Question about Pit SSR 110CC Pro Beginner Bike
Hi need to know timing settings for 110cc engine
Hi my brother had a pity 110cc dad took the sparkplug out as punishment lol so he found 1 tht fits and screwed it all the way in obv a car 1 , that would ov stuck in tht far the piston hit the plug and the bent over bit of the plug got snapped off and timing jumped made a nice crunchingsound my unkle took head off and extracted the peice now we dont know the timing
plz help in dire need loncin 110cc
on the floor in bits
had 600 quid on parts on it every thing on
it is genuine thumpstar parts
all round
And i payed 100£!!
coz he couldnt be bovvered any more
  • john paterson Apr 26, 2009
    i bought a motorbike that had been trasformed and had a 110cc pitbike engine put in it, i just bought a pitbike and it needed a new piston so i took it out the other engine but i hav never set timing on a 4stroke chain timed engine.
    i am looking to find out what marks i need to use to set the timing
    can any1 help???
    Problem Solver:
  • 13 Answers
Put magneto on <T>top,take off head and place piston till flush with head,place top end back onput timming chain back on and cog with dot facing right between the two markers nw the valves r shut,happy treking
Posted on May 14, 2009
  • Cayaby74 Mar 31, 2012
    This tip is quick, simple and to the point! Thx!
The °mark on the cam sprocket has to mark the > at the head AND the T-mark on the flywheel has to line up with the > on the bottom
Posted on Apr 28, 2009
I took the needles out of my 934D Brother Serger and I can't get them back in!
First, relax!!!
Here's the manual that shows how to install the needles. Be sure you are using the correct needles for your machine and then verify that the "flat" part of the needle top is facing the correct direction. Check that the needles set screws have been screwed out enough so the needles will fit in the holes. Slide the needles as far up as possible. Then, while holding the needle up, screw the needles screws back in.
Brother 934D User Manual Page 7
Aug 20, 2016 | Brother Sewing Machines
I have a 05 nissan altima 2.5 that I just got my head replaced.when me and my dad took it off we un hooked everything like battery cables sparkplugs altnater timeing etc..... well got the head back put it...
free spinning- sounds like no compression- possibly due to valve timing not set properly-I would start there because everything is managed by computor these days and if somethings not right other things like fuel and spark management won't work- cheers Denny
Nov 14, 2013 | Cars & Trucks
SSR 110 bike wont start
ok so if its BRAND NEW take it back to the place you bought it mate its engine is dead there is no compression either that or your sparkplug is not in tight or at all (lol)
Dec 08, 2012 | Pit SSR 110CC Pro Beginner Bike
Need to know how to set the timing on a 110 4 stroke bike engine
Bad things happen! Unless your with someone in the know, find someone in the know! lol. Seriously!
Nov 18, 2009 | Pit SSR 110CC Pro Beginner Bike
Hi,i`ve got a yamaha fz750 1988..and it won`t seem to run on all four cylinders..i took the air box off and while it was running put my hand over each carb one at once and found that on carb 4 it stopped...
Hi JIm,
If it stopped @ 4 tht means thts the only cylinder firing .
Remove the spark plugs,earth @ on the cylinder head, crank start and check for sparks...if its sparking tht means the coils etc. are ok.
As the spark plugs are out exam them to their conditions visit this site for more details :-
http://www.spark-plugs.co.uk/pages/technical/diagnosis.htm
From here you would know if its carburator or probably it may need a complete tune up....carburator cleaning, float level..adjustment, valve clearance.. new plugs (gap to specs.), check air filter, replace or fit 'inline' fuel filter thn balancing of the carbs.
Hope this helps!
Oct 29, 2009 | 1987 Yamaha FZ 750 MG (Europe-US)
How to set timeing on.110cc chines quad
Throw it in the rubbish.. and buy a Honda 125cc. Much better quality
Oct 10, 2009 | Pit SSR 110CC Pro Beginner Bike
How do i fit rollers to a peugeot speedfight 2 50cc
first you have to take the variator casing off ( the casing with the kick start on) where the belt goes around the 2 sproket things , the left 1 u have to undo tht nut in the middle take tht metal plate off then pull the belt off then pull the roller casing out and u will see 3 10mm nuts on the back of it , undo those then change rollers then put every thing back to geter the way you took it apart. ( if u want to derestrict it, leave tht plate off with the 3 10mm nuts
Sep 17, 2009 | 2004 Petronas FP1
I have a 1990 Jeep Cherokee Limited. I'm gonna explain my problem in detail and I hope someone can help me. Origonally my brother ran it without oil and the Engine locked up on him. then my dad fixed it...
youir jeep wont start because you dont have your distributer in the right turning point. The way your distributer sits on the engine has to be the same as it was when to took out the previous distributer. if it isn't i wont spark at all, and if it actuallly is close enough to make it run, it runs like ****. i would bring in your jeep and have a shop move your distributer, or if you want to do it yourself... just try unbolting it, lift it up and turn it one tooth over on the gear thats inside the engine. bolt it back on. try to start it. if it doesn't work, just keep trying it until it does.
Jul 07, 2009 | 1990 Jeep Cherokee Limited
Pit SSR 110CC Pro Beginner  Bike Logo
6,151 people viewed this question
Top Pit Cycling Experts
john h
Mack Baxter
Are you a Pit Cycling Expert? Answer questions, earn points and help others
