Question about LG LS-K1830CL Cool Mini Split Air Conditioner
Split Unit not heating
The split unit is cooling but not heating. The outside unit is going through all the cycles and the heater is not coming on. What is the problem?
  • 4 Answers
There is no problem the unit is cooling on ly and is not a heat pump so it can't heat.
Posted on Jan 20, 2009
  • Anonymous May 28, 2015
    Are you sure this doesn't have a heat pump in it? I had an air conditioner unit similar to this that had the heating option on it. I don' t think there was a heating pump on it, but I know that it worked. It could be that he needs a heating pump for this unit in order to get the air conditioner to pump out the hot air.
How do you clean the filters on the outside unit of split system Mitsubishi reverse cycle 18RV
Outside unit does not have a filter. You can try to pull the disconnect on the outdoor unit. Reinsert after 10 seconds, see what happens.
Jul 08, 2017 | Mitsubishi Heating & Cooling
Wat is H3 error in bluestar split Ac?
Hello Yogesh...
Unless you are familiar with the BASICS of REFRIGERATION...
"H3" ERROR CODE means it is "Out of ORDER"...
Broken: Needs repair.
By searching the internet "split A/C " It defines a
COMPRESSOR overload protection is trying to
See second detail sheet (below)
Is the heart of MOST modern refrigeration systems.
In a SPLIT system it is the outside unit with the FAN
that should be running when the COMPRESSER is
in action. Typically then compressed & COOLED
REFRIGERANT is then piped into a cooling element
cooling takes place (expansion valve and evaporator).
Treated AIR (indoor) is then blown through the
evaporator... cooling the room and warming the
refrigerant (which continues to cycle back to the
outside unit where the compressing cycle
continues until the INSIDE temperature is
achieved... (thermostat on the wall)
pretty much means EVERYTHING but those combined refrigeration units seen WORLD-WIDE HANGING OUT OF WINDOWS... or on roof-tops with DUCTING for
"treated AIR" to be pumped where needed.
Similarly heat pumps simply have reversible valves...
which turn the coils around (functionally).
There too are split-system (inside/outside) & combined units.
Excellent refrigeration primer (below)
Alarm Codes
Gree Air Conditioners Error Codes
Hope this helps.
Carnac the Magnificent
May 13, 2017 | Heating & Cooling
Have a Silverstorm split aircondtioner lost remote cant get cooling in summer periods.
split air cons come in both configurations and are mostly in the last few years with inverter systems
you can get cooling only or cooling and heating systems
some brands only have the cooling only on the smaller units ( 8000 btu units)
Sep 09, 2016 | Heating & Cooling
My ac unit outside runs when the tempeture gets above what it is set on, but the fan blower keeps going on and off. I switched the theromstat fan to on from auto and it does the same thing, on and off in...
the fan control is not for the fan on the top of your outdoor unit. that is for the blower, you have 2 fans. Im guessing you have a split system, 1 unit inside and 1 outside?? Does the outdoor fan continually run??
Feb 06, 2018 | Ingram GMS90904CXA Heater
Split not cooling and not working on heat
make sure outdoor unit is running if it is may have low freon if not check power at outside unit
Aug 25, 2009 | LG LS092CE Split System Air Conditioner
Split system outside unit won't come on for cooling, only heating
Check your filters, dog hair and lack of maintenance will definitely burden the cooling mode of the Mr Slim units.
Aug 22, 2009 | Mitsubishi Heating & Cooling
Heating part of split system not working but fan outside is
if the cooling is ok then the reversing valve outside may be faulty
May 28, 2009 | Heating & Cooling
Non-working outside unit
If your unit is blowing heat inside and it's not a heat pump. It will be most likely electric heat in your case.
Sounds like you have a split unit meaning the condenser is outside and the cooling and the heat features are inside or under your home.If your Rudd is a heat-pump the outside unit will cycle/blow cold air outside in winter and hot air will cycle/blow outside during the summer season. Now, if for some reason the heat  is not coming on inside the house, would be the only reason that you would need to be concerned. Being a heat relay or breaker of could cause that problem. Hope this helps you, Sea Breeze
Oct 27, 2007 | Ruud UBHC Air Conditioner
LG LS-K1830CL Cool Mini Split Air Conditioner Logo
397 people viewed this question
Top LG Heating & Cooling Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
