I have a teac a717 amp which is blowing both 5A fuses.
I have 40v AC at both secondary outputs from transformer and 4 rectifier diodes check out OK. Any suggestions of where to look? It was purchased new in mid 1980's.
  • pbuckley55 Dec 29, 2008
    To clarify some details, my son had the amp at low volume (yes it was low, I was in the room at the time) but he was feeding the output into his electronic drum amplifier. This was 2 days before Christmas. It made a pop sound through the speakers then there was no sound coming through the speakers. I have replaced one fuse and when I switched it on, the fuse glowed brightly before it blew.
    I will check the output transistors tonight.
  • weirdal May 11, 2010
    The first place I'd look is at the output section (transistors or STK type power packs). Since its from the mid 80s, I'd bet it has the STKs. Look for a big black chip the size of a credit card with about 20 pins attached to a piece of aluminum heatsink. There may be one chip or two.
    Any idea why/when the amp stopped working? Did it just die one day when you turned it on or did it blow out in the middle of a Van Halen album cranked up to 11?
  • 24 Answers
Thanks for the clarification. From the fuse behavior and feeding the amp into another amp (generally a no-no) it almost certainly is in the output section. If the amp used output transistors (numbered something like Axxxx/Cxxxx where xxxx=0000-9999) there will be some white three-legged low value (.47 ohm or less) resistors that are probably open. FYI the full part numbers for the transistors would be 2SA/2SC so a part marked C3281 would need a 2SC3281. B+D Enterprises (Google them) has most Japanese semiconductors and they have never sold me a fake transistor.
For more repair tips check out www.audiokarma.org
Posted on Dec 29, 2008
Jvc vcr/dvd recoroder dr-mvis
No power, No Display - test voltages on secondary side of transformer were pulsating
Check diodes 6230, 6240, 6210. They are BYW98 Rectifiers, in my case it was s/c. Thanks to Sparky for similar tip - Philips CD Model: CDR770/00
No power and no output
Replace C6 with 4.7uF, 250v
No power, voltages on secondary side of chopper were very low and pulsating
Check diode 6230. It's a BYW98, in my case it was s/c. Note: it's the rectifier for the 14v line
Dead, no power up on pin 2 of ic601
Replace x601 on main processor ic601
(Brko) Toshiba DVD Model: SD-1750 / SD-2800
No sound
Replaced C927 / C928
Nov 26, 2007 | Audio Players & Recorders
Behringer super x pro.the fuse keeps blowing on the ac inlet(t200 MA).a replacement unit works fine in the system.
When a fuse keeps blowing suspect an overload in either the power supply section or main amp part.
Look for burnt or damaged parts first.
The suspects in the power section are: transformer, diodes, rectifier, voltage stablizer, regulator.
In the Amp Section anything on the heat sink.
Jan 12, 2010 | Audio Players & Recorders
What are the secondary voltages off the transformer supposed to be?
The secondary voltages of a transformer are stepped down voltages. For example a transformer might be stepping 120 volts AC down to 25 volts AC in the secondary. Which then would be rectified by a bridge rectifier in the power supply and converted to DC Voltage which would be used to bias transistors or tubes and other electronic components. The amount of voltage that is output for use is determined and calculated by the engineers designing the amplifier or pre-amp.
Aug 26, 2009 | Audio Players & Recorders
Blowing fuse
Check for bad caps or diodes. Look for anything discolored or burned.
Dec 11, 2008 | Memorex MT1131 13" TV
Have a nearly 30-year old Akai stereo receiver AA-R30. Power light just stopped turning on. Opened up case and found main fuse between AC power cord and power transformer blown. When I replace the fuse,...
Look for shorted output transistors or possibly shorted rectifier diodes. An immediate fuse blowing up usually means that the power supply is the problem. Keep us posted.
Dan
Apr 08, 2008 | Audio Players & Recorders
Unit is dead....
The power supply is the first place to start.
Is there a transformer? Check to see that there is AC on the primary & secondary of the transformer.
If no AC on the secondary, then the transformer is bad. If AC ok on the secondary, then look for a bad rectifier diode/module and/or regulator module. There might also be fuses on the DC side of the power supply.
If the unit is completely dead, it's most likely a power supply issue.
Please let me know if I can be of further assistance to you.
- Jim
Feb 08, 2008 | Panasonic WV-CM1020 Television
Tv set won't start up
as your reg. output is 40v & you have checked every possible things responsible for it. my suggetion is that first you isolate power supply from hor.section & see if power supply output is ok. if it is ok then check for short & leakage in h/output like 1 hor.output tr. 2 diode or cap in eht winding. 3 check for print near eht transformer. 4 disconnect yoke connector & check . 5 & finally eht or flyback transformer.
Sep 29, 2007 | Philips Magnavox 27MS343S 27" TV
Proscan PS32610
Tv keeps blowing fuses it is due to short ckt in your tv in 1 power supply. 2 horl output section it is mainly due to 1 switching transistr 2 main fil cap 3 rectifier diodes 4 print short 5 h/output tra. 6 eht transformer
Sep 25, 2007 | Proscan PS36810 TV
RCA big screen tv
whenever fuse blows every time it is the indication of short circuit in tv. so please do not put fuse unless you know the cause of blowing fuse. these are the reasons of blowing fuse. 1 main filter cap.short. 2 rectifier diode short. 3 swithing transistor short 4 horizontal output transistor short 5 caps & diodes connected to flyback transformer short. 6 print short. 7 at last if every thing ok then flyback transformer defective. hope this will help. if you are not a tech person call skilled tech to fix it. good luck
Sep 24, 2007 | RCA P60828 TV
363 people viewed this question
 Grubhead
Grubhead
