Question about Canon Wordtank V80
Touchscreen doesn't work properly so calibration is not possible
Parts of the touchscreen don't react so I get stuck when calibrating my V80 after a battery change. Is there a possibility to bypass calibration, otherwise V80 is impossible to use!?
2 Suggested Answers
SOURCE: canon color laser printer 5000
I cannot calibrate the Canon LBP 5000 color printer. The option is grayed out. I have the same problem. Please send me an e-mail to ali.ayash@yahoo.com when you get the solution.
Thanks in advance.
Posted on Oct 06, 2008
Garmin 2595 Touchscreen does not work properly, it's shutting down by itself. I made calibrate, reset, and touchscreen diagnose, nothing helps
If you have tried to recalibrate it and it still is unresponsive, then the touchscreen needs to be replaced. More info on touchscreen replacement can be found here:
http://www.sharc.net/gps_LCD_repair.htm
Oct 20, 2013 | Garmin GPS
No signal how do I fix it
You have not said what model garmin nuvi ?
The touchscreen on a Garmin nuvi GPS usually loses sensitivity or stops responding if it's lost calibration.
This usually happens after prolonged usage.
Touchscreen problems are also caused by dirt, smudges and improper care.
If your Garmin nuvi's screen isn't performing as expected, Garmin provides solutions and tips to not only improve the device's performance, but prevent premature wear and tear.
Calibrating the Screen
If the Garmin nuvi's touchscreen isn't working, you need to calibrate the screen.
Calibration resets and repositions the screen for optimal performance without deleting saved settings.
Before calibrating the screen, press and hold the "Power" button to turn off the device.
Pressing and holding the "Power" button again for about 30 seconds automatically displays the calibration screen.
Pressing the dot on the white screen calibrates the touchscreen automatically.
Updating Software.
If The Garmin nuvi's touchscreen is still unresponsive, updating the device's firmware to the latest version can solve operating system problems that lead to touchscreen problems.
Before updating the device's firmware, connect the GPS to the computer using the USB cable. When the computer detects the GPS, the "AutoPlay" menu appears on the screen.
Tapping the arrow on the menu automatically opens the "myGarmin Agent" download page.
From there, follow the prompts to update your Garmin nuvi's software quickly and safely.
Cleaning. In some cases, the Garmin nuvi's touchscreen won't respond to touch if the screen is dirty. Touchscreens are sensitive to dirt and smudges that decrease sensitivity.
If the screen is dirty, cleaning it with a soft, clean, lint-free cloth improves performance.
If the screen is severely dirty, using water, isopropyl alcohol or eyeglass cleaner removes tough stains.
To avoid damaging the screen, apply liquid to a cloth instead of directly to the touchscreen before cleaning it.
Tips.
Refer to your Garmin nuvi's maintenance and storage information found on the device's manual prevents premature wear and tear.
If the screen stopped working after prolonged exposure to extreme temperatures or water, the device's hardware is most likely damaged.
In such a case, you need to contact Garmin for additional troubleshooting and possible repairs.
Attempting to disassemble and repair the GPS yourself only increases the risk of damaging the unit even further.
also it could be a battery problem if the nuvi is not getting power ?
May 08, 2013 | GPS
Touchscreen on a Garmin nuvi 1350 doesn't work. How do I fix this.
Try recalibrating it using the following method:
Nuvi 11xx, 12xx, 13xx, 14xx, 24xx, 25xx Series: Turn off the Nuvi. Place your finger on the upper left-hand corner of the screen and then push down on the power button to turn the unit on. Release the power button when the Garmin logo appears. Continue to press on the upper left-hand corner of the screen until you see the calibration screen. Press all of the prompted dots.
Once completed the Nuvi will display Calibration Complete
This will recalibrate your touchscreen to the LCD display.
If this doesn't resolves your problem. then your touchscreen may be defective and may need to be replaced.
Please see this page for additional information:
Mar 29, 2013 | Garmin nuvi GPS
My touchscreen on Garmin nuvi 1390 not working too and .calibration it's help alsoI did twice hard reset my GPS Garmin Nuvi 1390 and nothing happening and after I tried different trick,when I turned GPS off I hold the top left corner screen.The screen exchange for calibrations and I pressed several times according request and my GPS Garmin Nuvi 1390 started work,but repairing company wanna charge me $100 Canadian dollars.I didn't connect GPS to computer
Ello My problem is when i boot after a factory reset i have touchscreen to calibrate and when i do it it gives me try once again it's stuck there
I am not sure you are talking about a tablet PC or the new craze of tablets.
For the tablet PC you should have a screen calibration utility. You can calibrate the display for the Wacom (or other) pen, or for the touch input.
When you calibrate the pen, any touching of the screen with anything other that the Wacom pen will be ignored.
Similarly, when you calibrate the touch, any input with the Wacom pen will be ignored and you will be asked to use the proper instrument.
To get back to your case , it is possible that you are not putting the finger at the right place or not pressing hard enough. That is just a guess and I may be off the mark for the new tablets, but not for the Tablets PC:
Apr 07, 2012 | Tablets & eReaders
Does not work on the edges, can not access start by touching. when the screen is touched the arrow appears about half an inch away
Sounds like the calibration for the touchscreen needs to be reset. If you check in the control panel, there should be a ELO shortcut that allows you to calibrate/test the touchscreen. Try running through the calibration and see if the touchscreen behavior improves. If the calibration doesn't fix it, then you may have an issue with the touchscreen itself.
Mar 07, 2011 | Elo CarrollTouch touch-screen Monitor
Nuvi 760 powers on but the touchscreen will not work
If the Touch Screen is not working properly, Calibrate the touch screen..
Turn he unit off then on.... Slide Power Key to the right ( lock )
Hold finger on screen for about 30 seconds until calibration screen appears... for on screen instructions
May 10, 2010 | Garmin Nuvi 760 Handheld GPS Receiver
Touchscreen
I would like to ask a couple questions that might be of some use.
First, does the same issue occur when using the phone with the flip closed? That is, can you use the jog dial and keys on the flip properly?
If the phone works fine with the keypad and jog dial, then you should be able to try to recalibrate the touchscreen.
To re-calibrate the screen:
1. Select Applications tab
2. Select Control Panel
3. Select Device
4. Select Display or Screen
5. Follow the instructions on the screen.
6. Select Yes or No
Second, if you turn the phone off and on again, with the flip open, does anything load by itself, or does the touchscreen react as if something is being pressed?
This may indicate that there is a problem with the hardware.
It is possible to purchase a new touchscreen for under $100 from a few parts retailers such as http://cnn.cn .
It may also simply be a glitch or bug in the software or firmware OS. In this case, you can try a master reset or updating the firmware using Sony Ericssons update service (not compatible with Vista for the P910), or you could use a third party firmware utility such as from DaVinci etc.
If you choose any of the master reset, firmware or update options, you will lose ALL user data on the phone, so you should back it up before you proceed.
Apr 01, 2008 | Sony Ericsson P910a Handheld
Touchsrcreen is stuck in some mode.
3. Select Device
6. Select Yes or No
134 people viewed this question
Clive
Clive
old marine
old marine
