Question about Smeg DWI614 Built-in Dishwasher
Brand New Machine, can't open the door
Smeg di612ca intergrated dishwasher, delivered 2 days ago, just tried to take the protective packaging off, i have removed the polystyrene and clear plastic but there is what seems like a 'transportation device' a black piece of plastic with a screw through the middle, unhelpfully this screw is upside down so all that i can see is the treads. The door is not budging. It has been suggested that I plug it in and see if the door then opens, no luck, any halp will be appreciated. Cheers, J.
  • 2 more comments
  • dan199 Mar 04, 2008
    identical problem. have been told htere's no transport locking device and instructions are inside - not much help if ou can't open it
  • Anonymous Apr 05, 2008
    yep same problem. how the hell do you open the door??
  • Anonymous Jul 27, 2008
    I have the same problem as above really. The screw he mentioned seems to be on the underside of the base unit, right at the top where the door should close too (not actually on the door). I am baffled as to how to open this thing. Incredibly silly that there isn't a single instruction on the packaging, nor on the online help files.
  • JamesX Aug 31, 2008
    I have the same issue.
    The door appears to be clamped by a black locking mechanism which is screwed tight from inside the machine. The screw is inaccessible.
    I have a plumber coming tomorrow to organise the waterfeed so will let you know then if we've managed to sort it.
    Scholar:
  • 121 Answers
Threre should be instructions on what you need to remove, but where is this black plastic located, and wher eis the screw positioned?
Posted on Nov 07, 2007
I have a Smeg DI 112-1 intergrated dishwasher, when i switch on, light 5 flashes continuously and pressing the program selection button does nothing,
i have had success with dishwashers that have a (frozen) motor this involves
1 turn off electrical supply and or remove plug from receptacle.
2 turn off water supply, usually under sink, hot water side.
3 remove the mounting screws that you can see under the lip of the ledge when dishwasher door is open,once these are removed
4 carefully pull dishwasher out mindful of the hot water supply line that is attached.
5 visually locate the main shaft, use vise-grips to determine if shaft spins freely if not use v_grips to turn shaft two turns or so, check by closing the appliance door and turning power / water back on then try running unit.
this technique will work for some, and only if a (frozen) motor is the problem. this is a temp fix but it is better than nothing.
thanx good luck.
Apr 05, 2018 | Smeg Dishwashers
SMEG DI612CA ten beeps. no flashing light error codes
https://www.manualslib.com/manual/343502/Smeg-Di612ca.html
http://www.ukwhitegoods.co.uk/forumsphpbb3/smeg-di612ca-failing-spray-t91087.html
Feb 20, 2018 | Smeg Dishwashers
Smeg D1 612 CA dishwasher wont run
You may have to give a little more information.
Have a look at the manual, here -
http://www.manualslib.com/manual/343502/Smeg-Di612ca.html
and check for error codes/lights etc (p17; faults E1-E9)
Hope this helps
Oct 28, 2013 | Smeg Dishwashers
Leaking dishwasher
1-if it is brand new it should be under warranty 2-try changing soap brand, some suds up more than others and sneak past the seals 3- where is it leaking? (around the door, or underneath ie likely motor seal or plumbing) 4- check Plumbing connections 5-most "tubs" nowadays are one piece plastic, look it over carefully with a good flashlight. if you think you have found a crack remember where it is start the dishwasher and run it till it starts leaking and then open it and examine that spot-with the heat it may open up more or otherwise change
Apr 08, 2012 | Kenmore Dishwashers
The machine starts, does not heat the water, and just continues to run unless turned off manually. I am thinking either the timer or the heating element has failed. The machine is a model with the control...
hi test the element,the wires in the door can also break,it may be a thermostat/thermistor.if all these test ok it may be the pcb which is known as an intergrated these boards can be very expensive.
Jun 02, 2010 | Smeg 24 in. STX2 Built-in Dishwasher
How do I take the intergrated door of a busted whirlpool ADG 7540
open the door and inside you will see some screws, some of these screws hold the dishwasher door together and some (about 4) hold the integrated kitchen unit door on, trial and error
Apr 05, 2009 | Whirlpool 24 in. ADG7540 Built-in...
Smeg DI 612 C Domestic Dishwasher
I was told by a SMEG engineer that I needed to replace the detergent dispencer. Just waiting for him to get back with a new one.
Aug 15, 2008 | Smeg 24 in. DWI612 Built-in Dishwasher
Smeg Intergrated Dishwasher
Do any objects hang down (or stick up from below) and block it? Is the shelf pushed all the way in so it gets water through it? Does it seem to be spraying water, but not spinning?
Try spinning it by hand to see if it moves freely. It may just be blockede by a small object in the water.
Oct 08, 2007 | Smeg DWI614 Built-in Dishwasher
Smeg DWI614 Built-in Dishwasher Logo
978 people viewed this question
Top Smeg Dishwashers Experts
Marvin
Marvin
Norman Al-Anbar
paul
paul
Are you a Smeg Dishwasher Expert? Answer questions, earn points and help others
