Question about LG 26LC7DC 26 in. LCD HDTV
Tuning channels on LCD tv
Recently got a LCD tv from friend but no manual. Mum accidently went into menu and has wiped out most of the digital channels which had been tuned in including 7 and 9. How do I get them back as we dont have a manual? its a LG 26LC7D model can I see a copy of the manual on line?
Thanks
I ended up just trialing numerous different things in google and eventually got a manual which was close enough to solve the problem. Thanks for the encouragement this site gave.
Posted on Dec 29, 2008
I lost a few digital channels on an old LG LCD, tried to auto tune but could not retrieve. Followed a tip online that said to auto tune with the antenna cable which will wipe all saved channels, once...
hi your signal could be to strong, on the aerial cable the thin brad rap 4 strands around the center solid pin then retune in auto, if this does not work you may to manual tune it in, or get someone to check your aerial and you could try a firmware update on your tv hope it helps
regards
shaun
Jun 29, 2014 | Televison & Video
Grundig tv loses the digital channels
Did you try disconnecting the TV for a few hours to reset it?
Mar 03, 2008 | Televison & Video
All channels permanently deleted accidently, can I restore them
Auto tune the channels as found in the manual
  1. On your remote, press Menu.
  2. select Channel and press OK on your remote.
  3. select Auto Tuning and press OK on your remote.
  4. select Yes and press OK on your remote.
Nov 10, 2013 | LG 32LD350 32 in. LCD TV
Accidentally set my TV to factory defaults
only digital signal is available now analog has been switched off no longer transmitting. You could try returning in all of your channels from the main menu the tv can do this automatically but you need to select the procedure . retune the digital channels only
1. click on the home button
2. scroll sideways till you reach settings
3. in settings scroll down or up and click on digital set-up (centre button of your scroll control)
4.then scroll down to, and click on digital auto tuning (centre button of your scroll control) this will activate automatic channel tuning the tv will do the rest and will wipe out old settings and retune in all channels
Jun 04, 2013 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
46xbr kdl hi for some reason my tv as froze on channel 44...it is set in the programs list and i cant remove it...
you could try returning in all of your channels from the main menu the tv can do this automatically but you need to select the procedure
Jun 03, 2013 | Sony BRAVIA KDL-46XBR2 46 in. LCD HDTV
Programming my tv with a remote
you can program the channel manually, just press the menu button in the tv panel. select preset and then manual fine tuning to tuned every channel you want to watch and then save it.to make a manual fine tuning, press manual then select channel you want to tuned and then press vol. up/down button to search right frequency channel.do this process in every channel you want to tuned. hope this can help.
Sep 15, 2012 | Haier HL24XLE2 LCD TV
I know this tv has digital capabilities, so i don't need to get the digital box, what do i need to watch my local channels? i have directv but does not include local channels (ie. fox, abc, nbc).
Hello
To tune the local channels do the following.
1 Press the MENU key on the remote control to
display the Main menu.
2 Use the CURSOR "UP" or "Down"
keys to highlight
Manual Channel Search. Press ENTER.
3 Use the CURSOR "Up" or "Down"
keys to select Cable,
Air (Antenna), or Digital Add-On.
After the search is complete, the HDTV will exit the
menu system and return to normal TV viewing.
IMPORTANT FACT: This HDTV maintains only one database
of digital channels. Therefore, when you search for
cable channels, the database of antenna digital channels
will be deleted. You will only be able to receive those
ClearQAM channels your cable company provides.
NOTE:"Not available" will appear on the screen
when an option is unavailable.
TUNING MODE UNAVAILABLE MENU OPTION(S)
Analog RF Digital Caption
Digital RF None (all Menu options available)
Video 1 Manual Channel Search, Channel Scan
Memory, Digital Caption
Video 2/3 and Manual Channel Search, Channel Scan
HDMI 1/2 Memory, Digital Caption, V-Guide
OK.
Feb 08, 2011 | Sanyo DP32648 32 in. LCD TV
Resetting a sony television to receive digital programs
The retuning process is as follows:
  1. Press the [i+] or MENU button on the remote control to display the DIGITAL INFO menu.
  2. Press the BLUE button to display the MAIN MENU.
  3. Press the UP or DOWN buttons to highlight AUTO TUNING then press the OK button to display the AUTO TUNING MENU.
  4. Press the RED button to start the auto tuning process for all available digital channels.
  5. Wait for the process to complete.
If you wish to CANCEL the auto tuning process whilst it is processing then press the BLUE button at any time.
You may lose some channels when you retune the TV as the channels have been rearranged. To locate them look at the EPG although you may still find that some channels are no longer available on FREEVIEW. See the following link for additional information
http://www.freeview.co.uk/_retuneinfo/
Nov 10, 2008 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Grundig colour tv lost digital channels
there is prob in tv cicuit . memory ic may be curupt . if u r not a tv technician then connect a tv engineer
Mar 03, 2008 | Grundig GF70-600 TV
I'm sorry, but I have not worked with Grundig TV's, radios yes, TV's no. However, The menu shouldn't be hidden. The first thing I would try would be to UNPLUG the set from the wall, wait about a minute and plug it in again. This action should reboot the micro processor. On some sets, there are two levels of menus, main and advanced. You would want "channel setup" and /or channel scan. You may also look in the back of the manual and see if it list some service dealers that you could call for help. I hope this helps.
Electrode
LG 26LC7DC 26 in. LCD HDTV Logo
272 people viewed this question
Steve Allison
Steve Allison
