the solution now!
my english is very bad but i will try write good...
ok... i use one file recover (have many softs this type in internet...) i used this: R-Studio
try this and all will be ok!
good luck for yours!
Abimael - Lgm legrandmenteur@hotmail.com
Posted on Apr 07, 2009
SOURCE: Zoom H4 Battery Problem
I am having the same problem with my Zoom-H2. I have 2 2650 mah rechargeables, and the draw is such that 20-30 minutes of record &/or playback kills the batteries. Last night I just turned the power on and did nothing. 5 hours later the batteries were dead...
This isn't a solution. It is a reaffirmation that you aren't crazy!
Posted on Feb 01, 2010
SOURCE: zoom h4 Vista recording
Don't know if this is the problem in your case ... but here's what I did:
Note: I have Win XP
Previous to attempting connection between laptop and H4 as an audio interface I updated the H4 firmware to ver2.4 and connected to the laptop successfully as a card reader. From the laptop, I could see files I knew were on the H4 card.
... but when I tried connecting in Audio I/O mode, my laptop didn't know what to make of the H4. There was a USB mass storage driver associated with the H4 - I could see this from the "Device Manager". I "uninstalled" the USB driver associated to that "unknown" USB device. I terminated the audio connection on the H4, then reconnected. !!! It was recognized as "USB Audio Device" in the "Sound, video and game controllers" section of the "Device Manager". Before, it was listed under "Universal Serial Bus controllers" as a generic USB device with a yellow warning highlight indicating there was something wrong.
Hope this helps!
Posted on Jan 02, 2011
What is the problem on recording my fourth record, the screen indicates FULL. What is the next step. Thank you
When you say "fourth record" do you mean 4 LPS containing at least 16 tracks each?
If you are, check the format that the recordings are in. For example some recording software use WAV files which are very large.
Since an LP is about 30 minutes a side maximum you could have two hours of music! Depending on how full you drive was it could be nearly full, especially if they were recorded as WAV files!
MP3 files take up far less space so you could convert the WAV files to that format and then delete the wave files. If you can free up space to do it.
Jun 25, 2016 | Audio Players & Recorders
Zoom H1 says
What format are you recording in? Recording in the standard resolution WAV format will only give you about 3 hours in total on the 2GB SD card that comes with the H1, whereas lower resolution WAV recording or MP3 recording will give you more hours, more than 34 hours form MP3 at 128kbps.
Mar 03, 2012 | Zoom Audio Players & Recorders
I've bought a SDHC card 32 GB but Handy Recorder H4 do not recognize the card. I've tried to format it at the pc, but no way, the message is "no card"
Verify the device and card reader support SDHC. Try a 2g card and see if that works, typically anything 4g or larger is SDHC, older devices can not read such cards. It is quite possible that the card is bad.
Oct 14, 2011 | Zoom H4 Handy Recorder
Jan 05, 2010 | Zoom H4 Handy Recorder
Err format while recording - 1 hour lost!
I have almost the exact same problem.
I did not interrupt my recording. I stopped recording, turned off the recorder, unplugged all the mics, turned on the recorder, listened to the first 10 seconds of the recorded track, turned off the recorder, plugged it into my mac, turned it on in USB mode, attempted to transfer the track file, and the track size is "zero kb." I ejected the recorder, turned it off and back on, and now the track says "err format" and skips to the next track.
This seems like a unique problem, as any "data recovery" software will search for deleted files instead of corrupted files. And even if the file is corrupted I have software that can read the raw wav data. However, the filesize is incorrect and obviously doesn't contain any wav data. Shouldn't it be the actual file size? How can I fix this???
Sep 13, 2009 | Marantz PMD660
File import in 4-track mode impossible
Convert the audio to Mono WAV (16Bit, 44.1KHz). This can be done by using Cubase(Hope you got Cubase LE with Zoom). In an empty project import the audio, then mark the whole track using the Draw tool and then got to File->Export. Here select the above options and export. Import this file into Zoom H4 either by copying directly into the memory card or through connecting the Zoom to computer ( I copy it directly into the memory card's STEREO folder). Now if you import it to any project, it will appear there. You can now use Zoom H4 as a Karaoke device!! Anyway, sad that Zoom H4 doesn't support stereo tracks in the 4Track mode.
Aug 14, 2009 | Zoom H4 Handy Recorder
yes!...
Dec 22, 2008 | Zoom H4 Handy Recorder
Uploading files into projects
Most of the time you have to convert the wav files to another format Such as MP3 or WMP. there are converters available for this purpose online.Google audio converters. Maybe you will find one that you can afford . Or even find freeware.
Oct 28, 2008 | Zoom H4 Handy Recorder
This is suppose to hold hours of recording time and mine only holds a few minutes. How do I increase the time?????
Two things to try: make sure you have a big enough memory card for the intended format and recording time. I suspect you are trying to use the 16MB Compact Flash card that came in the box. A 1GB card will record much longer than the battery life in the Microtrack 24/96, even when recording 24-bit stereo in WAV format. If you have a smaller card, and want long recording times, use an MP3 format. Using the MP3 encoder, monophonic recording, 128K bits/sec, 44.1K samples/sec, you should be able to record over 16hrs of audio on a 1GB memory card. Same card, WAV encoder, 44.1K samples/sec, stereo, 24-bit audio will produce only a little over one hour of recording time. With the 64MB card that came with the recorder, the most you can record using WAV encoding, 24-bit audio, 44.1K samples/sec, is a little less than 4 minutes. With 16-bit audio about 6 min, and with mono and 16-bit audio about 12 min. With WAV, 24-bit audio, mono recording yields 7:52.
Nov 07, 2007 | M-Audio MicroTrack 24/96
Zoom H4 Handy Recorder Logo
57 people viewed this question
Top Zoom Audio Players & Recorders Experts
Jaysan Lunt
Level 1 Expert
Marvin
Marvin
Paul Bade
Are you a Zoom Audio Player and Recorder Expert? Answer questions, earn points and help others
