Question about Fuji FinePix F700 Digital Camera
Digital camera black LCD
Hi, I bought digital camera Fuji finepix f11 from an auction where I was not able to check it. It was a bargain. It takes pictures fine and can download it to pc. however, the LCD is always black, when I expose it to direct sun light or a tourch it displays images as negatives. I believe there is a solution for this problem, probably reset whether hard or soft reset. could you please help me, my e mail. nawafleh@hotmail.com Kind regards Ahmad
  • Ahmad Nawafleh May 22, 2007
    addedd to the fault. I opened the device and found the ribbon of the LCD with marks of fault and dicontinued due to electric shock probably on one of the lines only. Do I have to repalce all the LCD or you think I can repalce only the ribbon if that possible? I doubt it..
    probably all the LCD needs replacement
    Kind regards for all the trials.
    Ahmad
  • Ahmad Nawafleh May 23, 2007
    the sock defected the ribbon connected to LCD, this is why no light on it. do I have to change all the LCD or you think there is possibility to change the ribbon only, that is in case the lamp is working.
    Regards for your helpful comments
    Ahmad
    Scholar:
  • 125 Answers
According to the specs, the camera has a sort of LCD auto brightness control with manual override. Before sending it for repair, look at the possibility of adjusting the brightness. Fiddle with the setting, if you do not have the manual you can download it from the fujifilm website.
Posted on May 22, 2007
  • Michael Ifurung May 23, 2007
    The shock came from the backlight supply. Backlights are cold cathode lamp similar to florescent lamps. If you say that you can see something from the LCD, probably only the backlight is defective.
  • Michael Ifurung May 25, 2007
    Is the socket going to the LCD or to the backlight?
  • 76 Answers
Could be easy fix but possibly not.what is wrong is back light for lcd not working,could be anything from loose connection to backlight itself,would have to be seen by cam repair shop.GET ESTIMATE FIRST.
Posted on May 21, 2007
I bought FUJI FINEPIX AX650 6 months ago.Now After taking pics when i press play button to view , it shows READ ERROR.another problem after taking a snap, the LCD display shows blank (color black) for few...
when having a problem with your digital camera. switch it of, remove the battery and charge the battery. When you replace the battery, the error should be gone. If not, you should contact the service centre closest to you.
Jan 22, 2014 | Fuji FinePix AX650 16MP, 5X Optical Zoom...
Fuji S6000fd; black display, both lcd and viewfinder
I have the same problem except everything is white, not black.
Jul 05, 2009 | Fuji FinePix S6000fd Digital Camera
Lcd will not turn on
check on the manual, there might me a button to turn lcd screen on, there is an option to keep it off to save battery
May 26, 2009 | Fuji FinePix J10 Digital Camera
How to take black an white pictures with the fujifilm A850
Hi
check in the settings if you have option for sepia or grayscale. choose this and photos will be in black and white.
Hope this helps
May 13, 2009 | Fuji FinePix A850 Digital Camera
My daughter dropped my camera. Screen broken.
That screen is the lcd screen (liquid crystal display)
I had a fuji E900 that was dropped when the lens was extended , and it broke the lens mount ring inside the camera.
I took the camera apart to try and repaair it.
as part of the dissasembly I removed the lcd .
If you can find a parts camera.with a good lcd, it is worth the effort to simply replace your lcd.
if you need mor info email me , and I will try to describe the dissasenbly sequence for the fuji that I had, perhaps it will be the same for your camera.
Tom
Jan 05, 2009 | Fuji FinePix S5500 Digital Camera
Brand new camera - no image in view finder
Have you tried to format the camera? Alternatively, and don't mean to sound rude but have you taken the lense cap off?
Are you getting any menu options on the lcd screen or is it totally blank? If this is the case then likely there is a problem with your camera and you should speak to who ever you bought it from.
Good Luck.
Dec 03, 2008 | Fuji Finepix S5800 Digital Camera
Fuji Finepix S700
does the LCD monitor work when taking a picture? if not press the evf/lcd button to toggle between the viewfinder and the LCD screen
Sep 11, 2008 | Fuji FinePix S700 Digital Camera
Shutter opening problem
How hard did you press on the button? it will focus if not all the way. Also, check your battery. Other than that, I don't know.
Apr 08, 2008 | Fuji FinePix F11 Digital Camera
Fujifilm finepix a303
A bit more explanation please Stevie Is the Screen really blank[black] or can you see shadow images. Or Is it White blank? And can you still take pictures even when the screen is in this state. Tell us more
Jul 06, 2007 | Fuji FinePix A303 Digital Camera
Finepix f11 black lcd
This indicates the back light has blown. The whole screen will need replacement- if the part is available -of that I cannot advise you, The repair costs in a work shop will outstrip the value of the camera, that is alomost certain
Apr 21, 2007 | Fuji FinePix F10 Digital Camera
Fuji FinePix F700 Digital Camera Logo
122 people viewed this question
Top Fuji Cameras Experts
Steven Wander
Steven Wander
KJ Soni
Level 1 Expert
Jerry Greenberg
Jerry Greenberg
Are you a Fuji Camera Expert? Answer questions, earn points and help others
