Question about Abit KV8 Pro Motherboard
Start up problem
Comp was working fine 3 days ago then next day on startup POST stops at code 25. unknown if comp is on as monitor does not come on.
any fixes?
thank you
    President:
  • 1,073 Answers
Try to use another keayboard, if that dosent work, try to do a full >CMOS reset.
error 25 is a weird 1 as although it's supposed to relate to gfx it's also been seen to be apparently associated with faulty IDE cables/drives & even keyboards
Good luck to you
Posted on Dec 27, 2008
1995 Nissan King XE Pickup 4X4 V6 5 Spd Manual: About 2 months ago, I started my truck after running it all day and a progressively loud sound began. It started to sound like a jet engine. I removed the...
if you can`t remove starter take it some where and have it removed to check it out.I think your`e on the righ trail.The cable the no starts the hammer trick all sound like starter good luck
Jun 26, 2011 | 1995 Nissan Pickup
MY 01 IMPALA AIR WORKS ON DAY NEXT DAY STOPS. HAD
You most likely have a bad vachum motor that operates the blend door if you need more help post a reply.
Jun 15, 2009 | 2003 Chevrolet Impala
I have a L194WT LG Flatron monitor. One day it
Same problem started happening two days ago and ever since. I called LG and the product falls under a 3yr product warranty according to them (from my original purchase date of January 20, 2007). They will send packing slips to me so I can send the defective unit back to LG. I was told I am eligible for a replacement monitor - which will be shipped to me within 10 to 14 days (consecutive days, not business) - although I'm not sure what I'm being sent in return. My suspicion is that this monitor issue is a known issue by LG and they are quietly replacing the unit to those who follow through by calling CS.
Tips: Have your original purchase date on hand (in the form of a receipt) just in case they want proof of purchase.
Apr 16, 2009 | LG Flatron L1951S 19" LCD Flat Panel...
2000 VW Beetle dies occasionally and won't start for a while
run a scan tool on it and make sure there are no codes, if there is codes address those problems first, if no codes.. next time it won't start check for fuel preasure. it is probably a fuel pump getting ready to go out or they may be a large amount of something other than gas clogging the pick-up sock at bottom of fuel pump.
Mar 07, 2009 | 2001 Volkswagen Beetle
Problem while installing Win XP Prof.
The prolem is with Windows Xp cd...
When i try to install through the Genuine Win XP cd then it works fine...
Ok...
So use the original softwares....
Feb 16, 2009 | Intel DG31PR Motherboard
'88 4runner shift problem
You say you added gear lube. Where did you add the gear lube, to the differential? Because if you added gear lube to your master cylinder for the clutch, I think we found your problem. It calls for brake fluid.
Jan 20, 2009 | 1988 Toyota Pickup
Kv8 pro POSTcode 25
check your graphic-card.is the graphic-card supportet with your motherboard?
pci-agp.... take it out and try the onboard graphic-card.
Or try with 1 ram block...
Dec 28, 2008 | Computers & Internet
Jetta went dead?
take it back you should not put a remote start on a diesel period . they should have never installed this people just want the money these days
Dec 24, 2008 | 2001 Volkswagen Jetta TDI
No Display on my Samsung 204B monitor
If you know how to open it up and get to the power supply you will find three capacitors 2-820uf and 1-330 @ 25vdc 105o.they will have puffed up tops replace them. FYI the monitor has a 3 year warranty.
Dec 12, 2008 | Samsung SyncMaster 204B 20.1" LCD Monitor
Abit KV8 Pro Motherboard Logo
247 people viewed this question
Top Abit Computers & Internet Experts
Alun Cox
David
David
Jerry Umali
Are you an Abit Computer and Internet Expert? Answer questions, earn points and help others
